GVA - Where to buy double sided tape for aero lip install
07-23-2009, 12:48 PM | #1 |
Rep 2,808
I believe to install the OEM aero lip I need to use double sided 3M tape, right?
Is there anywhere to buy it locally? Or should I go to the dealer to get it (assuming they carry it) and if so, anyone got the part number for it? Thanks! |
07-23-2009, 12:56 PM | #2 |
Rep 3,807
Drives: Retired 2017 F87 M2
buy the red 3M tape. or look for the heavy duty one. I think homedepot should have it.
2017 M2 Coupe:|Black Sapphire Metallic|DCT|Nav/Idrive|M Performance CF Spoiler|M Performance CF DCT Interior| M Performance Gloss Black Kidney Grills| M Performance Steel Pedals | Eventuri CF CAI | 19" Brixton Rims | KW V3 Clubsport |
Retired: |2008 328i Sedan|Montego Blue| |
07-23-2009, 01:17 PM | #3 |
Rep 2,808
07-23-2009, 02:03 PM | #4 |
Rep 3,807
not sure what department. you can go there and ask. They should be able to help you. Just ask for heavy duty 3M double sided tape. I think its about 1 inch wide.
07-23-2009, 02:25 PM | #5 |
Rep 2,808
Thanks. Should be easy.
The official instructions call for applying this special glue all over. I'm guessing most people skip that and go for this double sided tape instead? Which spots did you apply the tape to? |
07-23-2009, 02:29 PM | #6 |
Rep 335
I bought my 3M double sided (red) tape at Home Depot in the glue/adhesives aisle. I believe it was $4.87 for a 5m roll.
Best to put the tape anywhere it is in contact with another surface. |
07-23-2009, 02:33 PM | #7 |
Rep 3,807
yup thats the one! I just used this tape when i had my hartage lip on my car. it held pretty well.
07-23-2009, 02:47 PM | #8 |
Rep 2,808
Hmmm... so noone bothered using the BMW glue instead, huh?
Just called the dealer and the Betalink K adhesive costs about $25... wonder if it's worth doing it that way, vs. double sided tape. I suppose with the glue, you probably can't take off the lip once you decide to sell the car. |
07-23-2009, 02:49 PM | #9 |
Rep 3,807
the reason y i used double sided tape, is so its easy to remove. I believe the betalink adhesive makes it close to impossible to remove your lip in the future.
07-23-2009, 04:15 PM | #11 |
Rep 335
Keep in mind that although the 3M tape is strong, it does soften above 30 degC -- I wouldn't hang too much weight from it or subject it to too much tensile forces.
07-23-2009, 08:31 PM | #12 |
Rep 836
i got my 3M double sided tape today at Canadian tire. its about 1inch thick. worked perfectly for installing my aero lip and m3 spoiler.
BMS E92 335xi | PROcede | K&N | KW | VMR | LUX | Bastuck |
07-24-2009, 02:32 AM | #17 |
Rep 3,431
i was at rona today and saw the tape on sale for $5.xx
Current: 09' E90 335d - Titanium Silver/Black Leatherette/Sports Package/6AT Paddle Shift/USB Integration/19" Staggered Breyton GT Gloss Black
Retired: 07' E92 328i (Jet Black) |
07-26-2009, 08:59 PM | #18 |
Rep 2,808
Is this the right stuff? Was the only tape similar to the specs at Home Depot. It's Scotch brand, but it seems to be owned by 3M. One inch wide, red backing, only thing is it seems about 1 mm thick, which I assume won't leave a gap if used at the corners? I thought this stuff would be thinner.
