Installed pics of New RSD BOV Kit
10-13-2009, 12:12 AM | #1 |
Rep 2,103
RS Design – Charge Relief Kit
Designed specifically for the BMW 335i (N54) turbocharged applications, the RS Design Charge Blow-Off/ Diverter System prevents compressor surge which can be detrimental to the longevity of the turbo(s). Utilizing a unique design that allows for crisp throttle response and increase turbo spool – the RSD Charge Kit will vent excess charged air through the use of a HKS SSQV (Super Sequential Blow-Off Valve) which uses a pull type relief valve. The SSQV is actuated by pressure alterations only, ensuring quick valve response and complete closure during idle. The SSQV utilizes two valves to offset and balance the charged air and increase efficiency. Smooth mandrel bends and a step design ease airflow into the throttle body. As the excess charged air is vented to atmosphere or re-circulated *(RSD optional kit), the concern of air being fed back to the compressor house causing potential damage to the turbine and its cartridge is minimized. This is a complete bolt-on kit and no modifications are needed. The RSD Charger kit will fit most popular aftermarket intakes. Kits are offered in tasteful color options. Key Features: - Complete Bolt-on Design - Prevents Compressor Surge by Venting Excess Charged Air - Crisp Throttle Response - Improves Turbo Spool - Increases Longevity of Turbo(s) - Utilizes HKS SSQV Blow-Off Valve Unit (Matte Black or Silver) - T-6061 Aerospace Aluminum Adapter Flanges and Bracket all Mandrel Bent - 4-Ply Nomex High Heat 350 degree and Oil Resistant Couplers - Stainless Steel Hose Clamps - *Optional RSD Re-Circulation Kit (60.09X.CPR.N54) - **Optional lower intercooler connection pipe - Offered in Wrinkle Black, Racing Red, Titanium, Polished - Made in USA Installed... InJen DCI fitment... BMS DCI fitment... Last edited by bavarianx; 11-02-2009 at 06:17 PM.. |
10-13-2009, 01:21 AM | #2 |
EUROPROJEKTZ
187
Rep 7,958
Drives: backwards
Looks great! Whats the price for one!? By the way, I haven't gotten a reply about my CARB sticker for my Injen DCI...
LTMW|SPEEDELEMENT|EUROPROJEKTZ
#TeamStretchNPoke |
10-13-2009, 09:22 AM | #3 |
Rep 1,137
how is the TB connection? an isssues with blowing it off? Price?
2008 335i coupe AW 6AT, RB Turbos, PROcede 2.5 V5, Alpina Flash, Injen Intake, VK MW DP . Helix IC, Vishnu PnP Meth(M10 nozzel), M3 sides, OEM Aero Lip, VMR V710 Midnight Blue, LUX H8, HID Fogs, M3 front bits, D2 Coilovers, Whiteline Rear Bushing inserts, Custom M3 Steering Wheel, Cyba scoops, M2 Performance Exhaust |
10-13-2009, 10:59 AM | #8 |
Rep 2,103
We've had a few units on vehicle's for a few months now and haven't had any blow off issues, probably due to the better quality hoses and the flanged pipe ends.
10-13-2009, 11:09 AM | #9 |
Rep 3,261
cost?
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
10-13-2009, 11:49 AM | #11 |
Rep 2,103
10-13-2009, 12:17 PM | #12 |
Rep 1,410
I have to agree that as long as the pipe ends are flanged then you don't even need T-bolts, worm clamps will do. Just like the AMS FMIC uses. And if you are gonna put T-bolts on everything make sure the piping isn't aluminum or you are going to start bending shit...
If you want insurance then buy an OCC. Car should have came with that anyway. |
10-13-2009, 03:25 PM | #13 |
Rep 122
I currently have this piece and am very happy with it. Upgraded from the stock charge pipe and right away, gained about +1 lb of peak boost. Definitely better then the stock piece imho.
10-14-2009, 04:49 AM | #14 |
Rep 5,175
Just be ready for the rash of blow offs when it happens. There are a number on the market and all have flanged ends and quality hoses.
10-15-2009, 01:02 AM | #15 |
EUROPROJEKTZ
187
Rep 7,958
Drives: backwards
price?
#TeamStretchNPoke |
10-17-2009, 03:29 AM | #16 | |
Rep 2,492
I also currently have this piece and am extremely satisfied with the overall sound, and feel of the HKS BoV & the charge pipe paired with InJen's DCI intake for the 335i. The sound of the above items combined with an aftermarket exhaust system will blow you away. It is also a wow factor to many other people who don't expect a BoV on our cars. I've gotten many compliments and questions regarding what is under my hood after parking my car as well. Bavarian Exclusive has yet again provided a quality product with great build and performance for the end user. Stay tuned for videos ! |
10-17-2009, 03:54 AM | #17 | |
EUROPROJEKTZ
187
Rep 7,958
Drives: backwards
#TeamStretchNPoke |
11-02-2009, 06:37 PM | #19 |
Rep 11,768
+1..*shift ftl..
-Rev
SGM e92 335xi|Helix|AFE|AWE|PROCEDE|SYNAPSE|ER|OSS|BMW PERFORMANCE|P3|always growing.. |
11-02-2009, 06:57 PM | #20 |
Rep 2,103
There's a reason that the t-bolts weren't used, even in our installs and tests we found the t-bolts didn't put an even load on the coupler and was overkill. The RSD pipe also has a bracket for added support.
11-03-2009, 04:45 AM | #21 |
Rep 5,175
We have hundreds of members that will attest to the fact that simple silicone couplers with off the shelf clamps will blow off the charge pipe. It has been tested over and over. Regardless of what bench testing shows, the real world has proven this as fact.
11-03-2009, 11:19 AM | #22 | |
Rep 2,103
RSD also is NOT using simple silicone couplers, the Nomex non slip high temp are the most expensive, best quality hoses made for these applications. There is a big difference between these and some plain Autozone hoses. If anyone really is set on having t-bolts we can supply those too. |
