Just a thought, N54 stroker?
09-24-2009, 07:13 AM | #2 |
Rep 28,154
09-24-2009, 07:46 AM | #3 |
Rep 3,261
i dont think anyone stocks the required materials to stroke a n54 (crank, sleeves, pistons). But with enough money, anything can be fabricated.
Still need a fuel solution before you need to worry about that since the stock block holds more power than the stock fuel system can support.
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
09-24-2009, 07:56 AM | #4 |
ahat
1042
Rep 2,592
Your still gonna run up against the current limits of airflow in the scrolls - at a lower RPM even. So you will increase lowend - with what benefit?
You probably wouldn't need sleeves. Really just pistons and a crank. Offset grinding the crank will get you a little something - providing you could find a rod that would have a smaller bigend pin.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
09-24-2009, 07:58 AM | #5 |
Rep 28,154
09-24-2009, 08:00 AM | #6 |
ahat
1042
Rep 2,592
So why not do that at first and then just work on airflow with the existing displacement?
09-24-2009, 08:03 AM | #7 |
Rep 28,154
it wont make a ton of power just opening up the head, the cam might make somewhat of a difference, but if you are pulling the head off to do all the work, might as well go for the big power and stoke the bottom end if it was available
09-24-2009, 08:09 AM | #8 |
ahat
1042
Rep 2,592
I doubt you will see much of an increase in a few CC of increased stroke. It moves the power around - generally not UP. The tradeoff in torque increase is usually offset by a lower HP peak. Especially without MAJOR headwork.
09-24-2009, 08:41 AM | #10 |
Rep 7,377
you can take away M3 there since is much slower than a tuned 335i.
09-24-2009, 08:57 AM | #11 |
Rep 1,629
Should have mentioned that I was thinking of a stroked engine + bigger snails. As for fueling, I'm holding out hope that AMS/CP-E will come up with a solution. Then again, there's always meth...
Probably looking at $15,000 in work considering what I've mentioned but the results would unreal |
09-24-2009, 10:20 AM | #12 |
Rep 3,261
but why stroker?
i think the first step would be to buy an oem piston from tischer and send it in to one of the piston companies and see what they can do with it. Do the same for rods, change them out in the motor and then worry about bigger turbos and fuel system.
09-24-2009, 10:21 AM | #13 | |
Rep 2,479
09-24-2009, 01:08 PM | #15 |
Rep 1,177
I wonder if the N54 open deck block would hold 700WHP.
09-24-2009, 01:08 PM | #16 |
Rep 28,154
12-13-2016, 10:16 PM | #18 |
Student
24
Rep 190
Drives: GT3, 335i, Charger
well I love digging through old posts, this one caught my eye. Especially since we push 930hp to the stock block ^^
~2008 E92 Single Turbo Project~ 719whp/658wtq @29 PSI FFTEC Precision 6466 Bottom mount cppnr1@gmail.com |
