E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > Private Owners For Sale / Trade / Wanted > Wash / Wax / Detailing / Touchup Supplies > Fixing minor scratches and dings
Reply
      07-18-2009, 08:27 PM   #1
BLACK335iCOUPE
Drives: 2007 335i Full Load
BIMMERPOST / Classifieds
Asking Price:
None
Item Interest
So I bought the touch up paint BMW offers.. tried it on the most noticeable scratch on the car and it turned out looking worse. Looks like a big flat elevated blob and is really easy to notice while walking by the car. I haven't applied the clear coat yet but I doubt it will help. Is it supposed to look this bad? Does anyone know if buffing it after a good wax job will flatten this paint bump or at least make it less noticeable? What other alternative is there to fixing annoying but noticeable scratches on your car without big blobs of paint?
Thanks.
      07-18-2009, 08:33 PM   #2
MCMLXXXIX
wat
MCMLXXXIX's Avatar
238
Drives: a gr3at whit3 5hark
wet sanding it should help
very fine wet sand that is...to level it out
2012 Toyota Highlander SE - PAST - 2008 e92 335i, 2006 e90 325i
      07-18-2009, 08:34 PM   #3
Bimmer007
Bimmer007's Avatar
Drives: Cars
quixx sells a scratch kit, they give you a fine sand paper where you sand the painted spot then apply the 1st compound, then the 2nd and it should look good.
walmart it the cheapest place i know where it is
http://www.quixxusa.com/
      07-18-2009, 09:52 PM   #4
NiVeDh
NiVeDh's Avatar
Drives: '08 E90 335i, '99 E36 M3
The way to use touch-up paint is to use a toothpick to apply a very, very tiny layer - just enough to cover the scratch. The rest of the indentation should be filled with clear coat. If you take your time and do it right, you won't have an elevated blob.
      07-19-2009, 08:43 AM   #5
Spydeputy
Spydeputy's Avatar
Germany
205
Drives: 2015 F23 M235i/2008,E90,335xi
take it to a body shop. they can use some 600 on it for you.
      07-19-2009, 06:58 PM   #6
BLACK335iCOUPE
what's 600? and how does wet sanding work.. does it leave a dull finish or is it just to level off surfaces?
      07-20-2009, 02:45 PM   #7
1N54E92
1N54E92's Avatar
Drives: BSM F30 M-Sport
langka or Dr. Colorchip.
google it
      08-12-2009, 09:23 PM   #8
bimmer01
bimmer01's Avatar
15
Drives: 2008 328i
Not 600, more like 1600 or 2000. Get the Dr. Color Chip kit. You'll have better luck. Fixing imperfections like that will never be 100% perfect, but the purpose of these kits is to sort of trick the eye into not seeing the imperfection unless your maybe 6 inches away from the spot. I've had tiny little scrapes that I can't even find anymore that I've fixed with the Dr. Colorchip kit.
Reply
e90post
