BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos MHP S2 C63 Burnout Vid, New Dynos with Race Catback
      12-30-2009, 05:24 PM   #1
MHP
MHP's Avatar
43
Drives: MHP S2 C63, MHP S1 997 911 GT3
For those interested in what the C63 guys are up to:
Our S2 car (93 octane):
SAE: 477/442rw
Actual: 501/464w
Keith's S3 car (93 octane):
SAE: 488/448rw
Actual: 520/478rw
3" Catback:
S2 Burnout:
      12-30-2009, 09:58 PM   #2
ACZakka325i
ACZakka325i's Avatar
286
Drives: 2 stroke
Sick numbers. Is that just with free-flow exhaust and chip? Maybe pulleys too?
I feel bad for those tires.
(Waitlist): #1 M2CSL
(Current): 2016 F15 X5 3.5xdrive - 2010 997.2 C4S Coupe
(Past): 2016 F30 340xi M-Sport -2013 535i xdrive
2008 E92 M3 - 2006 E90 325i
2002 E46 325xi - 1991 E30 325i
      12-30-2009, 10:56 PM   #3
MHP
MHP's Avatar
43
Thanks. I was actually in the parking lot of Discount Tire, was there for new meats anyway. Figured I'd make the most of what was left. The customers seemed to enjoy it, but my HVAC still blows rubber smoke LOL.
First set of graphs are from our S2 car: LTs/Mids, Catback, Tuning, Airbox/Filters, Thermostat.
Second set has our race ported heads in addition to the above.
The first three cammed 63s will be running around in a few weeks. Goal is 540rw+ SAE N/A. Stock cams only have around 200 degrees of duration @ .050, basically on par with a Ford Modular 4.6L cam. Which is probably the only way AMG got this motor to pass emissions. They also have zero overlap so we're really not even taking advantage of the LTs yet.
Then we stroke, re-cam and re-port.
Fun stuff.
      12-31-2009, 01:16 AM   #4
1BMW4fun
Drives: 12 X3 2.8, 11 550
The C63 does not have those cool looking diff fins anymore like on the E55/63 or the C55? Nice hp figure for just NA setup.
      12-31-2009, 05:02 AM   #5
MHP
MHP's Avatar
43
It has them, they aren't pretty (look like cheap plastic) but someone I think Euroteck makes a nice CF version.
Thanks!
      12-31-2009, 12:01 PM   #6
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
I plan on picking a C63 up come spring and will of course be seeking a tune. Guess my new forum name will be Tuned63. lol
Crazy numbers btw.
      12-31-2009, 03:06 PM   #7
MHP
MHP's Avatar
43
Crazy numbers btw.
Cool, are you going with the P31 package?
Thanks!
      12-31-2009, 03:54 PM   #8
MTV
Drives: E60 M5, Volvo S60R
Those are some impressive numbers. Cams and pulleys and you'll see a nice gain
      12-31-2009, 10:40 PM   #9
1BMW4fun
Thanks!
No I meant those fins hanging right below the differential.
      01-01-2010, 04:23 AM   #10
MHP
MHP's Avatar
43
Correct, gains with cams will be huge, the stock cams are meant for a lawnmower. We're expecting 540-560rw SAE with H/C + S2. Goal for the 7.0L is 600rw SAE on pump gas.
We don't believe in UD pulleys. Crank dampers are meant to quell internal harmonics, and a 6.2L v8 revving to 7500rpm (post H/C) will need every bit of a 6.62" shell dia to safely eliminate all 3rd order harmonics. V8s have more 3rd order vibration than V6s, V10s, V12s.
Long story short, a damper is not a place to make power, it's cheap insurance for a $40K bottom end. All our dampers are made by ATI and are SAE certified for use up to 750HP/7500rpm. They may not make power, but they don't lose any despite the larger shell due to the complete elimination of crank flex.
Ah my bad. You are correct, cheap stuff. Nothing like my M5.
Thanks!h
      01-01-2010, 09:19 PM   #11
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
Thanks!
I'll more than likely pick up a used '09.
      01-01-2010, 09:31 PM   #12
PLAY
Drives: AWE92N54
Nicely done. I always love a classy C63.
      01-04-2010, 03:31 AM   #13
MHP
MHP's Avatar
43
I would do the same especially since the ~30hp gain apparently now comes from the tune alone vs a forged M159 bottom end as well. Skip the Vmax limiter but get the LSD, we can eliminate Vmax with a tune.
Thank you sir!
