Quick question RE PS2 ZP tyres + Follow Up Review
08-06-2009, 10:51 AM | #1 |
Rep 3,446
Drives: G22 M440D
Just driven back to Scotland today and had my Brother get me a quote on some Michelin PS2 ZPs for my E92 335D. Running the original Bridgestones that came with it in November 2006 - need a change.
Just checking that these are OK for Michelin PS2 Zps : Front : 225/40 18 88W Rear : 255/35 18 90Y The rears are Y not W, I take it that that is just a higher speed rating ? I know some have mentioned a BMW kite mark - is there any way of determining this from order/part numbers etc ? Do you get this dimension of tyre for many other cars - seems quite a specific size ? Prices very good, but would like exactly the correct spec. Free mounting D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
08-06-2009, 01:36 PM | #2 | |
Rep 5,493
Hi Dave Both speed ratings are fine - 168mph+ ! And the sizes are correct too, as are the weight loadings. I think these tyres come with the BMW * mark anyway as they are only really used in ZP fitment on BMWs... Oh, and I think you're going to be suitably impressed! Be aware that the Michelin's are very sensitive to the light point of the tyre matching the valve placement on the wheel - this will help to ensure an easily balanced wheel.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
08-06-2009, 01:41 PM | #3 |
Rep 9,915
Drives: VW T5
How do you determine the light point of a tyre?
08-06-2009, 01:47 PM | #4 |
Rep 3,446
Drives: G22 M440D
Thanks Tony
I'll get them ordered tomorrow. Probably fitted Monday. Is the light point of the tyre marked ? Little coloured dot ? It's been over 20 years since I used to fit tyres. Using the old pneumatic clamp and a muckle big iron bar I was a dab hand at it. Nightmare having to break the ice on the old bath out the back in winter to check for slow leaks though .... All a bit nore high tech now ... will leave it to the lads. D.
08-06-2009, 02:05 PM | #5 |
Rep 5,493
The light point of the tyre is where the yellow or orange dot is located on a new tyre sidewall. This dot denotes the lightest point and is supposed to be located at the same place as the valve position on the wheel (which is the heaviest part of the wheel's rotational mass).
08-06-2009, 02:06 PM | #6 | |
Rep 5,493
The light point, not the heavy point, is marked with the coloured dot... I changed my wording around from what I originally wrote so that it's easier to understand...!
08-06-2009, 02:06 PM | #7 | |
Rep 9,915
Drives: VW T5
I will be sure to check when I pick mine up tomorrow, is this true on all new tyres?? |
08-06-2009, 02:08 PM | #8 |
Rep 5,493
Yes... it's the same on all tyres. Reason is that no tyre is perfectly balanced due to the construction of the steel belts inside, so in order to keep as few balancing weights off the wheel (which negatively affect handling) the idea is that the dot corresponds to the location of the valve. In practice a lot of tyre fitters are lazy and don't bother to do this as they know they can balance a wheel regardless... irritating to me as it normally requires unnecessary additional weights...
08-06-2009, 02:11 PM | #9 | |
Rep 7,519
Drives: 2009 E90 335i MT
BTW, those tyre sizes are the same I have on my car. I think the "kite" mark you're referring to is a star.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
08-06-2009, 02:13 PM | #10 | |
Rep 5,493
Only Porsche-related markings (N0, N1, N2, N3, N4) are relevant to performance and suitability for a car, and need to be adhered to for best performance.
08-06-2009, 02:15 PM | #11 | |
Rep 3,446
Drives: G22 M440D
To be fair, I won't be balancing them this time. D.
08-06-2009, 02:18 PM | #12 | |
Rep 3,446
Drives: G22 M440D
But a 15" rim was exotic to me back then. D.
08-06-2009, 03:10 PM | #13 |
Rep 8,972
08-06-2009, 03:30 PM | #14 | |
Rep 3,446
Drives: G22 M440D
Price is very good. I get them trade. Option B is let my Swiss BMW Dealer fit them (And I checked around and nobody does "discount", even with special company offers). And that price makes me go a bit peely-wally at the gills .... Besides, those speeds are academic. D.
