AEM Meth Kit and JB3 Help!
12-02-2009, 09:19 PM | #1 |
Rep 783
Hey Everyone,
My friend is currently at AutoTalent with his 09 e92 335i and needs some help. They are finishing up installing the AEM meth kit and my friend had a few questions. What map should be run with meth on? How much boost? Is there any specific map for the two to work together? Any help would be greatly appreciated. Thanks, ~D
2021 M3 6MT Brooklyn Grey/Silverstone
Previous: 2009 335i ZMP 2013 M3 6MT ZCP Space Grey/Fox Red |
12-02-2009, 09:21 PM | #2 |
SUPERMAN
121
Rep 3,171
first off why would you get a aem meth kit?
the pump is only 150 psi
MODS: JB3 18ohm | AR Design Catlles Downpipes | CDV Delete | Clutch Masters FX400 | ZEX Nitrous Kit | Devils Own Methonal Kit | VMR V701 (Matte Black) | H&r Race Springs| BMW Perf Grilles|
12-02-2009, 09:37 PM | #3 |
Joint Chiefs of Staff
4927
Rep 116,037
You should get in touch with BMS to figure out how the safety will work, etc. Most use map 7 though, grab the BT and do some logs!
Mike |
12-02-2009, 10:13 PM | #4 |
اوليسيس
198
Rep 4,678
very surprising Autotalent would have no insight in this, unless he is just anxious and jumping the gun a little bit.
12-03-2009, 12:28 AM | #5 |
Rep 7,377
map 7 to play it safe in case you run out of it. map 8/9 for the big power. Check with BMS/Terry for failsafe as Mike said.
12-03-2009, 02:02 AM | #6 |
829
Rep 3,982
Map #7 was my daily driver on straight 91 octane. With meth, it pulls very strong, with the same, or less boost! Map #9 also works good. I have used up to map#11 with good results on meth+91. On map #7 I am hitting traps of 118 mph or so. On map #10-11, I am hitting 119-120mph with a mix of higher octane.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) Last edited by hotrod182; 12-03-2009 at 08:19 AM.. |
12-03-2009, 02:22 AM | #7 |
Rep 3,334
I run map9 daily on 93+meth.
Mods list got too long, lets just say more than enough.
