30FE Overboost - Is there a way to prevent this?
08-15-2009, 11:39 PM | #1 |
Rep 134
Guys, after many trials and tribulations I finally got my Procede to work in the very hot asian weather here (where 230-250F oil temps are common after a 15 minute drive). The ignition timing is great to play with, but with anything more aggressive than stock Stage 1 (say, 80% ignition advance) I keep triggering the 30FE Overboost code at 3-4k rpm.
Thing is, the boost logged at the point of limp doesn't seem outrageous--typically between 160-170kpa as reported by BT, which translates to less than 10-11 psi. I suspect some of you are going to say Doomsday maps or better cooling--but before I resort to lesser maps or hardware rigs, is there a more elegant workaround so the ECU doesn't assert itself as aggressively in cutting power? p.s. FWIW I'm running 29.2 on MSD80...
SOLD — '07 E92 335i 6AT ZSP | Drivetrain: Procede CANBUS | Supersprint Catback Quads | Suspension & Handling: Sachs Performance Coilovers | Brembo GT 380/345mm BBK | Breyton Race GTS + Michelin PS2 19's | Vanity: M-Tech Bodykit | BMW Performance Steering Wheel | MFD Air Scoops | ///M Lip Spoiler
08-17-2009, 02:29 AM | #2 |
Rep 134
Anyone from Vishnu cares to chime in? I'll do a couple runs tonight and post the results here... hopefully somebody knowledgeable will be able to help...
08-17-2009, 02:47 AM | #3 |
Rep 3,262
To circumvent this, get a JB3
08-17-2009, 03:31 AM | #4 |
Rep 7,377
you are not the only one with Procede getting code 30FE Overboost... send a mail to shiv.
08-17-2009, 08:00 AM | #5 |
Rep 7,377
did you try to set it at 75% and see if its still triggering it?
08-17-2009, 08:23 AM | #6 |
Rep 1,748
DId you try emailing Dustin? He usually handles some of the tech support issues if shiv is unavailable...
Dustin@Vishnutuning.com
BMW X5 35i: Boopie Exhaust & Intercooler, K&N Drop in Filter, JB3 (3+ psi) 2013 Dodge Challenger R/T: CAI, Catch Can, Custom Exhaust, Headers, 87MM Throttle Body, Diablo Custom 93 OCT Tune |
08-17-2009, 08:50 AM | #7 | |
Rep 134
That will positively set off the 30FE--80% appears to be the threshold number...
08-17-2009, 10:41 AM | #8 |
Rep 761
Do you have an oil cooler and upgraded intercooler? Both might help you here.
335i coupe Montego Blue Dinan stage 3 tune, Advan RS wheels 350whp/365wtq
1994 Brooklands Green Acura NSX Comptech Supercharged 390whp/300wtq |
08-17-2009, 10:52 AM | #9 |
Rep 677
Or the Support Form on http://www.vishnutuning.com/tech_callback.htm
Is usually the quickest way.
59 Corvette, 72 240Z, 73 Espada, ZXR
08-17-2009, 10:57 AM | #10 | ||
Rep 134
08-17-2009, 11:40 AM | #11 | |
Rep 10,587
you have some VERY nice mods on your car. Brembo GT brakes......
08-17-2009, 06:43 PM | #12 |
Rep 428
OP: I responded to your email. I think it has something to do with the wastegate work your dealership did... I explained this in the email.
08-17-2009, 10:44 PM | #13 |
Rep 134
Many thanks for the response--I'll try tweaking the UT and post results. Cheers
