Methanol
09-25-2009, 09:42 AM | #1 |
Rep 4,481
Methanol
Hi,
Currently a couple of us are jumping on meth. kits ( snowperformance ). I fully understand the concept and planned to put a meth. kit on my former X5 3.0d already. I have a couple of questions: - Nobody concerned about the added hp and torque ? The tranny will have it's limitations. - Corrosion. Methanol is highly corrosive to aluminium. Why we expect that the N54 will not be impacted ? - Filling. Having the tank in the trunk is a clean installation. How often does it have to be refilled. You have to see meth as an additional, different fuel type for the engine. However, thanks to the pioneers who try this on the N54 already and provide experience and hopefully long-term proof for this mod. Thank you for feedback. Cheers, Eugen |
09-25-2009, 09:49 AM | #2 | |
Rep 5,175
For me, zero concern about added hp/tq. It is no different then those that have run race gas for a long time. The tranny will hold it, but the clutch may start to slip at some point. |
09-25-2009, 10:08 AM | #4 | |
Rep 4,481
09-25-2009, 10:14 AM | #5 |
Rep 5,175
Eugene, I have to tell you it is the single highest impact mod I have done to my car only behind my tune. The upsides are just so strong to doing this mod. The fact that you reduce carbon buildup in the engine is also attractive considering some of the N54 issues.
09-25-2009, 10:18 AM | #6 |
Rep 4,481
Now, on any methanol kit a failsafe system will be required. This is for
1) avoiding dropping methanol into the intake in case the methanol-tank is located higher than the nozzle(s) - easy to achieve. 2) falling back to a "safe mode" in case you run out of meth. this can be achieved by piggybacks or by opening the wastegates using a snowperformance addon. How did you implement this ? |
09-25-2009, 10:23 AM | #7 | |
Rep 28,154
the procede will go into valet mode if you run out, terry is working on doing it too. |
09-25-2009, 10:26 AM | #8 | |
Redline Addict
21
Rep 783
FWIW...I personally know one of the most prominent aftermarket Subaru engine builders and he HATES methanol, thinks it's a terrible idea to run it on any car. I think if you are going to run methanol it is a VERY good idea to change your oil more often. |
09-25-2009, 10:27 AM | #9 | |
Rep 5,175
The SafeInjection can function in multiple ways. It triggers a light in the cabin if flow falls below your set flow level. You can buy the optional flow gauge to monitor flow. Lastly, it can open you BOV, wastegates (issue there with vacuum actuated on N54), or send a signal to the piggy to trigger failsafe or valet. The only drawback really is what the poster above states. Change your oil every 2k miles. |
09-25-2009, 10:28 AM | #10 |
Vishnu Powered
69
Rep 2,205
The wastegate solenoid from snow performance I believe won't work on the N54 as our wastegates are not vacuum controlled.
2008 335xi Sedan | Titanium Silver | Black Dakota
PROcede v5 | Vishnu Exhaust | BMS DCI | AR Catless DPs | Helix FMIC | Stett Charge w/ Tial BOV | MORR VS8s | KWv3 |
09-25-2009, 10:30 AM | #11 | |
Rep 28,154
09-25-2009, 10:33 AM | #12 |
Vishnu Powered
69
Rep 2,205
I know a certified HKS tuner who mainly works on Supra's and he swears by meth. The cheapest bang for the buck type mod and it's so easy. You may have seen his personal JEDI supra on youtube, which sadly is now for sale.
09-25-2009, 10:34 AM | #13 |
Rep 4,481
09-25-2009, 10:37 AM | #15 |
Vishnu Powered
69
Rep 2,205
Even with a tuned car you should change your oil more frequently anyways. I see it from going from every 5k to every 3k with meth.
09-25-2009, 10:38 AM | #16 |
Rep 5,175
Why would it? People recommend changing oil more frequently just to prevent any concern if water was to get into your oil. Until someone here does a test on the oil, we won't know if 2k oil changes are needed or not.
09-25-2009, 10:39 AM | #17 |
Rep 5,175
Craig, this is no different than running race gas. There are a ton of guys running race gas and race maps daily. This is not like nitrous where you have a massive torque spike.
09-25-2009, 10:39 AM | #18 |
Rep 28,154
i can have your oil sampled at work, if i send you a bottle would you get a sample when you change your oil?
09-25-2009, 10:40 AM | #19 |
Rep 4,481
I'm changing every 6.500 mls. Good thing. But 2-3.000 ? Why ? Sorry ... answered above. So I could have water and methanol in my engine ... well, no proof.
09-25-2009, 10:41 AM | #20 |
Rep 28,154
3,000 was always the rule of thumb for changing oil, til synthetic came out and claimed it would last 7-10000 miles, but they dont mention the contaminants that get into your engine oil and hurt your engine
09-25-2009, 10:42 AM | #21 |
Vishnu Powered
69
Rep 2,205
Personally I would go from changing every 5,000miles (which I do now) to 3,000 - 3,5000miles for the reason that was stated above. There could be a chance of water in the oil. But like Former_Boosted said, we won't know until this is tested which it seems like will be happening soon. Better safe then sorry.
09-25-2009, 10:44 AM | #22 |
Vishnu Powered
69
Rep 2,205
Which brings up another question...
While using meth would you need to change your plugs more frequently? I was thinking less due to less carbon build up.
