My rear side passenger wheel came off...!!!!
11-19-2009, 02:38 PM | #1 |
Rep 1,798
Luckily I was driving slow or else I would be in deep trouble. I heard something rumbling when I was driving on the M25 and initially thought I had a flat. Pulled over after a while and checked, and could not see anything wrong.
Just 2 mins from home at the arnos grove roundabout; I heard a few loud bangs, and my rear passenger wheel literally came off!!! All the bolts were sheared off except one. I was flabbergasted to say the least. Luckily the only damage is the wheel hub which still holds the sheared bolts and the inside of the alloy wheel. Called BMW services; managed to put two bolts back on, and they will haul it to the nearest dealer. Had a similar issue before when BMW changed brake pads, and the cross scrwed the bolts and had to replace the hub/drum. Can I claim warranty in this case? Insurance? what are my options? Any BMW dealer guys in here? can you pls help?
11-19-2009, 03:00 PM | #2 |
Rep 7,519
Drives: 2009 E90 335i MT
I'd take it back to the place that last dealt with the wheel and have them pay the damages -- if possible.
2009 E90 335i Montego Blue · Black Leather · Burl Walnut · 6MT · US Spec
SatNav • ZPP • ZCW • 6FL • TPMS • iDrive • PDC • HWS • Xenons • BMW Assist • Power Rear Sunshade • Logic 7 European Taillights • Rear Foglamp • OEM Alarm • PicoTray • DataToys XM-DVR • Multi-view Processor Quaife ATB LSD • Short Shift Knob • Hartge Anti-Roll Bars • AP Racing Front Brakes • 19" Style 269 |
11-19-2009, 03:23 PM | #3 |
GTR'in it
169
Rep 4,434
What da fcuk?!
Unheard of for me with an M3 or any BMW! I'd take it to the last person that did anything to your car and raise hell on them Jerome. Is there any further damage bodywork, scratches etc? Last edited by SiKkBaSs; 11-19-2009 at 03:49 PM.. |
11-19-2009, 03:50 PM | #5 |
Rep 6,110
Drives: Don't know yet!
Jerome, were you running stock wheels (I doubt it), and were there any spacers involved.
I only mention it as it would be an easy out for a dealer (warranty), although it sounds ridiculous, i'm sure it might get mentioned. Insurance might be your best option if the dealer plays hard ball. As both Sunny & Floyd have said - who last worked on the car that would involve taking the wheels off, it sounds like they used one nut to secure the wheel, and forgot to fully tighten the other 4. |
11-19-2009, 04:21 PM | #6 |
Rep 7,953
Drives: Merc diesel
Garage List 2010 TTRS [9.00]
2007 Audi S5 [0.00] May 2007 Porsche 99 ... [0.00] March 2007 Porsche ... [0.00] Sep. 2007 E92 335d SE [0.00] July 2006 E90 330i ... [0.00] |
Could it be that the 4 bolts have been over tightened causing the threads to stretch and eventually sheer?
Either way it's not good and don't want to think about what could have happened tbh! I agree with the others, take it back to the last place that worked on the wheels if relevant. |
11-19-2009, 04:52 PM | #7 |
Rep 7,690
Drives: 335i SE Coupe Space Grey
bloody hell Jerome!...hope ur ok mate....actually, was gona call you last time when I first got my car back as i wanted to go for a lil drive ....
BMW is not in my top list atm../.. |
11-19-2009, 05:05 PM | #8 | |
Defected to the dark side.....
211
Rep 5,795
Drives: BMW M5 LCi
If no spacers were fitted, and the standard OEM BMW wheel bolts are (were!) in use, and BMW were the last people to remove the wheel then surely they must have a level of 'responsibility' - the problem is proving that the wheel has not been removed since. If it was say removed yesterday for a service and then fell off the following day, it is highly unlikely anyone had messed with it and more chance of a dealer playing ball. The fact your car is modded won't help as they will claim that other 'parties' obviously mess with it and likely that someone else is to blame. Anything to wriggle out of a claim is my guess Hope you get it sorted out matey and without too much expense & hassle !! |
11-21-2009, 04:16 AM | #10 |
Rep 258
you could also check as to whether the wheel studs are single use only (if they are made to stretch when torqued, re using the same stretched bolt may be a cause)
11-21-2009, 05:05 AM | #11 |
Rep 797
Drives: BMW 320d Le Mans Blue
Never heard of single use wheel bolts???? sounds like they either worked loose or were left loose. Sadly this happens more often than you think. Mechanics rarely use a torque wrench, most rely on the air gun.
11-21-2009, 05:18 AM | #12 |
Zummerzet Zyder Drinker!
112
Rep 5,541
Drives: '06 330D Le Mans Blue
Same here, never heard of single use wheel nuts/bolts!
I think the trouble here, unless work has very recently been carried out at said wheel location is PROVING that something had been left loose etc.... So when was anything done at that wheel location?
