Comfort Access & Running Tips...
12-30-2009, 02:10 PM | #1 |
Rep 55
Question:
What do people do with their fairly large key when running? Do you carry it, or put it somewhere? For instance - I go to a park or track (or some other place where I don't have access to a locker at the time), and go for a run or other workout. I don't want to carry my key with me while working out, but I also don't want to leave it with the car (as I would have done in the past on a tire or something) since then the car could be easily opened. Any thoughts or tips? Cheers! Chris
______________________________________
Christopher M. Whelan MAJ, U.S. Army |
12-30-2009, 02:19 PM | #2 |
Rep 1,730
If you can get a arm band kind of bag you can place it in there. This is what i do or I place it in a pair of shorts/pants with a zip-up pocket.
My last suggestion would be to wear some spandex tights/shorts under your running gear, put your key in a small plastic bag and then put the key in the spandex tights on your leg or something. All 3 have worked for me since I have comfort access as well.
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
12-30-2009, 02:30 PM | #4 |
Rep 1,190
zip up pocket
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
12-30-2009, 02:51 PM | #5 |
Rep 55
All good suggestions. Let me throw a wrench in the works.
I am in the Army, and, on occasion, do physical training with the unit to which I am assigned. Usually 2-3 times a week. When I do, I must wear the authorized PT uniform. Summer PT uniform is shorts with no pockets (well, a very small pocket that will hold the flat ID card, and that's about it. Can't carry ipod, and probably ought not carry keys in hand... Spandex might work, though I don't like to wear spandex. Winter is no problem since the jacket has zip up pockets. Thanks for advice thus far... Cheers! Chris
12-30-2009, 03:06 PM | #6 |
Rep 303
On a lanyard like dog tags? Tied to your shoe?
ElRedOne
330 xi Electric Red/Beige Step-Premium-Sport-CW-CA-PDC-Shade Z4MR Interlagos/Black |
12-30-2009, 03:18 PM | #7 |
Rep 2
CA & Running Tips
I'm also a runner and this is what I do.
I've deliberately arranged my FOB so all my keys are attached to the side with the removable key. I then separate the FOB (similar to what you would do when you valet park) and place my keys out of view (glovebox, center console, etc). I retain my FOB (oblong part) place it in my socks, exit the car and and then lock it up (finger on ridges). My FOB never moves around in my socks,even on long runs. When finished, I return to car, open door, reassemble keys and off I go. Works for me. Thanks, Donna |
12-30-2009, 03:36 PM | #9 |
Rep 141
I run a lot and had the same thoughts. I have my key fob on it's own ring that attaches to the my main ring with all the keys. When I run I just detach the key fob from the main ring and stick it in my pocket. I don't even notice it's there. I run with baggy gym shorts so it might be an issue if you wear tight shorts.
On a side note. What do people here do after working out so you don't get your seats wet with sweat? I have a large beach towel to cover the leather. I cut a hole on one side of the towel to hook over the headrest so the towel won't slide down while I drive. It looks a little getto but I don't give a sh!t, my seats stay clean and dry. |
12-30-2009, 03:36 PM | #10 |
Rep 679
Hmm..I was in the navy, our newer pt uniform(should still be the same bright yellow crap now)..anyways the little pocket that your talking about, is where i had my key fob. I'm assuming it's the one thats sorta hidden on the inside of the shorts right? Anyways i don't carry keys with my fob, so i just keep it there. Otherwise, I've seen people stick the ID in the sock, maybe you can put the fob there? Dunno about smell and sweaty fob tho
12-30-2009, 03:50 PM | #11 |
Rep 55
Cosmop,
For the seats I did purchase the BMW seat covers. They slide on and off pretty easily. That way I can put them on when I need to (on really sweaty/muddy/rainy days). Good key info. I'll try a few and keep y'all posted! Cheers! Chris
12-30-2009, 04:07 PM | #12 | |
Rep 679
12-30-2009, 04:26 PM | #13 |
Rep 1,109
buy running shorts with a hidden pocket inside the waist band. almost made specifically for the bmw fob
2007 328i Crimson Red *SOLD*
2010 335i MSport AW E92 |
12-30-2009, 04:39 PM | #14 |
Rep 679
military is really picky about colors and style. They make you buy "official" products that aren't worth the price, but since it's required you don't really have a choice..mine cost like 15-20$ and bad fitting, and style is from like the 80's
12-30-2009, 05:05 PM | #15 | |
Rep 950
12-31-2009, 12:45 PM | #16 |
That tickles
11
Rep 457
Remove the metal key from the fob, leave the fob in the car and lock the car using the metal key. If I'm not mistaken, the car will not open using the CA feature even though the fob is inside the car. Now you only have to carry the small metal key.
12-31-2009, 03:35 PM | #17 |
Rep 6,139
In the sock idea works for me.
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
12-31-2009, 10:31 PM | #18 |
Rep 779
then tape the small key to your penis
