GIAC Flash: when will stock file be avail?
08-19-2009, 07:38 AM | #1 |
Rep 390
Spoke to my local shop, we can't put back the car to stock as the stock file is not avail yet. What is the timing? And I assume once the file is ready, we could put the car back to stock mode on our own? Thanks.
08-19-2009, 10:52 AM | #2 | |
Rep 5
Most, if not all, of the stock files should be available. Flashing back to stock should not be an issue. If you know your ECU coding, you can send a PM our way so that we can help you figure it out.
08-19-2009, 10:57 AM | #3 |
Rep 518
08-19-2009, 10:57 AM | #4 |
Team Zissou
3084
Rep 10,198
I think the OP means the hand-held unit for switching oneself back to stock. We know GIAC is working on it, but there is no official time table for release yet.
08-19-2009, 11:06 AM | #6 | |
Rep 17
Any 93 octane flash can be flashed by a GIAC dealer back to true stock currently but it requires complete reflash meaning erase the performance file and write the original stock file to the DME. The multi-switching option (which would allow you to switch between 2 or more installed files, performance and stock and perhaps 100 octane race gas) is not yet released and GIAC has not advised us of a firm or tentative release date for that capability though we hope it will be soon. |
08-19-2009, 12:00 PM | #8 |
Rep 30
From my understanding (limited) . . . you can leave it in because the flash is undetectable by the dealer unless they rip it around the streets.
08-19-2009, 07:25 PM | #9 |
Rep 390
Thanks for the replies. I guess I'll wait...Imagine HPFP or whatever issue might come up and the car will need to visit stealership and we can't put back in stock mode....kinda risky I guess
08-19-2009, 07:41 PM | #10 |
Rep 5,040
this is one of the reasons why piggybacks still have quite a bit of remaining life
08-20-2009, 12:56 AM | #11 |
Rep 30
Here is what I don't understand. If you throw a visible or hidden code using the flash, from say your fuel pump, won't the code store the actual boost levels you were running? So don't you need a BT cable to run the flash under warranty?
On the plus side, the BT will show your real boost levels so it seems like a great tool to have. |
