Having some misfiring this evening...
01-27-2010, 08:01 PM | #1 |
Rep 424
At full throttle tonight, it felt like my both tires were spinning. A couple of moments later I noticed the "service engine soon" light on - and the car got very rough. The higher the idle, the rougher it got. Under smooth acceleration, it was hardly noticeable. After a few minutes, the light went off and everything went back to normal. Upon full throttle acceleration, it happened again. I turned the car off to go where I needed to be and on the way back out, started it up and everything was fine. Of course, under full throttle, it happened again.
So... I used the Bavarian Technic cable and it came up with the following. Any thoughts? Thanks in advance... 29D1: Misfirings, cylinder 5 Error will cause a warning light Error is not currently present Test conditions have been completed Short circuit or signal interruption Freeze Frame Information Event 1 Odometer 65400kms 40637miles Engine temperature 93.75 °C load value for misfire detection 89.06 % Engine speed 5,408.00 rpm Lambda integrator group 2 18.75 % Event 2 Odometer 65512kms 40707miles Engine temperature 91.50 °C load value for misfire detection 90.23 % Engine speed 4,704.00 rpm Lambda integrator group 2 17.97 % Event 3 Odometer 65520kms 40712miles Engine temperature 94.50 °C load value for misfire detection 94.14 % Engine speed 4,960.00 rpm Lambda integrator group 2 30.47 % 29D9: Misfirings in case of tank filling level too low Error will not cause a warning light Error is not currently present Test conditions have been completed Signal or value below threshold Freeze Frame Information Event 1 Odometer 65400kms 40637miles rail pressure 100,530.31 hPa counter recognition bad road 0.00 - ambient pressure 997.66 hPa fuel tank filling level 6.00 l MSD80/MSD81 Engine module for N54
Sal Collaziano
Stinger Forum |
01-27-2010, 08:02 PM | #2 |
1750
Rep 17,960
Drives: A Lot
Was your tank low on gas?
01-27-2010, 08:18 PM | #3 |
Rep 424
Quarter of a tank.. Exactly. Should be okay...
Sal Collaziano
Stinger Forum |
01-28-2010, 12:47 AM | #4 |
Rep 7,377
pump? spark plugs? Injectors?
01-28-2010, 01:00 AM | #5 |
Rep 1,884
not really ok as sometimes the fuel level can read off depending on many factors. I have seen mine rise up and down once it gets to 1/4 tank to the point where it may be less than you think. Were you driving it hard at this point or leaving a stop under hard accel? I have had a misfire under these exact conditions in the very same cylinder. There are some issues though with the coils or injectors. You may be able to get all of them replaced. On my car my tech had to open a PUMA case for the injector and they cleared it no problem.
My Youtube Channel
01-28-2010, 04:34 AM | #6 |
Rep 412
My misfires were caused by bad injectors. If you pull your #5 plug you'll have a much better indication, wet = injector, fouled = plug, ok = fuel pump or coil wire. Unfortunately, unless your getting a half-engine light while running stock it's kinda hard to complain to BMW. I had to wait until mine got so bad I was getting a half-engine light on startup, but at least you would know what the problem is. Don't try pulling the plug unless you have the right socket, a torque wrench and at least some mechanical aptitude.
01-28-2010, 06:07 AM | #7 |
Joint Chiefs of Staff
4927
Rep 116,037
Could be plug, coil, or injector, but could also indicate too much boost for your octane. Worth a BT log, and maybe swap plugs and injectors with cyl 1 as a test.
Mike |
01-28-2010, 08:40 AM | #8 | ||
Rep 424
Thanks, guys.. I was kinda hoping the fact that the problem went away after a few minutes would indicate something more specific. I guess I'll need to get back to stock and bring the car in...
BT log - I think I do have one of those. Are they more telling than the information I copy/pasted? I had the program record a log for this most recent session...
Sal Collaziano
Stinger Forum |
01-30-2010, 09:17 AM | #9 |
Rep 424
Okay, so I set my JB3 from map 5 down to map 3 and I'm not having the problem anymore. Of course, at map 0 it's not there either. This tells me I'm not going to get any help from BMW at all. My only option will be to go with a Dinan flash (which should bring up the problem again so that BMW can rectify it) with a custom JB+.. Since I won't be getting a Dinan high performance oil cooler, I'll be going with a stage 2 flash. Hopefully with the JB+ and a few other things, I'll be seeing the kind of performance I had with my JB3 set at map 5 - which is plenty for me. The way I see it, if your car is faster than mine at that point, congratulations...
Anyway - if this change to a lower map indicates anything, please let me know.. Thanks in advance!
Sal Collaziano
Stinger Forum |
01-30-2010, 08:18 PM | #10 |
ahat
1046
Rep 2,592
I had a 29D1 today on a 200 mile road trip at 65mph. Never even went more than .3 throttle the entire trip.
When stopped at a light noticeable miss - then half engine about 60 miles later Plugs replaced less than 4K ago. Runs fine after restart - gonna watch it a bit.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 Last edited by 335e92tx; 01-30-2010 at 08:25 PM.. |
01-30-2010, 08:42 PM | #11 | |
Rep 5,780
01-31-2010, 06:15 PM | #12 |
Rep 424
Thank you. I'll have somebody do the plugs first to see if that takes care of the problem. If not, than I'll move on...
Sal Collaziano
Stinger Forum |
02-01-2010, 12:53 PM | #13 | |
Rep 332
Hey man I had the exact same thing happen. Take the tune out, don't delete the codes. If it's the same as mine, you need new injectors. If more than two are misfiring on the same side then per the latest SIB they have to replace all of them on that side. Had that done, run like a dream since! |
02-01-2010, 01:30 PM | #14 | |
Rep 424
Sal Collaziano
Stinger Forum |
02-01-2010, 01:34 PM | #15 |
Rep 424
In the meantime, I think I'm just going to have an outside mechanic switch the fuel injectors and/or spark plugs from one position to another and see if I get codes for the new location. If I do, than I know to replace either that injector or spark plug. I'll replace all the plugs if that's what it is.. I'm sure the injectors are a little more expensive, though..
Sal Collaziano
Stinger Forum |
02-01-2010, 01:59 PM | #16 |
Rep 7,377
Just change spark plugs. i changed them every 10-15.000 km and when you pull them out you can see that it was time to do so.
02-01-2010, 04:49 PM | #17 | |
Rep 332
Maybe if you can't get the misfire to show up without the tune, it's just the spark plugs? Hopefully that's the case because I think the injectors are pricey outside of warranty... |
02-05-2010, 07:33 PM | #18 |
Rep 424
Just to note, the misfiring started happening on map 3. So I've jumped down to map 1. If it starts happening there, then it'll probably start happening without the JB3 installed - which would mean I could have the problem rectified by BMW. I still may go to the guy mentioned above anyway - it's easier.
Sal Collaziano
Stinger Forum |
02-17-2010, 10:57 AM | #19 |
Rep 424
I took my car to M-Werks (John) in Pompano Beach, Florida and he took care of my car. It was a coil.
I definitely recommend him if anyone has issues in South Florida.. 954-478-1888
Sal Collaziano
Stinger Forum |
02-17-2010, 11:02 AM | #20 | |
3442
Rep 79,211
02-17-2010, 11:03 AM | #21 |
Rep 424
Thank you. It's been all taken care of, however. It was the coil:
http://www.e90post.com/forums/showpo...5&postcount=19 I didn't think it was the tune's fault - just too much power for whatever was going wrong at the time. I originally figured it was a spark plug...
Sal Collaziano
Stinger Forum |
