335i Dyno w/ BMW Perf exhaust
10-24-2009, 09:43 PM | #1 |
Rep 70
Drives: 08 Alpine White 335I E90
Decided to get my 335 dyno'd yesterday on a whim...and this was the result, needless to say, both the shop owner and I were completely stunned at the numbers.
As you can see....it was ~370 hp, 377 ft-lbs. This is at the crank. Performance wise, my car ONLY has a BMW Performance exhaust. Stock tune, stock IC (as is very evident from the intake temps on the graph...), stock dp's. The run was done on a Maha dyno. For those not familiar, this is bar-none the best dyno available. It is the brand of dyno used by BMW, Porsche and Audi at their factory and testing facilities. Each Maha dyno costs over $300,000. Each Maha dyno accurately calculates drivetrain loss for each car on the dyno. After the run is completed...the operator places the car into neutral, and based on how much effort it takes to slow the wheels to a stop, it will calculate the drivetrain loss for your specific vehicle. It's very interesting to watch...when the car reaches the redline at the run, and the car goes into neutral, the drivetrain loss is calculated from redline down to idle as the rollers slow the wheels. The green line on the bottom is the drivetrain loss. As you can see, drivetrain loss varies based on vehicle speed/RPM. So when most people go on a DynoJet and the operator says "oh your car has about a 15% drivetrain loss on this dyno"...that is horribly inaccurate. Proof of how accurate a Maha is....this shop see's tons of stock E46 M3's and all day long they will dyno in the 331 -334 range...right on the money with what BMW says. It can also do just wheel horsepower, and we did a run with just wheel horsepower, it was 302 whp, 341 ft-lbs. It is also important to note, that unlike a DynoJet or DynoDynamics, the operator has no control over correction factors. So numbers can't be artificially inflated. The only corrections it makes are standard SAE, DIN, ISO....etc corrections. The shop owner has seen a ton of 335's, modded and stock, and he was blown away by my numbers. He begged me to let him take it around the block to see if his butt dyno corresponded to the actual dyno....needless to say it did! He got out of the car, and said "this car has to have some sort of tune on it!" No tune!!!!! An interesting tidbit though...I just had the car into the dealer and got the most recent software update, maybe it's stronger than everyone thought! |
10-24-2009, 10:47 PM | #3 |
Rep 5,046
Not to be a buzz kill but I'm going to call BS. Exhausts for these cars barely provide any HP. Maybe 5, 10 if your real lucky. Dyno #s are worthless or anything but comparisons and seeing how much power new mods give you. Plus, your im tempe, which means youre only on 91 octane.
10-24-2009, 10:50 PM | #4 |
Once upon a time ......
276
Rep 5,048
Drives: 2008 JB E92 - SOLD 5/2010
Nice man.
I used GoodSpeed for services on my 996 & an earlier Vette when living in Mesa & Chandler. They know their stuff, no doubt. Start modding & then post the results. |
10-24-2009, 10:54 PM | #5 |
ahat
1046
Rep 2,592
what altitude you at I in AZ?
And you CANT get an ENGINE dyno number with the engine IN the car_ - nomatter how advanced it is
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
10-24-2009, 11:04 PM | #6 |
Rep 11,768
i have to call bs..
-Rev
SGM e92 335xi|Helix|AFE|AWE|PROCEDE|SYNAPSE|ER|OSS|BMW PERFORMANCE|P3|always growing.. |
10-24-2009, 11:17 PM | #7 |
Rep 194
Number seems high, but it has been suggested that the 335i is underrated at the factory, some suggest closer to 330-350hp at the flywheel.
Still, 370hp at the flywheel with an exhaust is a lot, sounds like a higher reading dyno. |
10-24-2009, 11:30 PM | #8 |
Rep 1,357
Drives: '08 e92 335i COBB 4.01 Stage 1
Wow. Are you sure there isn't a piggyback tune in your car? Sorry, I don't know if you bought it used or new...
