Unknown BT Scan Codes
10-20-2009, 06:24 PM | #1 |
Rep 1,617
I found these in the "Stability Control" Module:
5DCC: Valve (HSV2): Ground short circuit recognized. Error will not cause a warning light Error is not currently present Test conditions have been completed 5DBC: Valve (USV1): Error with cyclical valve and relay test Error will not cause a warning light Error is not currently present Test conditions have been completed What could these be related to? Only perf. mod is a JB+. Something to worry about?
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
10-21-2009, 08:40 AM | #2 |
Rep 1,617
Anyone? I cleared these codes once but they reappeared.
How could I tell my dealer to scan the car, without raising suspicions? I don't think "I had a very bad feeling about this. So I used the Force to scan the DME" will be very convincing
10-21-2009, 09:39 AM | #3 |
Rep 967
Seems like they aren't causing any problems (or at least you haven't mentioned any), so I wouldn't worry about it too much.
If you want to be extra cautious, take out jb+ and clear codes If they come back again, go to dealer. You have nothing to worry about if you don't damage the clip/if you clear the codes. You could always complain about another issue (even if you make it up) that will force them to scan the car. If those codes are anything to worry about, I am sure they will tell you that you need some expensive repair
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife | |
