E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > How do I remove factory intercooler clamp
Reply
      07-01-2009, 08:29 PM   #1
JohnL135I
Donkey Kong King
Drives: 2012 Boss 302
How do I remove the factory boost tube clamp that holds the stock tube that goes into the factory intercooler? It appears to be a pressed clamp, and I don't have much room to work with. Trying to install a code 3 intercooler.
Thanks
[SIGPIC][/SIGPIC]
      07-01-2009, 08:38 PM   #2
Mr. 5
Modder Raider
Mr. 5's Avatar
Scotland
759
Drives: M3
2007 e90 335i  [8.00]
Thanks
You cut it. That's the only way.
If you want to ever go back to stock then put a regular clamp back on.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD
Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM
      07-01-2009, 08:44 PM   #3
Sniz
Sniz's Avatar
661
Drives: e92 335 - gone // e36 M3 turbo
nope,
you can get it off w/ out cutting. It is a pressed on clamp so there is a keyed line where the clamp connects to itself. If your lucky the clamp is oriented on your car where you can see and get to that keyed line. Look for the line and use a long flathead screwdriver. Drive the screwdriver under the clamp right at that line and twist....HARD. If you get the screwdriver underneath right at that clamp and twist it will release and you can just take the clamp off.
If you cant get to the connection point....then like Mr. 5 said you'll need to cut it
once you have access to those clamps you can have those unclipped and ther intercooler out in less than 5 minutes.
I've done quite a few intercooler installs at this point and only 1 car needed a clamp cut off.
      07-01-2009, 08:50 PM   #4
Mr. 5
Modder Raider
Mr. 5's Avatar
Scotland
759
Drives: M3
Yah, I guess you're right, but it's not worth it.
Just cut the thing and don't worry about it.
Are you reusing these clamps then?
Originally Posted by Sniz View Post
nope,
e90 335i--SOLD
      07-01-2009, 08:54 PM   #5
Sniz
Sniz's Avatar
661
they can be reused but i wouldnt, most of the time they are mangled pretty good.
but using the screwdriver you dont damage anything else in the car including the stock couplings so they can be reused very easily.
that and most people won't have something to easily cut these clamps effectively.
      07-01-2009, 08:54 PM   #6
JohnL135I
Donkey Kong King
I can see the key, however I have very little room to work with (1 series), I'll try and get a screw driver under it, but at this point I'm not having any luck.
Thanks for the suggestions... this clamp is kicking my a$$$$$'s
[SIGPIC][/SIGPIC]
      07-01-2009, 09:00 PM   #7
Sniz
Sniz's Avatar
661
use a hammer to drive the screwdriver under the clamp.....kick the clamps ass!
      07-01-2009, 09:05 PM   #8
JohnL135I
Donkey Kong King
Ok, going back under with a Hammer.....
[SIGPIC][/SIGPIC]
      07-01-2009, 09:13 PM   #9
Sniz
Sniz's Avatar
661
best of luck
      07-01-2009, 09:23 PM   #10
Septro
Drives: '08 e90 335xi
famous last words..
get a Dremel with a carbide bit and cut that bitch like a snitch in jail!
      07-01-2009, 10:03 PM   #11
Soni
Soni's Avatar
Drives: Just a car
2007 335i Coupe  [9.00]
driver side took 5 second...passenger side took spent over 2 damn hours still couldn't get it out. At the end, asked my friend to stop by Home Depot buy me a long flat head screw driver 18" long, reach in twist and clamp pop out.
      07-01-2009, 10:53 PM   #12
Mr. 5
Modder Raider
Mr. 5's Avatar
Scotland
759
Drives: M3
The dremel worked perfect for me.
e90 335i--SOLD
      07-01-2009, 11:23 PM   #13
badass335
badass335's Avatar
Drives: 2017 540i Xdrive
I thought dremel tools were only useful for ecu work!
      07-02-2009, 05:22 AM   #14
JohnL135I
Donkey Kong King
Intercooler install is now complete
Thanks for all the help, I had to get a 8 inch flat head, and It was just long enough.... A 10 inch would have been golden. I think I spent a good 2 hours on that clamp, but its dead now.
Cheers
[SIGPIC][/SIGPIC]
      07-02-2009, 08:00 AM   #15
Sniz
Sniz's Avatar
661
Cheers
excellent!
yes a good long flat head is needed.
glad you got it off and the new intercooler in
      07-02-2009, 08:50 AM   #16
zaxjax
Drives: 2008 Crimson Red 335i
2008 335i  [9.00]
They are!
Here's my proof
      07-02-2009, 08:55 AM   #17
Sniz
Sniz's Avatar
661
Originally Posted by zaxjax View Post
They are!
Here's my proof
love it, thats me on the left and Zax on the right.
too funny, only person to ever use a Dremel on his ECU.
      07-02-2009, 09:02 AM   #18
zaxjax
2008 335i  [9.00]
too funny, only person to ever use a Dremel on his ECU in Mexico.
Fixed
      07-02-2009, 09:09 AM   #19
Sniz
Sniz's Avatar
661
Fixed
of course
      07-02-2009, 11:25 AM   #20
Blk07335i
Blk07335i's Avatar
Drives: 2024 G87 M2
+1 Dremel with the cutting tool. Nice and small...worked perfectly. I tried to pry the OEM clamp out as well but no luck. Not worth the hassle especially if you are not going to reuse them. Just cut slowly so you don't go too far.
      07-02-2009, 11:38 AM   #21
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
try this DIY ...
http://www.e90post.com/forums/showthread.php?t=91461
      07-02-2009, 12:29 PM   #22
ianthegreat
Drives: n54
Originally Posted by Septro View Post
famous last words..
+1 just don't cut to far, i have a nice cut in my oem tubing now!
Reply
e90post
