Vented racehoods w/ open air intakes
02-24-2010, 12:37 AM | #1 |
Rep 2,190
Just a thought, would vented hoods for the e90/e92 provide nominal (if any) gains for the performance of an open air intake (or potentially lowering the intake temperature)? In the purpose of this thread, it seems that the placement of the injen dci would be perfect for the vorsteiner vented racehood as it is located right under the vents.
Any thoughts would be appreciated, thanks. Here are pictures for reference, notice the placement of the vents vs. the dci. |
02-24-2010, 12:56 AM | #2 |
Rep 44
I believe it would.. Would definitely be a little bit cooler. Might have some dirty filters though.
If only my car was as exciting as my bike
02-24-2010, 01:31 AM | #4 |
EUROPROJEKTZ
187
Rep 7,958
Drives: backwards
I think it would help reduce the heat under the hood but only bad thing is, if it rains, then you better hope your intakes don't suck in water. I was thinking about getting the hood too because of my injen intake sits right under the vent.
LTMW|SPEEDELEMENT|EUROPROJEKTZ
#TeamStretchNPoke |
02-24-2010, 01:41 AM | #5 |
Vorstiener
17
Rep 364
Drives: 07' e90 335
i have a vented hood and my car is fine in the middle of storm country oklahoma, and i have the AFE duals and they are fine, no water in the engine
| 2007 335 e90 | KW V3 | AR DP | ICONZ | AFE | JB3 | VORSTIENER | MTEC | 3D DESIGN | SNOWS | STETT | FORGED DV | VANGUARD | GODSPEED FMIC | |
02-24-2010, 01:44 AM | #6 |
Rep 4,647
Seattle = No Vented Hood For Daily
SGE92TT......................... 12.331 Sec @ 117.89 Mph............................POWERED BY
l BMS DCI l HELIX IC l FORGE DVs l RR OCC & CP & SCOOPS l AR 3" DPs l AE QUADs l BLISTEIN PSS10 l P3 VENT GUAGE l VISHNU PROCEDE V5 AUTOTUNE l Lots of Window Stickers |
02-24-2010, 09:18 AM | #7 |
Rep 2,661
when it rains your screwed. I have a vented hood and I swap out my open intakes for a closed box intake plus they get dirty fast
another thing the vents aren't setup to have air channeled in, but to let the hot air leave. the oil gauge does tell me that the car runs 10-15 degrees cooler
02-24-2010, 09:50 AM | #9 |
3442
Rep 79,211
These vents provide the cool air coming from the lower grills to be push the hot air out the top.
There would be a benefit of the hood, but I just want to say that I dont think it would be providing a "ram air" effect if thats what you were hoping for. Again, these hoods are designed to release the hot air. I wouldnt run this hood on daily driven car personally, due to the amount of debris, rain/snow, etc being able to drop in. |
02-24-2010, 10:46 AM | #11 |
Rep 17,017
Although this is an E46, it will show you what happens to the hood with rain. Moisture will get in but not enough to soak the filter or cause hydrolock. We run both of our cars here daily with vented hoods and it's never been a problem.
Drop me a PM, I can quote you on the hood. |
02-24-2010, 10:56 AM | #13 |
Rep 946
I wouldn't risk hydrolocking the engine, one big puddle or slash from a passing car and bye bye. Happened to my bro's Maxima, rod flew through the block!
02-24-2010, 12:27 PM | #14 |
Rep 2,190
water wouldnt be as much of a problem with afe or bms dci, but since the injen dci is directly under the vent it might be more of a problem because water will go through the vents and fall directly into the intake.
02-24-2010, 01:01 PM | #15 |
Rep 326
Don't worry about hydro locking, coming from experience in the past with Hondas, the only way to get it is if you run a cold air intake set up with out a valve and that set up has to be way under the fender to make it happen, so we can assume you will be alright with the vented hood unless you thinj that in any way you could be getting galons of water from the vents.
02-24-2010, 01:04 PM | #16 |
Rep 10,587
I woudlnt be concerned with hydrolock w that setup. Hell the rain would be like free water injection
02-24-2010, 01:07 PM | #17 |
Reading > Posting
20
Rep 220
I believe the 'hydroshield' mentioned in this vendor thread would address your concerns.
http://www.e90post.com/forums/showthread.php?t=256198
02-24-2010, 01:12 PM | #18 |
Rep 746
2009 BMW 335i Sedan / Auto / Paddles / Sport / BMW Assist / Heated seats / JB Matte Black Grill / Tischer First Aid Kit w\Triangle / Tischer Hood Pad / "Custom" rear fog switch <---- SOLD!!!!
02-24-2010, 01:26 PM | #19 |
ocasionally in crisis
52
Rep 2,358
As already said by a few - this hood would not really give u ram air -
but our engine bays are hot and some of that air would be pushed out / escape. 2 things though: I believe that hood is only avail for e90 someone posted that in miami his oil temps dropped 15 degrees - that is great but hard to believe.
If your car isn't scary - it's just not fast enough !
RPI IC / UR catless DPs / JB3 2.0 beta / UR CAI / Quaife LSD / Snow Methanol Injection / VK oil cooler upgrade / Forge DVs / M3 rear sway / Riss catch can / Paddle shifting 6AT / M Sport steering wheel / Logic 7 / Dunlop Direzza Z1 255/235 / |
02-24-2010, 01:39 PM | #20 | |
Rep 10,587
02-24-2010, 02:38 PM | #21 | |
Rep 1,948
02-24-2010, 02:49 PM | #22 |
3442
Rep 79,211
Hydrolock is not an issue that requires submerging of and/or forced water into the intake and then into the engine. Not going to happen from rain drops.
