jb3 question
12-02-2009, 02:08 AM | #1 |
Rep 57
jb3 question
just got this installed , and I absolutely love it!
question: when taking it in to dealer for service, how many of you are just deactivating it with the pedal selection method to MAP 0, and leaving the hardware in? Will the car throw no codes? When in MAP 0, is the only way the stealer would know about a tune is if they checked the ecu? Thanks- |
12-02-2009, 02:19 AM | #2 |
Rep 7,377
REMOVE IT completely from ECU box if you care about your warranty.
12-02-2009, 03:13 AM | #3 |
Rep 2,485
Map 0 is a pass though map so the JB3 becomes invisible.
If you are taking it in for warranty work, remove it and check for any tuner codes with a BT tool. If you are just going in for an oil change, clear any codes and set ot map 0.
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
