JB3 Dyno Results
08-14-2009, 07:55 PM | #1 |
Dishonorably Discharged
19
Rep 176
JB3 Dyno Results
Hey Guys,
Just visited my local Dynojet today and thought I'd share my results for others. My modifications are limited to just JB3 V1.3 & BMS Intake. All things considered, the gains were modest yet reasonable considering 91 Octane and a 95 Degree air temperature. One thing that did stick out was my Map 3 run. My car did not like that map at all. I was in such disbelief that I ran Map 3 a 2nd time on the Dyno and the results proved consistent. Map 1 and 5 proved to be superior to Map 3 during today's conditions. Anyways, attached are the graphs for your viewing pleasure Edit: Removing graphs -- Made several noobie mistakes which affected the outcome of the HP/Torque curves. Will be updating my software and will re-read the Dyno DIY tutorial before running on the Dyno again. Will post my runs in the next week or so. Last edited by Louie A; 08-15-2009 at 01:30 AM.. |
08-14-2009, 07:57 PM | #2 |
Rep 1,658
Wow man, something is NOT right here! Even on 91oct. and 95F!
08-14-2009, 08:02 PM | #4 |
Rep 1,658
Looks like you not making or barely any HP at all, just a bit of TQ. I'd contact BMS. How's the car running btw?
08-14-2009, 08:08 PM | #5 |
19
Rep 176
Car is running fine -- Although I must say, it does seem a bit more sluggish after installing my intake. I'm considering placing the stock filter on to do some comparison runs.
08-14-2009, 08:09 PM | #6 |
Just some guy
49
Rep 1,531
dude thats like 50 whp too low for map 5.. either u need to let the damn thing adapt. and do some WOT pulls. or your install was wrong. or you have boost leak. or etc....
2008 BMW 335i/Sedan/Alpine White/Terra/Steptronic/Premium Package/Sports package/Comfort Access/USB/Sirius
08-14-2009, 08:34 PM | #9 |
Rep 1,034
Or the dyno is fucked. If he has any friends with similar mods they should dyno their 335 there.
08-14-2009, 08:51 PM | #11 |
Rep 85
Don't get worried, I just had my car dynoed a couple weeks ago. 93 octane, JB3 map 7, no other mods...
08-14-2009, 09:03 PM | #13 |
Rep 1,034
08-14-2009, 09:08 PM | #14 |
Joint Chiefs of Staff
4927
Rep 116,037
Something is seriously wrong there. Did you buy the JB3 new or used? If used, are you sure 1.3 final was loaded? You'll definitely want to contact BMS for help in sorting it out.
Given the oscillation all over the place even on map 0 I don't think it has anything to do with 91 octane or the temperature. Probably some sort of boost leak. Mike Last edited by Mike@N54Tuning.com; 08-14-2009 at 10:14 PM.. |
08-14-2009, 09:57 PM | #15 |
Rep 16
I think the first question should be is your car an auto or manual? If it's an auto contact Terry and he will advise you how to set up the dyno pull. The auto has to be in the right gear and top of the curve before making the pull because it keeps I think downshifting. I could be wrong on the details but I know he said we have to do something different with the autos on the dyno.
08-15-2009, 12:03 AM | #16 |
Rep 4,633
Map 0 which is stock you can tell your boost is going crazy, so there is something wrong with the CAR not the tune. Get a BT cable and try to troubleshoot.
08-15-2009, 07:33 AM | #17 |
Rep 1,517
Drives: Ever changing fleet
As others have stated, something is definitely wrong....likely is something with your car.
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
08-15-2009, 08:21 AM | #18 |
Rep 883
08-15-2009, 08:46 AM | #19 |
Rep 1,297
08-15-2009, 09:44 AM | #20 | |
Rep 1,517
Haha, I meant "is" not "isn't." LOL, that's what happens when you start typing in bed right after you wake up.
08-15-2009, 10:37 AM | #21 |
4927
Rep 116,037
I just heard from BMS who has been working with OP. It turns out the dyno operator was not pushing the gas pedal to the kick down! OP is going to update to 1.4 beta and retest. 291rw isn't too bad for 3/4 throttle though.
Mike |
08-15-2009, 11:31 AM | #22 | |
19
Rep 176
Kudos to Terry for helping me isolate and determining the issues |
