Manual Tranny/Start Procedure
08-15-2005, 06:02 PM | #1 |
MAUI BUILT
488
Rep 7,781
Drives: 2006 330i MT
Hi all, I was wondering if you pressed the start button first w/o the clutch to get to the accessory mode and then depress the clutch to start, or just bypass the accessory mode by depressing the clutch first to start the car. I used to just start the car, now I'm doing it the long way for fear of damaging something(I don't know what, but worried anyways). Waste of time?
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
08-16-2005, 01:30 AM | #2 |
MAUI BUILT
488
Rep 7,781
Anyone? ^^^
Danny
08-16-2005, 01:34 AM | #3 |
Rep 524
I'm not sure I understand your question. Just inserting the fob turns everything on (except the darned sunroof) ...is this what you mean by accessory mode?
Realtor Mobile: 6spd / Sport / Prem / Navi / ED 3-30-06 73 3.0s/84 528e/90 525i/97 M3 4dr/99 M3 Conv/2001 330i/2004 545i ED/2006 330i ED June 05 You're in control...is there anywhere you want to go ? ------------------------- |
08-16-2005, 01:55 AM | #4 |
MAUI BUILT
488
Rep 7,781
I'm sorry, I didn't mean accesory. You know in a regular car with a key, one turn and you get power(accessory), the next turn gets you all the check engine lights(that's the mode I'm talking about) and the final turn starts the engine. Sorry for the confusion!
Danny
08-16-2005, 02:40 AM | #5 |
Rep 72
i clime in the car put the key in, press the clutch, push the start button. That the way the dealer showed me. i only use your way when i whant to play just the radio witout the ignition being on.
08-16-2005, 09:17 AM | #7 |
Rep 6,158
ok, this is simple,
when you insert the key you get accesory mode, when you push the start button once you get the "ON" mode where sunroof, fan, everything works when you push it again, it shuts off |
08-16-2005, 12:33 PM | #8 | |
Rep 17
My understanding of the manual is that you normally donīt pass this ignition mode, but you can do it if you like. When you insert the fob, my radio starts and that is what I would call accessory mode. |
08-16-2005, 02:49 PM | #9 | |
Rep 6,158
08-16-2005, 03:46 PM | #10 |
Rep 145
relax, you have a nack for missing the whole point in every thread you touch.
HRC, your long way might just be the safest way, thats when the cars knows and is going to be ready to have the engine started, like the fuel pump priming, arming the ignition, etc. I just dont know if damages the engine by just hasting. |
08-16-2005, 03:56 PM | #11 | |
MAUI BUILT
488
Rep 7,781
Thank you very much for your help! I agree with you, and will continue to go the "long" way Thanks Again! Danny
08-16-2005, 04:30 PM | #12 |
Rep 6,158
you'd be just fine if you
insert key push clutch hit the button what you've been doing is equivalent to turning the key to the ON position letting it sit for a second and then turning the key the rest of the way. No one starts a car like that, they just turn the key. Just put your foot down and hit the button, you won't hurt anything |
08-16-2005, 04:52 PM | #13 |
Rep 524
Ward....I didn't know that I could hit the Start button after the fob insert to get the sunroof to work...that was bugging me because the windows work as soon as the fob is in....weird......yeah...more things light up when you hit start but before engine start....coolio.
08-16-2005, 05:13 PM | #14 |
Rep 145
I know all mechanics of jets, turbo props planes, piston planes, carb cars, f.i. cars, and f.i. motorcycles.
With the exception of turbine power, all above warrants priming of some sort. Easy example is a modern Honda sportbike with fuel injection. Honda warrants to wait for the sound of the in-tank fuel to prime, shuts off, and the "FI" annunciator extinguished. Takes about 2sec. My friend does this same method on his A4 Ultrasport, but he is a little anal most of the time about his car! |
