JB3 2.0 Datalogging Cable
03-07-2010, 11:25 PM | #1 |
Rep 1,065
Drives: RB PWRED E90 N54 6MT
Is BMS the only place I can order the cable from?
$42 shipped for a cable doesn't sound right to me.
RB Turbo/Procede V5/Vishnu PWM Meth Injection Kit/Vishnu DCI/AR Catless DP/AE Performance Exhaust(Sold)/Helix FMIC/Forge DVs/Rixster Vent Boost Gauge/Wavetrac LSD/KW V3/ACT Street Clutch Kit
03-07-2010, 11:46 PM | #2 |
Rep 871
If its an consolation to you..... guys who don't take the risk on some random USB/serial cable for their V4 end up paying $41 for the RadioShack USB/serial cable. :P
In all seriousness, the pins in the serial connector are not standard and its probably best to just buy the BMS cable directly. |
03-08-2010, 12:23 AM | #4 |
Rep 1,065
I paid $13 shipped for the cable when I was using Procede back then.
I just don't understand what's so special about this cable for JB3.
03-08-2010, 12:29 AM | #5 |
Rep 871
thewgw24, the only thing special about this cable versus one you would buy off on the internet is this one only has 3 pins in the serial connector. You could easily make your own for cheap, but you have no idea what the 3 pins go back to on the USB side unless you get your hands on a cable and disassemble it and at $42 shipped, it probably isn't worth the time/effort? Plus, BMS probably won't support the cable if you built it on your own.. understandably.
03-08-2010, 12:45 AM | #6 | |
Rep 1,065
03-08-2010, 08:13 AM | #7 | |
The Stig
31
Rep 1,232
03-08-2010, 08:30 AM | #8 |
Joint Chiefs of Staff
4927
Rep 116,037
You can also make your own but may not save much. The cable is only 35.00 and if you buy it from me or BMS you will know it works and is done right. I am surprised people are complaining about the cost
If you love to DIY here is some help. Get a 5V FTDI leveler cable here: http://www.mouser.com/ProductDetail/...S6UR9QpQ%3d%3d for $20 + shipping. Then buy some DSUB pins, a DB9 housing, and a backshell. Crimp and attach as shown and you'll be off and running. Mike . |
03-08-2010, 09:25 AM | #9 |
Rep 871
Mike,
Could you please get a clearer shot of that last picture showing which pins are being used by which wires in the DSUB connector? Thank you.
Fully Loaded |
03-08-2010, 10:03 AM | #10 | |
4927
Rep 116,037
Mike |
03-08-2010, 12:36 PM | #14 |
Rep 1,065
Already placed an order!
03-30-2010, 12:20 PM | #17 |
Rep 68
Ok, as a happy owner of a brand new JB3, I thought I'd share my input. If you have some soldering skills, you could actually make yourself one for $2.99 I don't undersatnd why the cost is so high (as there is no know-how included
Here is the deal. The FTDI chip inside the cable is nothing more than a standard UART to serial converter; it has NO MAGIC LEVELER inside (check the datasheet here: (http://www.ftdichip.com/Documents/Da...ABLES_V201.pdf). It's a straight pass through, since a USB port supplies exactly 5v (well, voltage by a host or a powered hub ports is between 4.75 V and 5.25 V). I have no clue why they've opted for FTDI, as the cheapest and most widely used UART is the Profilic PL-2303. Typical USB to serial converters actually boost the levels from 5v to 10v by using additional chips (e.g. MAX232), which implies that they should be more expensive than a standard TTL cable. However, one could get such cable wihtin the $3 range from dealextreme.com. It would require bypassing the booster chip however in order to keep the levels at 5v, which could be PIA. Here come the good news. the cheapest one from DX is $2.99 (shipped FREE): http://www.dealextreme.com/details.dx/sku.24512 In fact, it's so cheap, that even though it says RS232 compliant, they stopped putting the max232 booster chip and it is a straight TTL device - it only has the PL-2303 chip inside If you go to discussions, and open the "Internal technical details please?" thread, you'll see people posting pictures of it. In the beginning, they used to put a voltage booster, but that's no longer the case. Most people who ordered lately have received the newer Y-105C version, which is the one we need. However, THERE IS NO GUARANTEE WHICH VERSION YOU WILL GET FROM DX, but I took my chances and ordered one. Keep my fingers crossed it's the cheapo one. Once you get the "brown thingie" board, all you need to do is to redirect the Tx pin by some soldering. I'll keep you posted and post some pictures once I receive it. |
03-30-2010, 01:51 PM | #18 | |
4927
Rep 116,037
Keep in mind only 3 pins in the DB9 are used for the serial communications. The rest are live analog signals for the boost gauge and other stuff. So take caution not to connect to anything other than the three above or you may cause headaches for yourself. Mike |
04-17-2010, 10:23 PM | #19 |
Rep 68
Received the converter, took little more than 2 weeks (can't complain about it providing the cost). It's the simple one - straight TTL . I have few other things going on, will do it in few weeks and keep you posted
08-21-2011, 08:23 PM | #21 |
Rep 204
cant i just use a regular usb cable and instead of using 232r connector just use pins and attach them to jb3? i would be using this 1 time and i dont feel liek waiting for the cable to come
i have over 10 different usb cables at my house how do i know which one to use i would just cut the end off |
08-22-2011, 08:25 AM | #22 |
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
Does anyone know what the DB9 side pinout is?
From the pictures it looks like pin 1, 3, and 5 are used. I'm going to guess that pin 5 is GND, 1 and 3 are either TX or RX. |
