changing spark plugs...does the click method work?
11-25-2009, 01:55 PM | #1 |
How you like them apples?
41
Rep 1,492
Drives: 335i
http://www.e90post.com/forums/showthread.php?t=142679
Long story short..does anybody know if screwing in the spark plug till is clicks works in place of buying a torque wrench 23NM for the N54 engines? I just my socket plug tool and don't have a torque wrench, just need to know if what others have suggested in the DIY guide about screwing in the spark plugs till it clicks work. Thanks!
V5 rev2.5 | VExhaust | V1 KW | V701 | H&R Sway Bars | Ram Air Scoops | DCI |
11-25-2009, 02:27 PM | #3 |
Rep 3,432
+1...pretty sure its cheaper to just get a nice torque wrench...and you don't want to overtighten spark plugs
11-25-2009, 05:00 PM | #4 |
41
Rep 1,492
Drives: 335i
right...where you guys looking for cheap ones? I was looking on the web at like NAPA auto parts and its like over ~$100
11-25-2009, 07:41 PM | #8 | |
297
Rep 4,408
I will say, I usually don't even use a tq wrench with spark plugs. After you've done it for quite some time, you develop a feel for it, and know when they are right. But if you don't have a lot of practice, I really don't recommend the touchy-feely method....
-Critter
11-25-2009, 07:53 PM | #9 |
Rep 1,048
This is the 3/8 torque wrench that I purchased and used for the spark plug install - About $100 from Amazon but well worth it.
SK 74104 3/8-Inch Drive 10-foot Pound to 100-foot Pound Micrometer Torque Wrench |
11-25-2009, 08:07 PM | #10 |
297
Rep 4,408
SK makes good tools for sure
-Critter
11-25-2009, 08:50 PM | #11 |
ahat
1046
Rep 2,592
They only need to be torqued to 17ft/lbs. Even the cheapest ones can pull that off without danger
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
11-25-2009, 09:01 PM | #12 |
297
Rep 4,408
I beg to differ. IMO they seem to be less accurate esp at low tq values.
-Critter
11-26-2009, 09:19 AM | #14 | |
Rep 1,404
I not advocating to buy Snap-on or Mac Tools, but Craftsman "like" tools are spot on. If not, send it your mechanic.
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
11-26-2009, 10:21 AM | #15 |
Rep 704
I thread the plug in by hand, then go an 8th turn with the wrench. Never had a single problem.
11-26-2009, 10:28 AM | #16 |
ahat
1046
Rep 2,592
They probably are not the most accurate, but they are not off more than 2 to 3 lbs based on my experience and that won't cause the plug to break or cause it to be too loose.
If you know how much resistance they had when they were removed (30seconds before), that should be pretty easy to return to that same force.. If you can't swag that you should not be under the hood. Torque settings where the fastener has some tension to ensure proper stretch is whats critical. Torque for plugs is more just so you don't break it off in the head.
11-27-2009, 06:39 PM | #18 |
41
Rep 1,492
Drives: 335i
thx for all the great info....I'm honestly thankful to have access to this forum and fellow proud BMW owners willing to share advice...seriously! thanks a lot!
okay now no more mushy stuff