BTW, could you tell us what was your drive train loss? |
10-25-2009, 03:50 AM | #11 | |||||
Rep 70
Yes, I know the only true way to get an engine dyno number is to take it out of the car and put it on an engine dyno. However, the unique way that the Maha can calculate drivetrain loss throughout the rev range puts it really damn close. There will always be those who doubt though. dude Believe me, I wanted to call BS myself, but it is what it is. There is no way to "cheat" on this dyno. Quote:
Just out of curiosity sake, I'm going to get it on a DynoDynamics dyno next week for a comparison. Quote:
I purchased the car new. And have done no software/tunes/chips/piggybacks on it. I'm waiting for the BMW Performance software...which is part of the reason I went to the dyno, so I could get a baseline before the software. Like I said though, I did have the dealer upload the most current ECU update...and it made the car drive wonderful. Much smoother than it ever was, and helped to eliminate a lag that I always felt was present. The drivetrain loss is the green line at the bottom of the graph. It is drivetrain loss in horsepower. At peak hp, there is a 60.9 horsepower drivetrain loss. If you go near the redline on the graph, its in the 70's. If you want a percentage, just divide that into peak horsepower...which is roughly ~16% at peak horsepower. |
10-25-2009, 04:52 AM | #12 |
Rep 198
Why are you using the "Corrected Data"? The uncorrected numbers are 327 Crank and 266 WHP ... that seems like it's a lot closer to what it probably is ... There is no way you are making 70 Crank horsepower over what the car is rated with just an exhaust ...
Most dyno number out there seem to be DynoJet so I'd give it a run on one of those and see where you fall
Not Stock... |
10-25-2009, 03:25 PM | #13 | |
Rep 70
It is the North American standard for dyno correction. It takes into account atmospheric conditions and standardizes the numbers, so they can easily be compared no matter what the conditions are. It's not full proof...but there's a reason its called a standard. Nearly every dyno will report SAE corrected numbers. |
10-25-2009, 03:36 PM | #14 |
Modder Raider
760
Rep 8,633
Drives: M3
I'd like to see the equation for the calculation of crank HP.
There's obviously an equation somewhere since it gets the power from the wheels and transfers it into crank numbers. I'm not going to go as far as saying BS, but I will say that someone most likely made a mistake somewhere with the process.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
10-25-2009, 04:25 PM | #16 |
Rep 7,377
When i dinoed on the MAHA i got 260 rwhp stock tune with full bolt ons. Drivetrain loss was 55hp.
10-25-2009, 05:29 PM | #18 |
Rep 70
10-25-2009, 05:56 PM | #19 | |
Rep 2,563
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
10-25-2009, 06:48 PM | #20 |
Rep 1,705
Call me crazy, but here is a theory...
BMW's ECU is pretty smart. Perhaps it is adding boost to compensate for altitiude, and the other factors to run the normal 300-ish HP that it is designed to do, thus the uncorrected numbers the dyno has being right in line with what they should read, then the dyno "double" corrects the numbers. In other words, the dyno says "if it were ideal operating conditions the car produce 360HP (or whatever) because right now, it is putting out 310HP (or whatever) in non ideal conditions" even though BMW's ECU already compensated for poor dyno conditions. I hope this idea makes any sense at all?!?!? |
10-25-2009, 09:11 PM | #21 |
Resident Kerbalnaut
478
Rep 10,703
I just got my 135i back from the shop and got the latest N54 software. I also only have the BMW perf exhaust and I noticed the same things you did. My car pulls to redline now, as opposed to the power dropping off at around 6500 RPM like it did before. I also have noticed a power increase on my butt dino.
Anybody know of a good dino in NY so that we can compare numbers? PS heres the link to my thread about this. The tech who did my software update said that he tailored the software around the fact that I had a perf exhaust. http://www.1addicts.com/forums/showthread.php?t=315365 |
10-25-2009, 09:48 PM | #22 | |
Rep 198
Not Stock... |
