ESS Stage 4 flash!
08-12-2009, 09:46 AM | #1 |
391
Rep 3,149
ESS Stage 4 flash!
Hi guys,
Here is the "unoffical" and totally maxed ESS Stage 4 dyno, the car had the following modifications in both stock and Stage 4 runs : -AR Design catless downpipes, full exhaust -DCI intake -Upgraded FMIC -Upgraded dump valves This is the absolute max we can develop out of this engine on pump 93. Anything more will require high octane fuel or upgraded turbos as there is nothing left in the stock turbo's at this point. |
08-12-2009, 10:41 AM | #4 |
Team Zissou
3084
Rep 10,198
Hmm not the greatest for full bolt-on's. Do you have a baseline without the mods installed? Only 367wtq? Are you guys intentionally limiting torque for some reason, or just can't seem to make any more?
08-12-2009, 11:24 AM | #5 |
Mastermind
71
Rep 1,360
That actually seems about right because he's maxed out at 93 fuel on stock turbos.
08-12-2009, 11:29 AM | #6 |
391
Rep 3,149
The turbos are limited in the mid range to avoid choking them to early. This is the only way to make the top end power as we are at the absolute max of turbo capacity and more power can only be had by upping timing (race fuel) or more air (bigger turbos). There is nothing left on the table on pump 93 with this setup.
08-12-2009, 11:35 AM | #7 |
Team Zissou
3084
Rep 10,198
08-12-2009, 11:40 AM | #9 |
391
Rep 3,149
This is what is possible to get out of a 335 with those bolt-ons on our dyno. The car had perfect timing, fuel and pushed the maximum top end boost the turbos could supply. I am 100% sure no other tuning option out there would have made more given the same conditions, fuel and dyno.
If you notice the small top at 6100RPM, that is the actual max capacity of the turbos. That's it, no more air can be had from them no matter how you tune. |
08-12-2009, 11:42 AM | #11 |
Modder Raider
760
Rep 8,633
Drives: M3
Do you have the AFRs and boost values with those runs?
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
08-12-2009, 11:49 AM | #15 |
Mastermind
71
Rep 1,360
08-12-2009, 11:50 AM | #16 |
391
Rep 3,149
The problem is that there are no more boost to be had. We set out to find the absolute limit on this tune. The turbos are totally maxed at this point. You can only make a bit more power by upping ignition timing and that requires race fuel or meth injection.
08-12-2009, 11:55 AM | #17 |
Team Zissou
3084
Rep 10,198
08-12-2009, 11:55 AM | #18 |
Rep 1,410
I would prefer the extra boost up top than down low, like the "red" line over the "black" line dyno. Of course I am 6MT and I put the RPM's where I want. I could see where some would rather have the higher low-end TQ especially in an automatic.
08-12-2009, 11:56 AM | #19 |
391
Rep 3,149
08-12-2009, 12:12 PM | #21 |
Read the manual please, just do it before asking!
11
Rep 397
08-12-2009, 12:12 PM | #22 |
Rep 402
If this is the absolute limit you guys recommend not passing, then i'm impressed. Others will say that I make 400rwhp blah blah, but thats at a higher psi level where the safety boundary has probably been crossed. I like it, where is the pricing?
