BIMMERPOST Universal Forums Off-Topic Discussions Board Home theater speakers/sound bar setups..
      03-01-2010, 12:50 AM   #1
ianbiz
Back in a BMW
ianbiz's Avatar
Drives: 2015 335i Msport
Educate me please.
I'm looking at finishing up the TV room in our house, I was wondering what you audiophiles out there are into these days. Trying to do this on a lower end budget as it will be used quite a bit.
Space is somewhat an issue (no floorstanding speakers or multi-amp setups). I do have room to do a typical 5.1 but kinda like the idea of a soundbar and a sub or 2.
Also wondering what you guys are doing for equipment stands when the TV is mounted on the wall.
Ian
      03-01-2010, 01:39 AM   #2
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
Originally Posted by ianbiz View Post
Educate me please.
Focal Dome 2.1 and Yamaha receiver Can't go wrong with that.
      03-01-2010, 01:43 AM   #3
335R1
335R1's Avatar
34
Drives: F30 335i
I'd like info on this sound bar too. Does it give you that true 5.1 surround sound? I've a 6.1 set up in my entertainment room, but want one set up in my bedroom too.
      03-01-2010, 02:11 AM   #4
stimpy
Drives: E92 335i
A soundbar isn't true 5.1. You need the perfect room setup for a soundbar to work correctly as it bounces the sounds off the walls. It's basically simulated 5.1
My buddy has a perfect rectangular room and his Yamaha soundbar sounds really good but it's not a replacement for the standard setup imo.
________
vapir no2
      03-01-2010, 01:19 PM   #5
daixloxbmw
Drives: Corvette Grand Sport
i'm with stimpy on this one... soundbars are not true surround sound options. they only simulate surround sound by bouncing sound off walls so that you are merely hearing echoes of the original sound and they only "work" when you have a perfectly shaped room. if one side of your room opens up to another room, then you obviously wont be hearing any sound bounce back from that side.
therefore, if you are asking true "audiophiles" for their opinions on soundbars... they will tell you that audiophile and soundbars can't be used in the same sentence.
if space is really an issue, try looking into one of these tiny sub/sat HTIB options from sony, panasonic, onkyo, etc. many of them offer tiny satellite speakers that can be placed fairly easily with a subwoofer that can be hidden away in a corner somewhere. although this is far from audiophile-quality, it is still substantially better than a soundbar because it will at least provide true 5.1 or even 6.1/7.1 surround sound.
      03-01-2010, 03:09 PM   #6
ianbiz
Back in a BMW
ianbiz's Avatar
would a soundbar be suitable for the weekly movie and tv show use?
Ian
      03-01-2010, 03:28 PM   #7
ianbiz
Back in a BMW
ianbiz's Avatar
picture of the room currently.
Ian
      03-01-2010, 04:22 PM   #8
TMR
TMR's Avatar
Drives: M3
http://www.usa.denon.com/ProductDetails/3765.asp
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/
SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/
SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/
      03-01-2010, 04:52 PM   #9
SantaPimp27
SantaPimp27's Avatar
Drives: Slow homie
Educate me please.
I personally wouldnt go with a sound bar if i were you. there really not that great and cannot give you true surround sound.
If you post a budget up i could recommend you a quality system to use. With a smaller budget, sometimes its smarter to go with a HTiB, but you can build a decent cheap setup.
      03-01-2010, 05:49 PM   #10
Spaceman Spiff
Drives: R8, 996 C2, Z4MR (sold)
Sound bar = poor man's 5.1. Where the seating position in your room? if it's not at the very end of the room, you'll be better off mounting the 2 rear speakers right at that kink in the wall to get a rectangular setup.
      03-01-2010, 07:02 PM   #11
achenator
Drives: 2017 LBB M2, 2017 R8+
my set up. speakers are Mythos by Definitive Technology
      03-01-2010, 07:29 PM   #12
samwoo2go
Drives: E92 335i
Go for true 5.1 and don't skip out on quality, you'll regret it. If budget is tight. you could always just get the 2 fronts with receiver first. Then center and sub. and lastly for a pair or 2 of surround back for 5.1 or 7.1. I would much rather do it in tiers like that than to get a shitty setup, ESPECIALLY if u use it alot. Why would you cheap out on something you use alot?
      03-01-2010, 07:34 PM   #13
samwoo2go
Drives: E92 335i
I say about $1500 is the minimum for an entry level respectable setup that's not trash.
here found you a good sub to start things off
https://svsound.com/store/index.cfm?...category_ID=12
      03-01-2010, 07:36 PM   #14
number335
number335's Avatar
20
Drives: E92 Coupe
Anyone have any experience with the Bose cinemate series II systems. They sound pretty good in the stores, but not sure if its worth $800. I don't want to run wires all over my home and it seems like a great compact system with great sound.
