Boost gauge= a/c not working?????
08-31-2009, 09:33 PM | #1 |
Rep 4,936
hay guys i was installing a boost gauge today (prosport) and i hardwired all the wires from the + connection with the red cap on top of it in the engine bay and grounded the wires with an existing bolt right next to the OCc (oil catch can). long story short the boost gauge stays on all the time never goes off even when i shut the car off (but works fine). and my ac doesnot work.
heres where i tried wiring it first 1. White,orange,red wires all tried to be connected to the light in the glove compartment Via splicing wires but did not work 2. tried doing the exact thing with the ciggarette lighter wires via splicing the RED/Black wires and THick brown wires but it did not work 3. Wired the white,orange,red wires to the positive connection in the engine bay and grounded the - wire via a bolt on the engine compartment so witch once of these could have caused the A/c heated seats and rear shade to go out? any sort of suggestion would be welcome .
[SIGPIC][/SIGPIC]
09-01-2009, 11:53 AM | #5 |
Rep 4,936
i think so do you think it would be better to leave the ground wire where it is and get the + wires to the cig lighter ?
[SIGPIC][/SIGPIC]
09-01-2009, 11:58 AM | #6 |
442
Rep 18,331
09-01-2009, 12:07 PM | #7 |
Rep 4,936
because iam guessing from what it seemed like that the ground wire from the cig lighter (thick brown) wasnt good enough. we tried splicing the red/black and thr brown wires to it but it didnt work.Now iam thinking to leave the ground wire where it is (in the engine) and rewire the + wire to the cig lighter that way the boost gauge will go off when i shut off the car
[SIGPIC][/SIGPIC]
09-01-2009, 12:51 PM | #9 |
Rep 4,936
thx for the help bro problem solved
[SIGPIC][/SIGPIC]
09-01-2009, 01:29 PM | #10 | |||||
274
Rep 6,510
I am not 100% familar with your specific prosport gauge, but it probably asks for constant power, switched power, and dimmer. You can get the switched power and dimmer from the ashtray, and get the constant power from a fuse tap in the fuse box. This is the best way. You should probably go digging in your fuse box anyways, since it sounds like you fried some stuff... just be careful to not get them mixed up, only check one at a time, use a flashlight... get out your manual and follow its directions for checking and replacing fuses.
EDIT, I see everyone else already solved this... glad to here. I typed this post up before lunch, but never submitted it, so I posted it anyway... lol -Rick |
09-01-2009, 02:12 PM | #11 | |
Rep 4,936
nothing vented just a mounted pod the cheap stuff my buddy wants 1 thanks.
[SIGPIC][/SIGPIC]
