Is the stock FMIC enough for road use?
02-05-2010, 03:45 PM | #1 |
Rep 98
I have been seriously thinking going for my next mod: FMIC.
However, after reading a lot of posts, I got a little skeptical... I read some posts that defend that for road use the stock FMIC is good enough, because most of the tests that compare stock vs upgrade are done on the bench so the airflow that reaches the FMIC is a lot weaker than we do see on the road… For what I understand, and for the comparisons I saw, the upgraded FMIC's don't give much more absolute power than the stock one. They just maintain the power stable pull after pull. I agree that this may be an issue on the track, but on the road you just can't keep WOT all the time... From this test one can conclude that even after 5 pulls the stock FMIC doesn't loose that much. And this is not an on the road test, so with more air, the stock should't loose that much on the first place! So, should I do this upgrade for normal road use? Regarding FMIC options, I am thinking to go the Forge route (no trimming and sold in Europe), but I didn't find any comments about how much power it can handle... Should it be enough to support other mods that I might want to do in the future?
E92 335i '07 6MT
Procede V4 | AMS FMIC | AR Catless DP | BMS DCI KW V1 | H&R Sway Bars |
02-05-2010, 03:53 PM | #2 | |
Rep 488
02-05-2010, 05:21 PM | #4 |
Former N54 Fanatic
84
Rep 1,927
Drives: Slow
Well, I'm not sure people are upgrading their FMICs for "absolute power" as they're better reasons behind wanting the upgrade
02-05-2010, 05:25 PM | #5 |
Rep 7,377
its a must for the 335i . the stock one is ridiculous.
02-05-2010, 09:47 PM | #7 |
Rep 746
intercooler..... hands down based on my research....
2009 BMW 335i Sedan / Auto / Paddles / Sport / BMW Assist / Heated seats / JB Matte Black Grill / Tischer First Aid Kit w\Triangle / Tischer Hood Pad / "Custom" rear fog switch <---- SOLD!!!!
02-05-2010, 10:16 PM | #8 |
Rep 2,556
RBC-
I don't have a tune but installed a FMIC last year because I felt timing being pulled on long, hard uphills last summer. You've got a tune=higher intake temps, so a FMIC should serve you well.
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
02-05-2010, 10:18 PM | #9 |
Rep 319
So if you don't have an oil cooler, getting a FMIC is the better option before getting an oil cooler. I thought GIAC and Dinan won't flash the cars without an oil cooler. Is it the FMIC will add power where as the oil cooler only adds safety?
02-06-2010, 12:17 AM | #10 |
Former N54 Fanatic
84
Rep 1,927
Drives: Slow
02-06-2010, 04:29 AM | #12 |
Rep 98
Ok... Convinced already!
Maybe I will do the downpipes also as I am going to the shop... Which V4 map are you running with FMIC and with FMIC+DP?
E92 335i '07 6MT
02-06-2010, 06:57 AM | #13 | |
Rep 1,898
You can also import an FMIC from the states. I have recently did this and is no problem at all. Transport is fairly cheap, customs depends a bit. A paid only 45CHF import fees for 3(!) FMIC (ordered some for friends as well). FYI, I bought the ETS because of stock fit without trimming and inclusive piping. |
