taking care of the turbo 335i
10-03-2006, 04:20 AM | #1 |
Rep 804
should i let the car cool down before turning it off after driving hard? or should i also let it cool down a little after a normal drive?
please help and post info with taking care of the turbo so it can last longer. |
10-03-2006, 06:36 AM | #2 |
Rep 10,185
It could help a bit if you let it cool
The electric watepump also keeps supplying coolant after you shutdown the engine to hep cool the turbos
BMW if you are reading, I need a job, Please. |
10-03-2006, 08:51 AM | #3 |
Rep 1,772
Any time you drive hard, you should have at least a few kilometers of normal, light-throttle driving as a cool down lap prior to parking.
Obviously, this requires a bit of planning but I think it is a good idea... especially with the turbos. I would think that with the turbos, if you are just driving normally and you are not in an extremely hot place, you should be able to park the car and let it idle for about 10 seconds prior to shutting it off. I am just speculating though. From what Fleet says, it seems like BMW has it set up so that you don't have to worry about it too much. |
10-03-2006, 11:13 AM | #4 | |
Rep 547
Drives: 335 I Coupe
335i, 6MT, montego blue, jade grey, grey poplar, anthracite headliner, style 230 rims, short shifter
11-29-2012, 10:49 PM | #5 |
Rep 1,290
I should have listened to this. my turbos went out at 33k. the ecu will try but it can't revive the dead :/
- Proven Power Tampa Built 6466 ST N54 6AT WR 711whp 637wtq -
11-29-2012, 10:51 PM | #6 |
Rep 6,136
11-29-2012, 10:53 PM | #7 |
Rep 1,290
why are yours whining or something ?
11-30-2012, 09:55 AM | #10 |
Rep 741
The most important part is to not drive hard before the oil temp has warmed up. Cool down is important too, but only if you've been driving very hard.... Remember, turbos are a wear item. You're only slowing the wear down by taking care of them.
I wet though 2 turbos on my old B5 A4 and am on my second set in the 335. If I keep the 335 long enough I would bet that it will get another set.
Jet black e92 6mt 335xi:
18" BBS RGRs, KW v1, ESS Stage 2 flash, VRSF 7" FMIC, VRSF downpipes, JG Mods m-tech front, mtec V3 AEs, BMS OCC, hardwired valentine 1, p3cars gauge, amber delete, sport seats, factory oil cooler. |
11-30-2012, 11:38 AM | #11 | |
Rep 53
Keep this in mind, "coking" of the center section/bearings is a concern of premature wear on turbos. This is the act of oil disintegrating and leaving carbon deposits on moving parts, therefore causing resistance and unbalance. This is caused by extreme heat and rapid temperature loss. You always battle heat issues with a 2 turbo set up. Ripping on your car before the oil is up to temp will cause a similar unbalancing effect due to the viscosity of the oil not being there to provide full protection. Change your oil frequently, warm your car up, and pseudo turbo time your travels to prolong turbo life. As for BMW's failsafe coolant run, I really can't see cycling the coolant after the car shuts off being that super beneficial to saving the turbos. It may help other aspects of the powertrain such as keeping rapid cooling down to a minimum(which is huge when combating warping and stress cracks) but it has very little to do with the major issue with turbo failure. If the oil continued to pump after the car shut off that would be a different story. Watercooled turbos are just designed to keep the center section temps down while running, it's just a heat exchanger. I can't stress enough that oil condition and temp are the winners for this issue.
Rocky
2007 335i Sedan 1991 Toyota Supra, 1JZ swap, T66 single, supporting mods. |
11-30-2012, 12:19 PM | #12 |
Rep 2,396
Drives: '08 E90 335i
If you're gonna rip on the car, def have a cool-down or cruise to where ever your destination is to let the turbos get back down to a normal operating temp (which is fine to just shut the car off).
If I'm ripping it on the highway home, I usually ease up a couple exits away so by the time I get home, I've done 5-10 mins of normal people driving. |
12-01-2012, 10:23 AM | #14 |
Rep 1,883
The only thing I ever did was make sure the oil temp was at least ~170 before going into full boost. Other than that, I got 60,000 miles of 18+ psi, hundreds of drag strip passes and my turbos had no whine and zero shaft play when I took them out.
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
12-05-2012, 12:21 PM | #15 | |
Rep 38
