Wavetrac LSD Installed on a (Previously) Welded Ring Gear
09-23-2009, 11:35 PM | #1 |
Modder Raider
759
Rep 8,633
Drives: M3
Let's face it...
if you have a production date of March of 2007 to Present, you have a welded ring gear and you can't install an LSD. You have to spend about $3,700 AND have to send back your own diff. Right? Wrong! Autotech (Wavetrac) has come up with a solution to separate ring gears from the OEM carrier and tap the ring gear so it can be used with the Wavetrac LSD for about 700 bucks. So, for just under 2k, you can have a limited slip differential installed on your previously welded ring gear! I gave a complete 3rd member to Autotech a while back hoping they could separate my ring gear from the carrier. Not only were they able to work with my ring gear, but they were able to come up with a solution and a process for all of those who have welded ring gears. I have a manual transmission which has the 3.08 rear end. Up until now, those with welded ring gears who have done the LSD upgrade have had to change their rear end to the auto ratio (3.46). Some have chosen the 3.46 because it winds up quicker, but for those who wanted to keep the 3.08, they were out of luck because it is almost impossible to find a bolted 3.08. Now, it doesn’t matter. Now I know that it’s all about personal preference with what ratio is used, but I really wanted to stick with the 3.08. IMO, since our cars have so much torque that gets hit at lower RPMs, then I think that it’s better to have taller gears in the back to take advantage of the torque band. The Separation The first picture is the OEM carrier with the ring gear attached. Here is a close up of how BMW welds the ring gears to the carrier. I’m not exactly sure what method was used to cut the ring gear off the carrier, but here is a picture of the ring gear that was just separated. The surface was then smoothed out and tapped for the attachment to the Wavetrac unit. Here is what the end result looks like. The Traction I knew the entire time that an LSD is the best modification that one can do to a RWD car, but it really hurts when someone makes a quote of around $3700, especially when you can get other mods for much less. But, it’s common knowledge that although you have more and more power, if you can’t put the power to the ground, it’s wasted. The moment I got into my car after the Wavetrac was installed, my car felt much tighter and planted. Even when driving in a straight line, the car just felt much more controlled. The times that you really notice the difference though is when rounding corners. Some of you guys have seen my video of when I rounded turn 4 at Laguna Seca and completely lost it doing a 540 into the gravel. I know that it most likely had to do with driver error, but I’ll guarantee that if I had this Wavetrac installed, I would have most likely saved it before my spin. This is a slomo of my wipeout at Laguna Seca: Differentials Open Differentials An open differential does a great job of transferring the power from the drivetrain to the wheels. The problem with an open differential is that the torque always takes the path of least resistance so if one wheel starts to slip, the torque will continue to drive the slipping wheel. Clutch LSDs These LSDs respond to driveshaft torque, so the more torque that is input by the driveshaft, the more the clutches grab giving more of the wheels equal amount of power. The problem with this type of LSD is that it locks the rear end when enough torque is applied, which creates a recipe for disaster for those who aren’t used to drifting. Torque Biasing LSDs Torque biasing LSDs takes the torque and divides it between the 2 wheels and increases the “bias ratio”. The bias ratio is the amount of torque that one wheel gets over the other. For example, some torque biasing diffs have a 2.5:1 bias ratio compared to the 1:1 in the open diff. With this example, if one wheels starts to slip, the gears in the LSD will multiply the torque that is going to the slipping wheel by 2.5 and transfer it to the wheel that has grip. The problem with this type of LSD is that if there is little to no load on one of the wheels, then this means that there is little to no torque that will be multiplied and transferred over to the other wheel. So, no matter how high the bias ratio is, if there is no load on one of the wheels, the Torque biasing ratio behaves like an open diff. Wavetrac The Wavetrac differential is a torque biasing differential but has a device inside the diff to react when there is little to no load on one of the wheels. This device creates a load inside the unit to be multiplied against even when there is no load on one of the wheels. Here is a quick video to show how well it transfers the torque to the wheel that needs it. Installation Thankfully, I had a shop near me do the install. Unitrax is a company that strictly deals with drivelines and they’ve been doing it for 25 years. They worked with installing the ring gear, setting up the backlash, and replacing the seals. I’ve never seen so many differentials in one place in all my life. http://www.gounitrax.com/ Here are a couple pictures that I took while I was at Unitrax. You can see the stand of differentials here: Here’s a rack of some Viper Differentials that they just completed: What else can I say, the Wavetrac is incredible! I'm really excited that somebody finally came up with an affordable way of working with our welded ring gears. Videos will come shortly!
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
09-24-2009, 12:05 AM | #2 |
Rep 986
This is definitely great news for us with welded ring gears (including me)!
Looking forward to more info and videos.
