Reliability - 335
View Poll Results: Has stuff broken on your 335? | |||
Yes, por build quality | 32 | 29.91% | |
No | 69 | 64.49% | |
Yes, my fault | 3 | 2.80% | |
No, But with the mods I've got on it should've | 3 | 2.80% | |
Voters: 107. You may not vote on this poll |
01-27-2010, 04:44 AM | #1 |
Rep 549
Reliability - 335
A clients car broke down the other week. It's at the dealer getting sorted out so no clues as to what it was, yet.
Having seen info on this forum about stuff that breaks in these cars I thought we go ahead and make a "highly scientific" poll about this subject. I guess it's up to each and everyone how you would like to classify stuff breaking, but it would be nice not to include wear&tear, like turbo-changes when you've gone stage 3 during 60000 miles. More stuff like that shouldn't have broken, like HPFP's. |
01-27-2010, 07:11 AM | #4 |
Rep 6,140
Still going strong! (knock on wood!)
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
01-27-2010, 08:45 AM | #7 |
Rep 2,558
new turbos' installed to fix wastegate rattling in mine at around 20k miles
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
01-27-2010, 08:46 AM | #8 |
Rep 402
43k and the only thing ever wrong with one HPFP replaced. Take care of the car and it'll take care of you. I've purchased extended warranty through BMW and have nothing to worry about with the car. If it breaks, it gets fixed for $50.
01-27-2010, 11:27 AM | #10 |
Rep 95
01-27-2010, 12:12 PM | #12 | |
Dismembered Member
3613
Rep 9,213
Dunno about the $50. But I know that is the smartest move to make after 50K.
My delivery experience and beach photoshoot here. |
01-27-2010, 01:40 PM | #14 |
Rep 1,922
Drives: E90 335i, E70 X5
34.5k miles, so far my car's been in for fixes are the fuel system, 1 time HPFP (service history showed previous owner had 1 HPFP recalled @ 18k miles so total of 2 new HPFPs so far), 1 time software reprogram due to SIB (limp mode, misfiring codes), 1 time towed in due to ALL failed injectors (which is 1000 miles after HPFP).... other than the fuel system related, nothing goes wrong yet.... knock on wood..
-eric
E90 335i TiAg *STOCK* see my garage for mod list.. E70 X5 SGM *try to stay stock* :/ |
01-27-2010, 02:24 PM | #15 |
Rep 402
Re-read, thanks. $50. Have to decide if Extended Maintenance is worth another $2k-3k. Definitely wouldnt want to own the car without warranty. Parts are overpriced, not to mention labor.
01-27-2010, 02:37 PM | #16 | |
Rep 95
Maintenance; engine, transmission, and body adjustments; wheel alignment, balancing or rotation; wiper blade inserts; engine drive belts; spark plugs; filters; fuses; all batteries; all hoses and clamps (except air conditioning and power steering); oils, lubricants, fluids, refrigerants and coolants (except as required in the course of a covered repair); brake pads and rotors; brake shoes and drums; manual transmission clutch assemblies; suspension dampers (shock absorbers/strut elements); exhaust systems; tires. Paint; glass; headlamps; bulbs (except instrumentation); mirrors; lenses; body and chassis; body seals and gaskets; interior and exterior trim, moldings, and fasteners; upholstery, headliner, carpeting, floor and trunk mats; convertible top (all components except electronics); air or water leaks; wind or body noises; wheels; damage due to rust, corrosion, or contamination, except as covered by the BMW New Vehicle Rust and Corrosion Perforation Warranty. or wear and tear, good luck with that $50. |
01-27-2010, 02:46 PM | #17 |
Rep 549
Yep, poor is poorly written....can't find anywhere to edit the poll. Maybe you can't since there's no sense having a poll if you go changing stuff at a later date.
01-27-2010, 02:57 PM | #18 | |
Rep 402
01-27-2010, 03:06 PM | #19 | |
Rep 95
Just adding the Extended Warranty (not Maintenance) to the list of reason why getting into this car was a regrettable decision, and dislike the snarky-ness of the board when I'm really just trying to share information, not start fights. If I misread your comments, my apologies. |
