Procede V3 Issues, SES/Limp and Misfires
09-11-2009, 04:47 PM | #1 |
Rep 3
First time poster, so appreciate any help/insight. I have a 2008 335XI and have the Procede V3. When I initially installed it, it worked great, but after about a month or so, it started to stutter under hard applications of throttle anywhere from the 3,500-5k rev range. The car would then go into limp mode and the SES light would come on.
The first time, I disconnected the proceed, took the car to the dealship and had it serviced. When it came back, I reconnected the Proceed, updated to the latest software/firmware after speaking with a helpful staff member at Vishnu (Dustin I think), and tried again. Everything worked great again...for about a month or so...now the whole cycle has repeated. I just got an OBD reader today and see that its throwing a P0301 error which indicates Cylinder number 1 is misfiring. I disconnected the proceed, cleared the error and the car is running fine in stock mode...I want to reconnect the unit again, as the power/torque difference is amazing, but if anyone has any input on getting the unit to run reliably so that its not always causing misfires/limp modes, I'd really appreciate it! |
09-11-2009, 05:05 PM | #5 |
Rep 3
I read about the sparkplugs in response to the engine misfires, but wouldn't the car be idling quite roughly if one of the plugs needed to be replaced? The car idles very smoothly...
09-11-2009, 05:11 PM | #6 |
1750
Rep 17,960
Drives: A Lot
Hi guys,
100% hardware related. The problem is either going to be worn sparkplugs, or less likely a weak coil, or even less likely a bad/clogged injector. A cat running a stock tune at 6-psi of boost can get away with any of these issues indefinitely because peak cylinder pressures are relatively low. A cat running a high HP tune needs all of these components to work as they should. Or else, misfire. Simple as that. To fix, the first thing you should do is determine which cylinder is misfiring. That is easy given that the diagnostic code(s) will tell you. Next, change the spark plug in that cylinder. If your plugs are more than 15k old, it would be a good idea to change them all. Factory OEM plugs will do just fine. If problem persists, it's likely to be a weak coil. Easy to determine by swapping the suspicious coil with another coil. Drive the car and try to trigger the misfire code again. If it "follows" the new cylinder location, then you know what to do. Replace it. They are reasonably inexpensive. If the misfire stays on the same cylinder then it is very likely you have a faulty/dirty injector. At that point, you'd better off taking it to the dealer for them to diagnose/replace it. Ultimately, it is VERY important to follow all these steps, in this order, to quickly solve your misfire problem. Because, gone unfixed, it will just get worse and worse which is no fun. No damage can come of it. It's just annoying. Shiv |
09-11-2009, 05:13 PM | #7 |
Rep 1,993
Email Vishnu, but depending on how many miles you have on the car I'd say look at the plugs first.
09-11-2009, 05:13 PM | #8 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
09-11-2009, 05:21 PM | #10 |
Rep 3
Thanks fot the great response Shiv. I will do as you indicated, and keep you guys posted as to how it works out...I have about 15000 miles on the car now, so I'll just have all the plugs replaced.
09-11-2009, 05:28 PM | #12 |
Rep 62
Codes after 133 firmware and 9-9 maps yesterday
29D2 2E9F 2C32 2C6C SES came on at the top of 1st gear.
2009 335i xDrive/Le Mans Blue/M-Sport/Prem/Nav/HD/Sat/Alum
09-11-2009, 05:50 PM | #14 |
Rep 5,175
If you are getting single cylinder misfires, then shiv is right on as many of us have experienced it. Swap you misfiring coil pack with a cylinder where there is not a misfire. If the misfire follows, then change that coil pack. If it doesn't follow the coilpack, then change the plug. If it persists, then it is likely an injector and you need to take the car to the dealer.
09-11-2009, 06:14 PM | #15 | |
1750
Rep 17,960
Drives: A Lot
For now, just erase the codes as the firmware update itself can trigger them. Then check the codes again if/when you throw an SES. And then email me the code info (shiv@vishnutuning.com). Preferably read from the PROcede's code reader (which is displayed in decimal as opposed to hex). All this stuff is very easy to diagnose and solve. Just please follow the guidelines when it comes to troubleshooting. Shiv |
09-11-2009, 06:41 PM | #16 | |
Rep 62
I did email you and submit a call back request via the website yesterday. I've purchased a Unichip from you In 2002, Xede in 2005 so I know the drill
09-11-2009, 07:03 PM | #17 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
09-12-2009, 09:34 AM | #18 |
Black Forest Bimmerphile
Rep 137
Thanks for the information, Shiv. My E92 went limp the other day and was running rough
16,000 miles on the odo. I had a heavy load and floored it to get into traffic on an uphill merge lane. Got home and got a P0303 code (cyl. 3 misfire). CEL and rough engine are gone. Will check the plugs. |
11-02-2009, 12:52 AM | #19 | |
Rep 408
