Exhaust Rattling on startup?...
09-16-2009, 04:27 AM | #1 |
Rep 29
it might be normal but i just wanted another opinion every time i start up my car it kinda has this rattling sound but at the same time it sounds like a chain or something... anyone know what it could be or if it's normal?
Thanks |
09-16-2009, 04:36 AM | #2 |
Rep 7,377
got exactly the same , only cold motor at startup
09-16-2009, 06:32 AM | #4 |
Rep 989
is it just when the car is cold? if not it might be some problems with the catalytic converters...
EURO E92 M3 2008 6MT Interlagos ///Fully Loaded! Evolve-R ECU Flash/Gintani Sport Exhaust/MS Stg2 Intake Kit/H&R Springs/MS 18/15 mm spacers/Bmw Perf. Grills/Gloss Black side gills/LCI Tails/LUX V3's/RD license plate leds |
09-16-2009, 06:43 AM | #5 |
SCCA B Street
117
Rep 660
Most dual exhaust systems on bmw's have a vacuum tube that opens and closes one side of the exhaust until the o2 sensors heat up. My e46 330's came off for more than a year. After putting it back on there is some noise while it opens or closes in the morning.
You may want to get a light and look under the car.
09-16-2009, 08:28 AM | #6 |
Î canŧ főcus mŷ attėntĭon
73
Rep 1,407
Wastegate rattle?
2011 M3 Coupe - Individual Fire Orange/Black Novillo Extended Leather, 6MT, Mode Carbon, Eisenmann Race, BBS CH-R, BC Coil-overs (Sold)
1995 M3 Coupe - Avus/Hurricane, AEM EMS, Precision Turbo, Boostlogic, H&R, Fikse FM/5, MaxVelocity, Maximum PSI, 20% Tint, etc etc..(Sold) 2009 M3 Coupe - AW/Fox Red, 6MT, Carbon Roof, Shadow Trim, etc (Sold) |
09-16-2009, 08:36 AM | #7 |
Rep 840
I think I have the same noise. I also had wastegate rattle and got a new set of turbos but this noise didn't go away. I will try to record it so we can compare but mine happens right before the exhaust flap closes and it doesn't matter if the engine is cold or not.
09-16-2009, 10:28 AM | #10 |
Team Zissou
3084
Rep 10,198
I had an issue like this at one point, i got under the car and one of the brackets that you screw in which supports the exhaust had come loose and was dangling parallel to them inbetween. Every other time I started the car or was at idle it sounded like a chain in a tin can.
long story short, that bolt was so rusted (thanks VT salt) that when i tried to loosen it it broke right in half. Last edited by jpsimon; 09-16-2009 at 01:57 PM.. |
09-16-2009, 01:49 PM | #11 |
Rep 3,961
The flap in the rear rattles on every BMW I have had. It occures a second or two after a cold start.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
09-16-2009, 02:46 PM | #13 |
Modder Raider
760
Rep 8,633
Drives: M3
Yep.
It's the wastegates closing during start up. It's normal.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
09-16-2009, 02:57 PM | #14 |
73
Rep 1,407
09-16-2009, 03:16 PM | #15 |
Rep 29
thanks for the replies guys, yeah it seems to just do it on a cold start and the only mods i got is the dual cone ex. probably gonna get the quad ex. later on, but yeah i guess it's normal n i never ask the dealership it always seems like they got something to say haha...
09-16-2009, 04:17 PM | #16 |
Rep 12,680
Drives: like an asshole
i had a problem with the bracket, they grinded it down a little for me cause it was hitting the metal head shield thats on top of the muffler
