Welded LSD question
11-27-2009, 09:24 AM | #1 |
Rep 8
Welded LSD question
I have a welded diff on my 08 e92. I was wandering could I buy a bolted diff from a totaled e92 or e90 320d, 325d, 330d swap the cassette and put the bolted unit with lsd in my car. Thanks
11-27-2009, 09:30 AM | #2 | |
Rep 5,493
Also, by the time you've bought the replacement differential, assuming it's ok that is, you might as well have bought the welded swap out from Birds in the first place!
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
11-27-2009, 09:42 AM | #3 |
Rep 8
Thanks Tony. I know that is my best choice however since I am not local it involves high shipping charges and than shipping my diff back to birds. (total around 400 pounds) If I find a bolted diff here how can I found out if it will do the job. Thanks
11-27-2009, 09:49 AM | #4 | |
Rep 5,493
Are you sure it costs that much to ship?!
11-27-2009, 12:14 PM | #5 |
Rep 5,493
I did a bit of info digging for you, based on the VIN number of your car
a) your car uses a welded 188L-style differential with a 2.35:1 final drive ratio b) your car also uses the latest style 3-bolt flange for the connection between the prop shaft (input shaft) to the differential. This 3-bolt mounting came into use when the diffs changed from bolted to welded construction. Earlier bolted diffs used a nut-type connection for the prop shaft The problem you have is that you need an early bolted 188L 2.35:1 differential that uses the 3-bolt flange - this is basically impossible to find as this configuration doesn't exist as far as we can find out If you want to continue down the breakers' solution, then you need to find a differential off a 2006 manual 325d or 330d which has a 2.35:1 final drive - there should be a sticker in the top of the diff unit which tells you what ratio it is. You will also need to buy the prop shaft (main input shaft) off that exact same car too. Alternatively, buy an assembled version from Birds and exchange yours in return.
