Adding 10" W6 to 335 Sedan
01-26-2010, 05:29 PM | #1 |
Rep 74
Hey Guys,
I'm in the process of getting my 335i sedan, and I want to start planning out my audio setup. I had two 12" W3's in my WRX, powered by a JL 500.1 but I recently sold those subs and got a 10" W6 from a friend of mine. I want to add this to the 335 if it isn't going to take up a ton of room... Does anyone make a corner box? Is the 500.1 going to put out too much power for that sub? Anyone have any pictures of their 10" sub installed in a sedan? Thanks, Mike |
01-26-2010, 11:46 PM | #2 |
Guest
36
Rep 611
I think that the 500/1 will be good for a JL 10W3V3. Too much power is not really a problem. Underpowering is generally worse.
2006 Black BMW 330i, Black interior, ZSP, ZPP, Logic 7, Xenon, Ipod, Satellite Radio Preparation, Moonroof, 12'' 2 P2 subwoofers running on KAC-7204 amplifier, Hardwired Escort Passport 8500, Hardwired Garmin Nuvi 650 on Kuda Mount.
tutor,math tutoring,math tutoring,test prep,tutoring jobs,tutoring blog |
01-27-2010, 11:35 PM | #3 |
Rep 7,089
Drives: '06 AW 330xi
You have to go custom for an enclosure on the side...as for the amp, you'll be fine. Just make sure you adjust the gains properly.
01-28-2010, 01:30 AM | #6 | |
Guest
36
Rep 611
I would go for three 10W3V3s.
tutor,math tutoring,math tutoring,test prep,tutoring jobs,tutoring blog Last edited by amlebede; 01-28-2010 at 04:10 PM.. |
01-28-2010, 05:17 PM | #7 |
Rep 13,023
01-28-2010, 05:18 PM | #8 |
Hates Speed Limits
113
Rep 2,589
01-30-2010, 10:17 AM | #9 |
Rep 13,023
VP Electricity's test enclosure with ID10D4V.3 sub...
Details still are being worked out (i.e. carpet color), but sound and integrated-wise this is it. The bass comes loud and clear thru the rear seats bulkhead (no folding rear seats) without being either muffled or overbearing if tuned right; no remote bass volume is used in my system and only half of the max 250W RMS is input. This is the missing sub bass that the SWS-8 tries to replicate but it just can't by nature. However, by adjusting the SWS-8 more towards the midbass they deliver it tight after this ID10 installation. Perhaps is the capabiliy of my bit one processor to better adjust what the user wants to do but the SWS-8 can deliver strong mid bass. Maybe it will not be as accurate as other dedicated midbass drivers but it really does it quite convincing. As the trunk space occupied well, see the photos. Low profile, trunk remains usefull, even OEM. The enclosure does not bolt into anything, either snaps tight into that space or tighter with velcro strips in the backside grabbing the trunk carpet side trim. |
01-30-2010, 11:50 AM | #11 | |
Rep 3,201
Glad to finally get corroboration that this thing works through the seat in E90
01-30-2010, 11:56 AM | #13 |
Rep 3,201
We are working out the tooling costs - this one was handmade, but we will be making them in a tool at a pro glass factory. Don't want to take this one into the ditch, so I will most the info soon in a new thread.
One kink is, I don't know that a W6 is gonna fit. What depth is it? |
08-05-2010, 05:37 PM | #15 |
Rep 18,123
Nice install! Reading later.
Current: 2010 Alpine White 335D LCI l 19" BBS LMs l KW V2 Coilovers l BMW Performance Grilles l MSport Front/Rear l Karbonwerke Trunk l F1 Pinnacle Tint 35% Former: E92 Space Grey 335i Latest pics |
08-05-2010, 09:55 PM | #16 |
Rep 18,123
How easy is this to pull off when you need to access your battery? You using a lot of slack underneath with banana clips?
08-08-2010, 01:37 AM | #17 |
Rep 44
I had my custom box built by TPLSM3 over on the 1 series addicts forum. Still waiting for it to arrive, but it's a corner box, so I still have access to my entire trunk.
08-08-2010, 11:34 AM | #18 |
Rep 3,201
08-08-2010, 11:56 AM | #19 |
it's all about the sound
Rep 29
W6 vs TW5
I was considering getting the JL StealthBox for the 3-Series sedans until yesterday when I listened to a demo box of the 13TW5 subs. They didn't sound as fluid as the 10W6.
A friend of mine just put a 10W6 powered by a 500/1 in his 135i conv, and it sounds great. Since this thread was started at the beginning of this year, can I assume that you've got your 10W6 and 500/1 installed in your sedan? How is the sound? I may end up doing something very similar. |
08-09-2010, 08:40 AM | #21 |
Rep 29
Great! I already have a JL Audio 300/2 that I could use to power the 10W6. Will that be enough? or do I need to upgrade to a XD600/1 or HD750/1?
