New dyno results! Procede Stage 3...
11-30-2009, 09:20 PM | #1 |
Rep 919
Well my misfire issues seem to have corrected them self with the latest 11-2 maps..
Manual 335i Procede CanBus Stage 3 AR Design Catless DP's Vishnu DCI UUC RSC335 axle-back "stock midpipes/cats" AA Intercooler 93 Octane Run Conditions: 84.40 F, 33% Humidity, STD 1.01 Run 1: UT 82%, IC 75% Run 2: UT 80%, IC 80% Run 3: UT 83%, IC 65% (Anyone else find it strange that this runs makes peak power at 6,150rpms?) Last edited by Malaka1; 12-01-2009 at 12:37 PM.. |
12-01-2009, 01:47 AM | #6 |
Rep 7,377
what is your stock run so we can see the delta?
12-01-2009, 04:56 AM | #7 |
Rep 5,175
Numbers are worthless without a baseline. Not to sound harsh, but some people are dynoing at 280 rwhp stock and others realistically at 250-260 rwhp, so we can tell nothing about your car without the baseline.
12-01-2009, 07:35 AM | #8 |
Rep 565
Happy to see you making the power now. Are you still getting those strange codes?
08 E90 335i AT RB Turbos -NX Wet Kit - Chiplogic Flash or Procede V5- M3 Diff - AE Exhaust- Forge Dv's - Helix Intercooler - AR DP's - P3 Boost Gauge - Vishnu Meth- Stett Chargepipe and CAI
09 C63 |
12-01-2009, 10:14 AM | #11 | |
Rep 919
-I did a valet mode ruin on this dyno before the AA Intercooler was installed and made 290.56rwhp and 299.79wtq.. *with dp's, DCI, and axle-back in.. -It is weird, most people have higher torque than horsepower...I was expecting over 400wtq being that the hp was 394.. |
12-01-2009, 10:24 AM | #12 | |
Rep 5,175
12-01-2009, 10:33 AM | #13 |
Team Zissou
3084
Rep 10,198
he made a "valet run" but still had all his mods except the FMIC. So stock it would have been a bit lower.
those secondary cats are holding you back, get rid of them! |
12-01-2009, 10:34 AM | #14 |
Rep 763
really just a tune adding 100whp?!?!!? that is amazing no? i mean yes those other mods will benifet more with a tune then with the stock setup but still that is very impressive, im assuming a dynojet? (is it true that those read really high)
12-01-2009, 10:36 AM | #15 |
Rep 5,175
Axle back should be worth next to nothing and the DPs are still only about 5-8 rwhp with no tune. DCI's won't gain hp either on 7 psi. Maybe 110 rwhp?
12-01-2009, 10:37 AM | #16 |
Rep 5,175
Bolt-on mods will give exponentially more power as you increase the boost.
12-01-2009, 10:44 AM | #17 |
Team Zissou
3084
Rep 10,198
not saying you're wrong in any way, just making sure no details are left out. Either way we're just guessing with no real baseline..
12-01-2009, 10:45 AM | #18 |
Rep 7,377
I gained 22 rwhp fully modded on stock map. 250 Stock and 272 stage 3 mods stock map.
On pump gas and stock turbos you are maxed out with a 100-120 rwhp delta
12-01-2009, 10:51 AM | #19 |
Rep 5,175
12-01-2009, 10:52 AM | #20 |
Rep 5,175
You and I are on the same page when it comes to baselines. I am glad the community is working toward establish this as a need, not an option.
12-01-2009, 10:58 AM | #21 |
Rep 7,377
now we only need to establish soon a new baseline of power with upgraded turbos and meth :-)