08-07-2009, 03:49 AM | #15 | |
Rep 295
Apart from speed rating is there any difference between 'W' and 'Y' rated tyres or is it marketing hype. My understanding from many years ago - that there was a constructional difference in the sidewall which was to do with tranmission of extra power to the road surface by higher powered cars, hence on 325i ='W' rated and 330i = 'Y' Would using 'W' rated tyres pose an issue with the insurance company in the event of an accident? |
08-27-2009, 06:42 AM | #16 |
Rep 3,446
Drives: G22 M440D
Had the Michelins on for the last 2 weeks and covered a lot of mixed driving.
First thoughts were of greatly improved steering in the straight ahead, now no longer diverted at the smallest change in camber or bump. Much, much better at shrugging off all those little deflections that plagued the Bridgestones and no longer holding on like Yosemite Sam when you encounter lorry ruts. The ride is also improved. How much of this is down to the fact they are nice new full-treaded tyres I'm not certain. They certainly seem a little more compliant than before. On the Motorway and at very brisk driving on wildly undulating (laterally and vertically) B roads I found a strange pitching sensation. On the B roads especially the electronics were stepping in. Regular ripples in the road were catching out the damping, . Looking carefully at my tyres I had inflated the rears to 2.8 bar ... but mine are now Y rated so they should be 2.4 for normal running. After adjusting them it feels a lot more balanced front to rear - so worth checking the exact spec of your tyre. Don't really drive like a tool in the wet, so can't comment for people who want to door-handle their car in the wet. Traction seems better than the hard Bridgestones. Overall - much improved over the Bridgestones. But still totally unconvinced by runflats. Just back from a 200 mile round trip to the car markets using an old Escort MK IV Estate car. Had a great time in that. Sure it would eventually go into glassy understeer in the wet and had no power but the way it rode and handled over many surfaces and road types makes the E92 look like a clumsy, crashy fool. E92 = Ultimate Driving Machine my arse. Ultimate Marketing Machine I can believe. My next car may very well not be a BMW if the 3rd generation of runflats don't improve considerably. D.
08-28-2009, 02:25 AM | #17 |
Rep 8,972
I had to reduce my PS2's to 2.2/2.4 bar to stop the rear wheels leaving ground over cats eyes or small lateral bumps. On 2.8 bar even middling acceleration, say up an mway slip road, if you hit a repair or a ridge the car will lurch as a wheel lifts, spins and drops again, traction light flashing. They've reduced the damping for comfort to try and cover for the the shocks transmitted from the tyres, but now it can't control the wheel movement.
The new car (09) is markedly worse than my previous E90 (06), which was great, but too 'stiff' for majority buyers who want m-sport looks, but SE comfort. And poncy magazines like autoexpress criticising hard ride, so they soften them all up for a 'wider' audience. Now we get 'performance suspension kit' for those who previously would have been happy with m-sport ride. Yep, this obsession with RFTs ruins what should be great cars. Shame, but same with everything when the accountants are put in charge. Realistically i'm going to have to change the suspension too for it to cope properly with proper tyres...... I can't live with it for 3+yrs otherwise.. |
09-01-2009, 05:36 AM | #20 |
Rep 3,446
Drives: G22 M440D
The last week has pretty much been hovering about 12 degrees with cold, wet to flooded roads. Done a lot of winding B road driving. Undulating, rising and falling, 90 degree turning stuff - following old coast roads.
Have to say that the Michelins are in a different league to the Bridgestones. I have adjusted the pressure to get a very good steering feel from the car (18" - 2.6 front W, 2.4 rear Y). While still firm (RFTs spit, spit), they certainly absorb more of a bump than the crashy Bridgestones. No longer clenching my teeth as I see a small pothole. And driving in the wet is making my confidence come back - the traction and feel is of rubber. The Bridgestones would Brrrrrp up and down over bumps with the traction light flckering like they were made of bakelite rather than rubber (especially in the wet). The Michelins flow much, much better. More predictable and much more secure in the wet. That increase in confidence is marvellous. Had to perform a very brisk exiting manoeuvre on a wet junction, expecting to have to feather the throttle to prevent the traction control killing power but was very surprised to quite frankly rocket out the junction while even able to push the loud pedal deeper ! Best of all, still a 100% improvement on straight line stability and reluctance to tram-lining. The Bridgestones were dismal at that - fidgeting on anything other than a mirror smooth road, going apoplectic on rutted roads. Tiresome. Ruining the car. Overall I can full-heartedly recommend the Michelin PS2 ZPs (RFT). Actually enjoying driving it again - quite playful now D.