2008 E92 MT | VTT Stage 2+ 20T | VTT Inlets | JB4 MHD E85 | Fuel-It Stage 3 LPFP w/FPR and Return | BMS PI | AR DP | AE Quad Exhaust | Helix FMIC | ER CP | Tial BOV | DCI | AR OCC | Spec Stage 3+ | SMFW
09-24-2009, 03:49 AM | #5 |
Just some guy
49
Rep 1,531
looking forward to seeing video and b4 and after traction for 0-60
2008 BMW 335i/Sedan/Alpine White/Terra/Steptronic/Premium Package/Sports package/Comfort Access/USB/Sirius
09-24-2009, 05:32 AM | #6 | |||
Rep 1,230
Congrats on your diff...........Best performing solution at a competitive price
I have tested for these features to prove a point by providing different loads to each rear wheel to test for myself to see exactly what improvements I had gained via it's installation. To help amplify the situation, it was performed going up a hill with one wheel on wet very slippery grass surface and the other on a dry road surface. The car provided enough effective torque to the non-spinning wheel (in this case being the one on the road surface) and the car launched away no problem. In regards to the WaveTrac, you are provided extra grip if you off load wheels, as one would in a rally or racetrack situation. Since you track your car this is very appropriate for situations like yours but for most people driving their cars on the road, they would never notice the difference between a WaveTrac or Quaife fitted car. I guess many here have seen this video of how an LSD performs on wet road surface. Guys, enjoy your LSD's ........ Last edited by Sparky66; 09-24-2009 at 05:52 AM.. |
09-24-2009, 08:54 AM | #7 | |
Modder Raider
759
Rep 8,633
Drives: M3
09-24-2009, 09:45 AM | #10 |
Rep 8,745
Mr. 5 Thank you for taking the time to share. Can you clarify what Autotech (Wavetrac) did and what the Diff shop (Unishop) did.
Did Autotech build you the whole pumpkin and all Unishop did was to install? Thanks!
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
09-24-2009, 09:58 AM | #11 | |
Modder Raider
759
Rep 8,633
Drives: M3
I gave Autotech the 3rd member (the pumpkin) and they developed a process to cut the ring gear off and machine it. Unitrax is a company that installed the ring gear to the LSD and set up the backlash. They also do the actual diff swaps. Unitrax has 3 lifts to work with.
09-24-2009, 12:26 PM | #14 |
Rep 4,764
So what is the easiest process of ordering one to replace a welded diff? Is it Harold at HP Autowerks that I should go through?
09-24-2009, 12:32 PM | #15 |
Modder Raider
759
Rep 8,633
Drives: M3
Harold is a great option because I believe he already has a couple diffs already. Once you get the diff then I believe all you have to do is send your unit back.
09-24-2009, 12:36 PM | #16 | |
Modder Raider
759
Rep 8,633
Drives: M3
It took a couple months but this was only because they were working on a standard process for everyone else. i believe that the standard process is only about 3-4 days turn around time but you could contact Autotech for a more acurate time frame.
09-24-2009, 01:01 PM | #17 |
1750
Rep 17,960
Drives: A Lot
Craig-- what would have probably saved you from losing control of the car is keeping your head pointed to where you want to go. The second you take your eyes off your desired trajectory (as you did when you began the slide), the hands will naturally take you towards the unintended direction. Common mistake of course. Not necessarily fixed by adding an LSD. Laguna's a great track btw. Despite me crashing there 10 years ago at turn 9. Similar driving error.
Shiv |
09-24-2009, 01:10 PM | #19 | |
Modder Raider
759
Rep 8,633
Drives: M3
I tried to turn the steering wheel in the correct point while still holding the pedal, but my rear end wasn't responding at all. Contact Autotech. I believe that there is a little labor to install the diff onto the ring gear. I believe that part of that labor is included in the 700 price.
09-24-2009, 01:10 PM | #20 |
Rep 2,368
glad to see my diff back in action!! I really would like to feel out the difference between wavertac and quaife. The only times however, i would definately notice are steep ditches where i can get one rear wheel to life. Currently, the car cant move anywhere and spins only one wheel until the DSC kicks in. I dont think ive ever had those situations except after i installed the m3 rear sway bar. Anything stock wise would never reach a situation where one wheel is in the air...
09-24-2009, 05:04 PM | #21 |
Supreme Allied Commander
3890
Rep 54,575
Drives: F80 M3
Just to clarify a few things. A complete 3.46 Quaife or Wavetrac final drive unit does not require the purchaser to send back their own final drive at all. There is no core charge on these units.
The only time a core is required is the 3.08 Quaife or Wavetrac built from a low mileage final drive. In the case of the 3.08 Wavetrac, the purchaser will need to return the core for a core refund. Alternatively, they are welcome to keep their existing unit with no core refund issued. Sending your unit in for modification will mean some down time with your car awaiting the return of modified unit. A quicker solution will be to purchase a Wavetrac Final Drive unit and return your existing unit for a core refund. Harold |
09-24-2009, 05:14 PM | #22 | |
3890
Rep 54,575
Drives: F80 M3
Wavetrac $1295 Axle seals $35 Gear Lube $20 Misc chemicals $? Labor: Autotech to modify your welded ring gear $700 Your tech to install the unit 3-4 labor hours Buy one complete... $1995 + $800(Refundable core charge) + Freight |
