09 335d oem security system
08-15-2009, 09:38 PM | #1 |
Rep 583
I just got a 09 335d with the oem security system, i asked the sales if it has a proximity sensor and he said yes, so I got that option. I couldn't find any info on the proximity sensors that are included with the alarm install but only found mentions of the force entry to doors, hood and trunk.
So do these factory alarms have proximity sensors? (it either beeps or flashes lights when someone gets close) I know the red led flashes under the rear view mirror... |
08-15-2009, 09:39 PM | #2 |
Rep 8,693
Drives: 06 330i
i dont know, but congrats on the car. =)
08-15-2009, 09:59 PM | #3 | |
Bimmerhead
Rep 35
2007 E90 328i | BLK ON BLK | STEP | ZSP | ZPP | XENON | CA | OEM ALARM
08-15-2009, 10:12 PM | #4 |
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
There's an ultrasonic sensor inside the light thingy. Roll down your windows, lock your car, stick your arm in and the alarm should activate.
08-15-2009, 11:27 PM | #5 |
Road Warrior
Rep 123
My 335d does not have the proximity sensors but something will set the alarm off if I leave the sunroof open with the alarm set and the wind blows.
http://www.thelonghighway.com A Blog Dedicated to the BMW 335d
08-16-2009, 01:44 AM | #7 |
Rep 462
the motion sensor isnt inside the "clown nose" its located in the box directly behind the moonroof... the clown nose just houses the light to let you know the alarm is set.
08-16-2009, 07:02 AM | #8 |
Rep 238
If you are talking about a sensor that goes off if someone stands outside next to the car, then no. It's not on my 09. It has an interior motion sensor that detects movement inside, but nothing that detects anything outside the car.
2012 F10 Alpine White/Venetian Beige ZPP/ZTP/Sat Radio (previous 09 335i E92)
08-18-2009, 04:18 PM | #9 |
R1200RT
Rep 115
Drives: BMW 335d (E90)
As far as I know it comes with SCM class 3 as a standard. So no proximity.
I found a document on the kind of tests they perform for approval. http://www.scm.nl/_scm/uploads/file/...nglishANN1.pdf
335d E90
R1200RT K&N/Power FRK/black cylinder heads/Corbin /BMW Navigator IV/Baehr |
08-18-2009, 08:54 PM | #10 |
Rep 8,003
You can turn off the ultrasonic sensor if you press the lock button on your keyfob twice. I use this feature because otherwise, nearby trains set off my alarm.
08-18-2009, 10:40 PM | #11 |
Rep 583
