is there a turbo back 3inch exhaust for 335i
02-28-2010, 02:45 PM | #1 |
Rep 529
i was wondering if there is a full turbo back 3 inch exhaust out there for the 335i coupe? or i would have to get it custom made?
thanks
RIP E46 M3
RIP E92 335i RIP F80 M3 Hello G80 M3 |
02-28-2010, 02:48 PM | #2 |
Rep 4,936
I think this would be your best bet http://www.e90post.com/forums/showthread.php?t=338490
It aint 3 inch all the way back but its one of the only turbo back systems made.Now if you want a 3" back i think you would need to custom make it
[SIGPIC][/SIGPIC]
02-28-2010, 03:00 PM | #5 |
Rep 7,377
the AR are still tapering down to 2.5 inch so maybe AR can do a custom version .
02-28-2010, 03:03 PM | #6 |
Rep 2,409
Just take your car to an exhaust shop, tell them to make you 3 inch downpipes and a 3 inch exhaust. The total will run you the same if not less than buying AR downpipes and the Active Auto cat back exhaust.
Otherwise if your not dead set on full complete 3" exhaust then just go with the standard exhausts you find on the forum. |
02-28-2010, 03:08 PM | #7 | |
Rep 3,730
Check out TMR's thread about a single 3" custom exhaust: http://www.e90post.com/forums/showth...single+exhaust
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
02-28-2010, 06:03 PM | #8 |
Rep 3,012
I've already discussed this before. And if you want a 3" solution from turbo back to midpipes, which flanges and tapers down to the stock 2.5, stick around because in the next couple weeks there will be a commercial solution available very soon.
02-28-2010, 07:08 PM | #9 |
Rep 12
True dual 3" exhaust systems are perfect for the most power and best sounding exhaust. They let enough exhaust to flow and lower the amount of psi requiered to make certain power and they sound good. What else do you want?
03-01-2010, 08:07 PM | #10 |
Rep 529
i'm really looking for the dual 3inch exhaust but to turn the dual into a single 3inch.
the single 3 inch is equivalent to having a dual 2.5 inch?.
RIP E46 M3
