Hello, my name is 330d and I'm an OILoholic
07-12-2009, 08:07 AM | #1 |
Rep 3,022
Is this normal for a 330d?
At 4000 miles car needed 1 ltr oil top up... 7000 miles another .5ltr top up... and now at 12k it needs another 1ltr Oil service not due for 9k miles... Cheers.
M2 Arrived!
Family 5er |
07-12-2009, 08:12 AM | #2 |
Rep 89
My 335d has just had its oil service (2 years and 17500 miles), so early in miles terms (had almost 3000 miles before needed on mileage), but had to go in at 2 years old for brake fluid change so I got the oil done at the same time.
I have added no oil and it was still almost to top mark on dipstick. I've had it since 7000 miles, so certainly in 10000 miles I've owned it it has used none.
E 91 335d SE
Sparkling Graphite, Grey leather, Sat nav, Adaptive and High beam assisted Xenons, Electric heated seats, HiFi Speakers, Burr walnut etc. For winter - Defender 90 county. |
07-12-2009, 08:39 AM | #3 |
Rep 7,953
Drives: Merc diesel
Garage List 2010 TTRS [9.00]
2007 Audi S5 [0.00] May 2007 Porsche 99 ... [0.00] March 2007 Porsche ... [0.00] Sep. 2007 E92 335d SE [0.00] July 2006 E90 330i ... [0.00] |
Tim, not much help but never had to top the oil up in my 335d. That said, I know others who have had to top the oil up but whether this was within 'accepted tolerances of use', I don't honestly know.
Just a thought, but my manual for the Porka states what is permissable use of oil per 1000 kilometres, and I have had to top it up but it's well within the tolerances stated. Does the BMW handbook give any ideas? |
07-12-2009, 08:46 AM | #4 |
Rep 9,915
Drives: VW T5
Sounds like the engine has not been run in properly.
07-12-2009, 09:01 AM | #6 |
Rep 9,915
Drives: VW T5
Probably an old wife's tale, but engines that have been driven 'softly' from new tend to consume more oil. If the piston rings have not bedded in properly from exercising the engines full rev range then they can pass oil. But as I said, probably an old wife's tail.
When do you check your oil leve? At cold? Straight after stopping?
07-12-2009, 09:58 AM | #8 | |||
Rep 3,022
“Engine Oil Consumption varies depending on driving syle and operating conditions” Very helpful Quote:
Check is as per manual i.e. after driving and car is up to temp, leave for 5 mins then check.. Quote:
Wonder how helpfull the dealer will be...proably quote the user manual back at me
M2 Arrived!
Family 5er |
07-12-2009, 12:33 PM | #12 | |
Rep 9,218
My car used no oil at all in the first 9000 miles. It then needed a litre at around 12,000 and 15,000 miles. Since then it's been very steady only ever requiring a top up shortly before a service. |
07-12-2009, 01:45 PM | #13 |
Rep 732
If this is an E90 i would spend the time and look at the airfilter. Most of our cars have closed crank ventilation. If the airfilter is pretty blocked (not too difficult on that air filter lay-out), then you have a low pressure area between filter and turbo inlet which will increase blow by and thus suck the oil out of the engine.
See oil catch cans on the US forum too. |
07-14-2009, 01:32 AM | #14 | ||
Rep 3,022
No obvious oil in engine comp and none on drive
M2 Arrived!
Family 5er |
07-14-2009, 06:53 AM | #15 | |
The Tarmac Terrorist
958
Rep 29,345
Drives: 997.2 GT3
A gentle running in can lead to a glazing of the Bores which in turn lets oil slip By to Be Burnt. The engine will Be fine and last just as long.
997.2 GT3
07-14-2009, 08:38 AM | #16 |
Rep 7,953
Drives: Merc diesel
Tim are you any further on with gathering info. on this?
You don't know any decent engineers do you to maybe obtain an 'accurate' answer as opposed to one that may not be 'wholly' accurate from the dealer. Sometimes a compression test can give some clues. |
07-14-2009, 10:01 AM | #17 |
958
Rep 29,345
Drives: 997.2 GT3
Helen, i douBt a compression test will show up anything on this engine. It will Be within tolerances.
I too myself once ran an engine in like a granny and that too used so much oil it was unreal.
997.2 GT3
07-14-2009, 10:22 AM | #18 |
Rep 7,953
Drives: Merc diesel
Just a thought, wasn't sure whether he may be getting a slight seepage via the bores (sounds nasty doesn't it lol).
07-14-2009, 10:28 AM | #19 |
958
Rep 29,345
Drives: 997.2 GT3
Yeah it will Be through the Bores But the compression test will Be fine, its a 10k motor..If it had any proper Blow-By or one cylinder down on compression compared to others the cars performance would Be suffering and it would Be using mich more oil than tim states.
997.2 GT3
07-14-2009, 12:56 PM | #20 |
Rep 3,022
Hi Helen,
No closer apart from views in this thread (altough no 330d owners ). Unfort I dont know any BM engineers who can give me a fact based view rather than the generic stealer (and I will put money on this) "Sounds within tolerance Sir" And yeah, seapage within the Bores does sound nasty! So Carlos - if it is this, you reckon it will continue to burn oil?
M2 Arrived!
Family 5er |
07-14-2009, 01:08 PM | #21 | |
958
Rep 29,345
Drives: 997.2 GT3
But keep an eye on it, it could get Better with a few more miles. But i would expect it will continue as it is still using alot with 12k on her.
997.2 GT3
07-14-2009, 05:55 PM | #22 |
Rep 732
No, i meant E46 320d of which i had two which is about the same air filter layout as what you have today. Like you said, a sod, and one bad placed tree leave at the filter inlet nearly blocks it all. The guy who designed this ought to be fired. That's why i said on another thread regarding the E90 330d it might not be a bad idea to replace the BMW one with another after market filter, AND add a second, primary filter, as cold air intake. The primary one would be easy to clean, the secondary should stay dead clean, but limits any risks on leaks somewhere. The total restriction might be well below the average restriction of the original filter. The E92 320d I have now is one major improvement in this respect!
On a general view though, yes any increased air filter restriction will increase oil consumption with closed crank ventilation unless you change the plumbing. Just physics.. 10 years ago these all vented to atmosphere, now they're connected to a vacuum cleaner (= your turbo). The more vacuum, the more oil mist they suck out of the engine. regards, |