      03-01-2010, 07:45 PM   #15
SantaPimp27
Drives: Slow homie
+1 this is a very good alternative if your short on cash
bose is some of the most overpriced crap ever. go onto any real forum with guys that do audio for a living and you will almost never see a recommendation for bose.
if you give me a budget i could recommend some speakers that will blow bose out of the water
      03-01-2010, 07:53 PM   #16
samwoo2go
Drives: E92 335i
Bose speakers and Monster cables are caviar of the audiophile world...a whole bunch of money for nothing...but everybody likes it because its mother fucking caviar
      03-01-2010, 09:34 PM   #17
TRZ06
TRZ06's Avatar
Drives: 16' M3
Yep.
I went all out on my HT, spent waaay too much, but then again, the only thing I will need to replace in the next 20 years is the TV.
I have B&W 804S as my mains, with the B&W HTM3 as my center. B&W inwalls 7NT for by surrounds and a Velodyne DD10 for my sub. Running those are a Anthem AVM 50 Pre-amp and a Rotel 1095 power amp.
18? Camaro 2SS 1LE
16' M3 MG Ext. /SO Int. (DCT, Ohlin R/T, 19" wheels)
15' Audi S4
13' Audi TTRS (APR stage 1, MSS springs)
09' C6 Z06
08' M3 Interlagos Blue: 6sp, Tech.
      03-01-2010, 09:54 PM   #18
SantaPimp27
Drives: Slow homie
Originally Posted by TRZ06 View Post
Yep.
damn dude very nice setup. quality speakers last forever, and hold their value very well.
im rocking Paradigms
maybe ill start a Home theater thread where everyone can post up their stuff
      03-01-2010, 10:08 PM   #19
TRZ06
TRZ06's Avatar
Drives: 16' M3
Yeah, that was my thinking with spending what I did on them.
Quite a few of professional musicians use B&W because they are accurate and don't add anything artificial to your source material, the con of that is that they don't add anything artificial to your source material, lol.
The quality of your source material is important with B&W, as if you put shit in, you will get shit out. HOWEVER, you put in a nice SACD or a DTS quality material these things are orgasmic. They are critical listening speakers and reward if you are a audiophile.
Since I got the system, I have gotten very much into orchestra, Comp. Jazz, Yanni type of music.
They do great in the movie department as well.
Good call on the Paradigms, they are definitely a better value then B&W
18? Camaro 2SS 1LE
15' Audi S4
09' C6 Z06
      03-01-2010, 10:20 PM   #20
darkcloud
darkcloud's Avatar
Drives: 09 VW JSW
2006 325i  [0.00]
I could use some suggestions.
1. I need a center channel. Requirements: Must be slim. Mounting is not an option as the logical placement of the tv in my room is the corner. Under $250.
2. 2 Front and 2 Rear speakers. Again this is not a traditional shaped setup. Stand speakers aren't an option, front left placement area is where the dog sleeps haha. Wall mounting is a must. Have all 4 speakers being the same would be great. Under $600.
The sub and receiver I have are currently good enough. Only way I'm pulling off new speakers is because we just remodeled that room and the current speakers won't work for the new placements. I ran all my speaker wires in wall with nice speaker wire wall plates.
My room shape
retired 06 E90 325i
New: 09 VW Platinum Grey Jetta Sportwagen 2.0T SEL w/DSG, panoramic sunroof and Ipod adapter
      03-01-2010, 11:04 PM   #21
lambtron
Drives: Crimson Red E90 335i
Yep.
NICE! BW ftmw....
OP, If you want a super nice sound on a budget, go with HSU Research.
      03-01-2010, 11:08 PM   #22
SantaPimp27
Drives: Slow homie
Hmm, for the two front channels, i would highly recommend some Paradigm SE1's. there a hybrid between the monitor and studio lines, but closer to the studio line.
Here's a review on them:
http://www.hometheatermag.com/compac...tem/index.html
they retail for $300 each. the SE center is $500 and i would recommend either spending more or saving up. 80-95% of all dialogue is sent to the center channel during movies and is arguably the most important speaker in the system. ideally, if you could make a 3rd SE1 work, that would be perfect
Paradigms, like most higher end speakers must be bought from an authorized dealer and are not sold over the internet. Dealers are known to give 10-25% off.
