Had my car "Stage 2 Procede" dynoed.....:(
10-17-2009, 11:36 AM | #1 |
Rep 919
My car has been throwing a few codes recently, "Cat ineffiency" and "Misfire in Cylinder 1". Well I cleared the codes and went yesterday and had the car dynoed..first thing the guys at the shop said was that they could hear and feel that the car was misfiring.
The car made 338rwhp and 360wtq...STD 84F. 10-9 Beta Map (Stage 2) "93 Octane" User Torque was set to 83% Ignition Correction 75% My mods are listed in my sig below.. I had the car dynoed a month ago at the same shop when I had the JB+ and stock downpipes and it made 323rwhp and 353wtq.. I am kind of dissapointed with such minimal gains coming from a JB+ to a Procede w/ AR Catless downpipes. Could this be a result of the misfires in Cylinder 1?? Does that basically mean that the car is running on 5 cylinders? I have seen Stage 1 Procede cars using 91 octane make 370+rwhp..Where is the power? I have a set of spark plugs on the way, I will install those and see if that helps, but I don't see me gaining another 40+whp from changing them. Any thoughts? |
10-17-2009, 11:38 AM | #2 |
Rep 7,377
There is something wrong with the car. Remove the tune and see how the car goes without it. If it throws codes just take it to the dealer.
10-17-2009, 11:46 AM | #3 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
10-17-2009, 12:01 PM | #4 |
Rep 415
Drives: 2009 335i e92 6MT
yeah, that's pretty low for stage 2... definitely something wrong. I made 360 on stage 2 without downpipes.
10-21-2009, 11:10 AM | #7 |
1750
Rep 17,960
Drives: A Lot
Did you write that correctly? There should only be four digits/letters when dealing with DME hexadecimal codes. And 5 numbers when converting them to DME codes in decimal format. With what tool are you reading it?
10-21-2009, 11:12 AM | #8 |
Rep 919
Ya, I may have wrote it down wrong..I will check it again, I was using the Canbus.
10-23-2009, 08:40 PM | #11 | |
1750
Rep 17,960
Drives: A Lot
Also, if you have a 6at, try running the 6at maps as they roll off boost slightly at the shift which is where 6ats are most misfire prone. The 2aaf code is just fuel pump implausibility which is normal for many tuned (and even some stock cars). Its a silent code (no limp/light) and nothing to worry about. Shiv |
10-23-2009, 08:43 PM | #12 | |
1750
Rep 17,960
Drives: A Lot
Also, if you have a 6at, try running the 6at maps as they roll off boost slightly at the shift which is where 6ats are most misfire prone. The 2aaf code is just fuel pump implausibility which is normal for many tuned (and even some stock cars). Its a silent code (no limp/light) and nothing to worry about. You're almost there... Don't give up. With your previous tune, you were only running lower boost pressures which didn't ask much from your ignition system. With full boost tunes, the coils and plugs must work properly. Coils should last the life of the car under most circumstances. But expect to replace plugs every 15k or more if you routinely race and run race gas/very high boost. Shiv |
10-23-2009, 09:59 PM | #13 |
Rep 919
Ok, I will try swapping the ignition coils and see if the misfire goes to cylinder 2.. I will let you know, thanks for the help!
P.S. just to make sure cylinder 1 would be the one nearest to the front of the car or engine bay, correct? |
10-25-2009, 11:04 PM | #14 |
Rep 919
So I swapped the ignition coil from cylinder 1 to cylinder 2 and got the following codes today, 10740, 10741.. Both cat inneffiency codes, no misfire code yet.
10-26-2009, 01:22 PM | #16 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
10-29-2009, 06:27 PM | #17 |
Rep 919
Ok, well I got the same misfire in cylinder 1 today "29CD"... This is after I switched the ignition coil from cylinder 1 to cylinder 2.. Any idea what it could be that is causing the misfire since I already changed the plugs and swapped coils??
10-29-2009, 06:30 PM | #18 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
10-29-2009, 06:41 PM | #19 |
Rep 919
Well, my engine warrant has already been voided so I will be leaving the procede in the car, how much do you think the injector will cost?? And labor??
10-29-2009, 06:46 PM | #20 |
How you like them apples?
41
Rep 1,492
Drives: 335i
what?!?!?! how did it get voided?!?!?!?
V5 rev2.5 | VExhaust | V1 KW | V701 | H&R Sway Bars | Ram Air Scoops | DCI |
10-29-2009, 08:30 PM | #22 |
Rep 408
They can not void your warranty only refuse to do service on something your mods could have reasonably broke.
