Installing cyba scoops
03-08-2010, 11:45 AM | #1 |
Rep 776
This might sound stupid but I'm having a hard time installing my cyba scoops. I tried screwing them but they always fall off after 1-2 days of driving.
Anyone can help me out?
E92 M3 Clubsport
JRZ | TE37SL | AR1| Stoptech BBK (ST60/40) | Recaro SPG XL + Schroth 6 point | Raven Roll Cage | | Alex Alpine Tune | Turner Test Pipes | AFE Carbon Intake | Bimmerworld Solid Bushings and more... |
03-08-2010, 11:46 AM | #2 |
Rep 28,154
i dont know about cyba, but i installed a bunch of rpi scoops and they recommend rtv silicone on the back of the screw to keep them from backing out. try a nut and bolt instead of a screw, or the silicone
03-08-2010, 12:03 PM | #4 |
Rep 865
Drives: 2018 F15 X5 xDrive35d
I installed them yesterday in like 10 min. Remove the grills, and the scoops holes match with the screws that hold front plastic bumper part and air intake inlets.
03-08-2010, 12:05 PM | #5 | |
3442
Rep 79,211
If anything add blue loctite to the front most torx screw. Dont do Red loctite or you will never get it off. Those torx screws should not be backing out though. TS make sure when you screw the Torx screw on it, you push up on the scoop securely, and make sure the screw gets a good bite. Last edited by Jeff@TopGearSolutions; 03-08-2010 at 12:10 PM.. |
03-08-2010, 04:52 PM | #6 |
How you like them apples?
41
Rep 1,492
Drives: 335i
besides the screws which you want to of course double check they get in there...check those plastic plugs that it lines up with...you might need to spread out the pronges that is has so it really holds your scoops....btw if they are really loose try taking them out and reinstalling...i notice on some of the earlier versions the screw comes off the scoop....
V5 rev2.5 | VExhaust | V1 KW | V701 | H&R Sway Bars | Ram Air Scoops | DCI |
03-09-2010, 12:10 AM | #7 |
Rep 698
Drives: you crazy..
Garage List 2019 BMW M2 Competi ... [0.00]
(SOLD) 2016 BMW M235i [10.00] (SOLD) 2015 BMW M4 [10.00] (SOLD) 2008 e93 M3 [10.00] (SOLD) 2007 e92 335i [6.50] (SOLD) 2003 e46 325i [10.00] |
Be sure that whenever you put the screw on the top that it will actually hold..
When I was installing it I noticed that the right scoop's screw thread(Me facing engine), is somewhat not catching on the screw.. Take the grills off like what everyone says here so that you can press on it better... But got it to work... I've had it for several weeks already and tried to run it up to 150mph.. Didn't drop thankfully..(Knock on wood).
Punky 2021 Model Y Long Range Performance 2018 F80 M3 CS [Sold] 2019 F87 M2 Competition [Sold] 2016 235i ?M? [Sold] 2015 F82 M4 [Sold] 2013 C350 [Sold] 2008 CRV [Sold] 2008 E93 M3 [Sold] 2006 E92 335i [Sold] 2002 325i [Sold] 1996 318i |
