E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > bt scan codes
Reply
      09-24-2009, 02:06 PM   #1
BMWdmk
*Rollin 3rd*
BMWdmk's Avatar
Drives: Something fast
bt scan codes
hooked up my bt scan to my cousins car (SES on)
what do you guys think?
he also said the SES would blink on and off randomly
(car is stock but used to have tune, fmic and dps)
Short Test
Engine - N54
Current Fault Codes
2C7E
2C7E Lambda probe behind catalytic converter, trimming control
Error will cause a warning light
Error is not currently present
Test conditions have been completed
Signal or value below threshold
2C3C
2C3C Lambda probe in front of catalytic converter 2, not plugged
Short circuit or signal interruption
2C2B
2C2B Lambda probe in front of catalytic converter, system check
Error is currently present
30BE
30BE Injector, calibration: plausibility
Error will not cause a warning light
Timeout
2CAB
2CAB Lambdaprobe 2 before catalyst, temperature
2CA7
2CA7 Lambda probe heating in front of catalytic converter 2, function
Test conditions have not been completed
2C7F
2C7F Lambda probe behind catalytic converter 2, trimm control
2C2C
2C2C Lambda probe in front of catalytic converter 2, system check
Fuel pump
Longitudinal mgmt
Power steering
Transmission
Stability control
Transfer case
Air conditioner
Footwell module (FRM)
Car Access System
Junction box
Instrument cluster
Rain / light sensor
Telematic
Airbags
Roof control
Seat module - driver
Radio
Radio gateway
Current Fault Codes
E18F
Central registry does not match with debit configuration (Error_Registry_New)
Steering
Convertible top
Trailer
Park distance
Central control - low
Reply
e90post
