Besides turbo, what makes e92 engine different from e90?
10-23-2006, 09:47 AM | #1 |
I love the ///M3, but I want 550hp ///M5
141
Rep 3,276
Drives: BMW330iE90
I know its got the bi-turbo and split-dual exhaust... but what else makes the two different from each other. WHat does the e92 have that e90 doesnt? and how can I.. a 330i, get the near close performance as that e92??
e90 e92 255hp vs 300hp 220ft/lb torque 300ft/lb torque what else??? i think if i got atleast 270lb/ft of torque ill be good.. |
10-23-2006, 10:26 AM | #3 |
Rep 2
twin turbo, the placement of the fuel injectors, just a totally different engine overall! i believe next year the sedans will be housing the new 335 engines. your only bet to getting more power would be either ecu upgrade or forced induction. the coupe itself can not be compared to the sedan simply because they are not the same, there was an article in a mag that said not one body panel is similar to the coupe so its not just the engine, its everything from suspension to materials
10-23-2006, 11:06 AM | #4 |
Rep 5,732
The engine block is aluminium rather than magnesium casing, due to the increased strength requirement of the high compression (turbo).
Not a new engine per se, since it uses the same basic components; it is a derivative of the N52 engine, adapted for turbo and DI. |
10-23-2006, 11:38 AM | #5 |
United States Marine
319
Rep 2,748
actually... it's a new engine.
Different block design and material, no valvetronic, direct injection with piezo-electric fuel injectors running almost 3000 psi... it's the N54. a new, different engine than the N52. if it was just modified, it would have a different designation, like when vanos was first added to the M52, it became the M52TU. We don't use TU anymore, but it would be something like N52V2HO. but it's not. It's N54. Matt |
10-23-2006, 11:56 AM | #6 | |
pull my finger to get your kinder® surprise
148
Rep 10,455
335 sedans are out on the street already
10-23-2006, 12:46 PM | #7 | |
11
Rep 141
Drives: 330i Touring
PLEASE everyone, stop referring to the 335i engine as "E92". It's just WRONG! [Steps off soap box] (And yes, I know 335i isn't the real engine name. But it sure beats calling it E92!) |
10-23-2006, 01:12 PM | #8 |
Rep 29,202
The 335i engine are the same in both the e90 and e92.
But here in Europe the 330i engine is not the same, in e90 and e91 it has 258hp, but in the e92 it has 272hp.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
10-23-2006, 01:24 PM | #9 | |
Rep 1,032
Drives: 2006 330i & 2010 535i
2006 330i Jet Black w/ Beige Leather/Sport/Prem/Step/Shades/Xenon/Logic 7 |
10-23-2006, 02:53 PM | #11 | |
11
Rep 141
Here are some of the engine options available for each model: E90: 316i, 318i, 318d, 320i, 320si, 320d, 323i, 325i, 330i, 330d, 335i, 335d E91: 320i, 320d, 323i, 325i, 330i, 330d, 335i, 335d E92: 325i, 330i, 330d, 335i, 335d ...and this is not even a complete list. Now do you understand why it's a bad idea to talk about "the E92 engine"? |
10-23-2006, 03:12 PM | #12 |
Rep 29,202
OK, here's the different e90, e91 and e92 options in Norway and in most of Europe, beside the 316i and 320d LE (150hp insteed of 163hp, less tax with 150hp)
11-07-2006, 04:18 PM | #13 | |
S0THPAW
8731
Rep 7,847
http://www.caranddriver.com/reviews/3223/bmw-330i.html "The most obvious difference between the base 330i and 328i is the additional $590 that buys you six 496.5cc cylinders instead of six 465.5cc cylinders. The blip in displacement is courtesy of a stroke increase of 5.6 millimeters to 89.6mm." 84mm x 89.6mm is the 335i bore x stroke per cylinder.... Can someone inform me if that is the same 'old' E46 3 litre engine, but now with direct injection and 2 turbos etc? I recall reading it's the 'same' in its base specs. ???? Last edited by Robin_NL; 11-07-2006 at 05:05 PM.. |
11-07-2006, 08:54 PM | #14 | |
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
11-07-2006, 08:56 PM | #15 | |
Rep 17,767
11-08-2006, 03:00 AM | #17 | |
S0THPAW
8731
Rep 7,847
11-12-2006, 04:39 PM | #18 | |
Rep 3,618
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone 2010 Mercedes-Benz C350 4Matic - Gone 2006 BMW 330xi - Gone 2001 Infiniti QX4 - Gone |
11-18-2006, 05:00 AM | #19 | |
Rep 407
I don't see it on bmw.com |
11-18-2006, 09:25 AM | #20 | |
Rep 29,202
We got it here in Norway, and I think in Greece and Portugal Its a 1.6 liter with 115 HP.
