McKinney catch can installed
11-22-2009, 06:52 PM | #1 |
Rep 2,314
I've finally had it with the RR oil catch can.. It leaked after I purchased it, I sealed and thread taped every single connection, and the oil worked it's way through and leaked again. Just poor connections & fitment imo.
I purchased the McKinney catch can after several positive reviews. The catch can was well packaged and arrived very quickly. I was VERY impressed with the quality of the product. McKinney used name brand fittings (Swagelok) and every connection was super tight. Here are a couple pictures of the install. I used the old connection pieces from the RR catch can and purchased longer hoses to run to the front of the engine bay. I mounted the can in the front so that it provides easy access for oil disposal. I clamped onto the radiator hose and let the bottom of the can rest on a couple cables beneath. My only question... Would there be any issues with how long my tubing is? About 4 feet each length. Thanks guys! |
11-22-2009, 09:08 PM | #2 |
Rep 2,558
Looks sweet... I don't think there should be a prob with those tubes that long... as long as there isn't any pooling of oil in the tubes...
what CAI are you running there?
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
11-23-2009, 07:53 AM | #5 |
Rep 2,314
He's correct, it's the UR CAI.
I used 2 worm clamps and interlinked them like a figure 8. I put one clamp over the factory radiator hose clamp (see on the last picture) and slipped the other clamp through it (it sits like a cup holder almost). I'm no engineer so it's hard to explain. Very simple and is a snug fit. It doesn't feel like there is any pressure/pulling on the radiator hose either as the can is slightly resting on cables beneath it. |
01-23-2010, 02:21 AM | #6 |
www.facebook.com/Synergy69
24
Rep 505
01-23-2010, 06:12 PM | #7 | |
Rep 2,314
I would definitely keep an eye on RSD's and also AR's - both should be good! |
01-23-2010, 06:37 PM | #8 |
Rep 198
looks great! I made one and mounted it in the same place.I made a bracket to mount the can to the same bolt as the P/S res.Here's a pic
Duncan |
01-25-2010, 11:27 AM | #10 |
24
Rep 505
How much did you buy your McKinney for?
Will the dealership give us crap for having a oil catch can installed? |
