Oil change after run-in at 2000 miles for E92 330 Diesel
09-11-2009, 03:39 PM | #1 |
Rep 1,207
I am at 2000 miles on an E92 330D. I would like to do an oil change.
BMW recommend BMW LL04, so i am thinking about Castrol Edge Turbo Diesel 0W-30. One mechanic (private garage) told me that BMW use special oil for new cars (some additives basically), so I should not replace this with a normal oil? Is it true that the original oil in a new car is different or is the mechanic talking crap? Is the original oil in a my new car the equivalent of LL04 or 0W-30? Is it safe to put 0W-30? Will this void my warranty as I will get this done from a normal local garage (along with a filter change). Any help much appreciated?
09-14-2009, 05:04 AM | #3 |
Rep 1,207
The dealer is charging something like £17 per litre while I can buy the Castrol 0W-30 for less than £5 from a autostore !
09-14-2009, 11:40 AM | #4 |
Rep 10,394
09-14-2009, 08:30 PM | #5 |
Rep 716
Check this site for a list of LL04 equivalent oil
http://www.opieoils.co.uk/c-686-bmw-longlife-04.aspx |
09-15-2009, 03:02 AM | #6 | |
Rep 1,207
Thank you all for your help. Castrol 0W-30 is equivalent to LL04.
However, my queries as in the original post are still unanswered... Quote:
09-15-2009, 03:09 AM | #7 |
R1200RT
Rep 115
Drives: BMW 335d (E90)
Where does it say in your instruction manual that you have to change oil now and waste money.
Be smart and wait for the car to tell you that you need an oil change. My 335d is at 4,500 miles right now and I don't expect it to alert before 18,000 given the current indicators. Spend your money on a nice mod!
335d E90
R1200RT K&N/Power FRK/black cylinder heads/Corbin /BMW Navigator IV/Baehr |
09-15-2009, 04:06 PM | #8 | |
Rep 1,207
My query was simple: If i do decide to change the oil, is BMW LL04 (equivalent to castrol Edge 0W-30) the oil to go for, or does BMW put some special oil the first time around.... and I would actually cause damage by changing the original oil
09-16-2009, 08:26 AM | #9 | |
Rep 10,394
Here's a little history lesson on BMW maintenance. IIRC..prior to the late 1990's all BMW cars had an initial fluid service at ~1200 miles which included an oil change. Since that time only the "M" cars get a break in service at this mileage. The fact is that many people change oil earlier because #1 they want to, #2 they don't believe BMW, #3 because they did so on their other cars. The reality is that advancements in synthetic oil and manufacturing allow us to have extended oil changes. Mike Miller who's a well known BMW maintenance guru in the U.S. (He writes for Roundel and Bimmer) has said time and time again if you want to keep the car over 100k miles then you should follow a more stringent maintenance interval (ie. oil changes every 7500 miles). If you don't plan on keeping the car over 100k miles just follow BMW maintenance. Last edited by F32Fleet; 09-16-2009 at 04:42 PM.. |
09-16-2009, 03:16 PM | #10 |
New Lifetime Replacement Policy
821
Rep 11,738
09-17-2009, 01:32 AM | #11 | |
Rep 1,207
Thank you all...
09-18-2009, 04:18 PM | #12 |
Rep 296
I have an E46 with 151,000 miles on the odometer and I have only done BMW recommended maintenance schedule and have used NO oil between changes and have had NO engine problems!
Go ahead and do it if it makes you feel good, but all it does is enrich the oil co's IMHO. BTW I also have an E91 with only 35000 and it too has never use any oils between change and it also only gets changed when the service reminder indicates that it is due! |
