Does Air Scoops make a difference?
02-15-2010, 03:45 PM | #1 |
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
Are they worth it?
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS Last edited by AltecBX; 02-15-2010 at 10:05 PM.. |
02-15-2010, 03:47 PM | #2 |
Rep 1,677
The cyba one's for $40 to me is. Whether they work or not, $40 isn't a big deal to me. I also coupled it with K&N drop-in filter. I also could've gone the DCI route but I'm still warranty and would like the car to look stock.
02-15-2010, 03:48 PM | #3 |
Rep 2,558
doubt it... i have 'em and i don't notice much difference... I'd say if you can get them for <$20 maybe get them... *shrug*
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
02-15-2010, 05:15 PM | #4 |
Rep 15,818
I do like the way they look heh
02-15-2010, 05:29 PM | #6 |
Rep 944
just a mod, nothing else.
http://www.youtube.com/user/Ferre86
| e93 M-DCT ESS VT2-625 | Akra Slip-on | Challenge Race Catless x-pipe | Challenge front lip | Challenge Diffuser | Carbon front grilles | defi gauges control unit | Macht Schnell gauge panel | E93 M3 trunk Spoiler | IND Carbon Fiber Side Markers | |
02-16-2010, 02:28 AM | #7 |
Rep 2,663
Looking at getting the aFe Stage 2 intake. Was wondering if I should get the dynamic air scoops with it. What are ya thoughts.
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
02-16-2010, 07:57 AM | #8 |
Rep 5,463
If they do anything at all, it would be with a closed pressurized system, once you put open filters on, they really can't make any difference what so ever.
2025 X5 Msport
02-16-2010, 06:17 PM | #9 |
How you like them apples?
41
Rep 1,492
Drives: 335i
lol lighten wallet
there are a couple of other posts here that are older that hammer this out...but long story short RPI tells us all about a few hp more at above 70mph the ability to gauge that is hard without proper testing. I am running cyba scoops and DCI and they work great...I can feel the difference at times.
V5 rev2.5 | VExhaust | V1 KW | V701 | H&R Sway Bars | Ram Air Scoops | DCI |
02-16-2010, 07:30 PM | #10 |
Riding the knock sensor
2437
Rep 1,617
Drives: 21 X5MC | 23 M4CSL
I can tell you I picked up a couple MPH on high speed sections of the track in the E46 M3 after installing RPI scoops. Unfortunately, I don't track the 335i often or have a baseline precise enough to determine if there is improvement for the N54. FI and NA senstivity to the changed airflow are different too, making this comparison, and hence this post worthless. Hey, they do look cool though
02-16-2010, 07:48 PM | #11 |
Once upon a time ......
276
Rep 5,048
Drives: 2008 JB E92 - SOLD 5/2010
They will make a difference in performance, but only if you're rollin' at 60mph + ........
That would be with a DCI setup ....... doubt they're going to contribute at all with the OEM box. Limited breathing room. |
02-16-2010, 08:13 PM | #12 |
Rep 3,730
Save the money for a FMIC or DP since you already have the tune. I do not notice anything using the good ol' butt dyno, whether they help out at high speeds is debatable.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
02-16-2010, 09:32 PM | #16 |
276
Rep 5,048
Are ya sure 'bout that? Seems there was just as much picked up without the scoops installed as there was with them ......
02-17-2010, 07:22 AM | #17 |
Keepin' America Free
72
Rep 1,260
I think the $120 or so for the AFE scoops is outrageous, but PM cyba he sells them shipped for under 40. I figured every little bit of cold air helps for my hot air intake aka DCI, so for $40 I got them. Still waiting for them though, I'll chime back in when I get them.
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough" -Mario Andretti |
02-17-2010, 07:28 AM | #18 |
Rep 2,314
I used them in the summer just for the fact they push more air under the engine bay. In Texas is gets pretty hot and humid so I thought a few degrees cooler couldn't hurt. As far as performance.. i think you're dreaming. I did notice more dirt/rocks in the engine bay area.
12-11-2017, 07:58 PM | #20 |
Rep 5,463
you would have to hit 700+ mph for them to do anything, it is simple math.
Equation is Pra = (mph)^2 x 0.0000176 Where Pra = Pressure in PSI, mph = vehicle speed in mph, 0.0000176 is the constant for this equation. So, Pra = 700^2 x 0.0000176 Pra = 8.624 psi Stock boost is 8.5 psi, so at 700 mph, you would be making the same pressure as the turbo, so net no gain - everything over 700 mph would result in more pressure than the turbo itself is actually making, but then you would create some compressor surge. It also will not pull any colder air since it is a high pressure area when you are moving, it isn't going to scoop any more air. If you like the looks, then fine, but no one can seriously think they do a single thing - it is like blowing into your vacuum cleaner and thinking it makes more suction.
2025 X5 Msport
12-12-2017, 03:49 PM | #22 | |
Rep 2,704
Going by your logic, any intake upgrade does not work then. Including the intake installed on your car currently. It is well documented that all added intake upgrades help, more volume of air and if colder is always better. |
