New Dyno results V4 maps 2-23
03-08-2010, 04:10 PM | #1 |
I AM the 12th. Emom
48
Rep 1,007
Fresh of the dyno, though I'd share my results and gather some thoughts..
so fire away!! Dyno: Dynojet AWD Winpep7 335i 6sp man. 4th gear pulls Base -HP: 275.93 Tq:300.11 run 1 - 370.68 @ 376.31 run 2 - 367.15 @ 376.36 run 3 - 366.23 @ 376.53 run 4 - 367.67 @ 377.04 gain about 95 hp.. not too bad? mods: DCI, V4 map 2-23 stg 2 map 2 NO LIMP MODE OR CODES !!!! Operator has only ran 2 other manual 335 I data logged all runs, and have dyno print outs for each run. (when I figure how to post them (data logs and dyno)
e92, 335i SG/ Coral. 6m, LSD,
03-08-2010, 04:21 PM | #3 |
How you like them apples?
41
Rep 1,492
Drives: 335i
thats awesome!!!!! but are you supposed to be running stage 2 though? I specifically rmr talking with vishnu folks and them saying to turn stage 1 with those mods.....
V5 rev2.5 | VExhaust | V1 KW | V701 | H&R Sway Bars | Ram Air Scoops | DCI |
03-08-2010, 04:25 PM | #4 | |
1750
Rep 17,960
Drives: A Lot
The truth is, v4 users can usually run 1 (or sometimes even 2) stages higher than v3 users since it has a iron clad grip on boost targeting. Whereas v3, like other traditional piggyback tunes, is subject to boost range variation due to the DME's air intake temp compensations. OP-- Looks great. Email me the logs/dyno runs and i can host/post them for you. Email is shiv@vishnutuning.com. Cheers, Shiv |
03-08-2010, 04:42 PM | #5 | |
41
Rep 1,492
Drives: 335i
03-08-2010, 05:14 PM | #8 | |
Rep 277
03-08-2010, 05:59 PM | #10 | |||
I AM the 12th. Emom
48
Rep 1,007
(semi-dirty filters tho) [QUOTE=twinturbopg;6871937]thats awesome!!!!! but are you supposed to be running stage 2 though? I specifically rmr talking with vishnu folks and them saying to turn stage 1 with those mods.... it seem to like it so far NO problems, even with agressive driving Quote:
Tq. 100 (all setting default for map 2 stg 2) No I went to a recommended place called "English Racing in Vancouver Wa. Octane- "super" 92 pump
03-08-2010, 06:01 PM | #11 | |
I AM the 12th. Emom
48
Rep 1,007
Marc
03-08-2010, 06:12 PM | #13 |
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
nice numbers, specially for tune + dci only.. cool
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
03-08-2010, 06:17 PM | #14 |
Rep 66
03-08-2010, 06:22 PM | #15 |
1750
Rep 17,960
Drives: A Lot
03-08-2010, 06:41 PM | #17 | |
Rep 2,842
I thought 100 was the default correction. |
03-08-2010, 06:52 PM | #18 | |
I AM the 12th. Emom
48
Rep 1,007
i will re-check next time it gets hooked up!! hopfully not for a long time as i am happy with these numbers! and will wait till the next update Shivman put out with the extra display goodies!!
03-08-2010, 06:59 PM | #19 | |
Rep 2,842
But I do think 100% is the default setting.....but IIRC there was a point where some maps were released with 200% as the setting. No wonder you can run stage 2.....your timing advance is probably reduced enough to compensate. The proof is in the numbers |
03-08-2010, 07:04 PM | #20 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
03-08-2010, 07:16 PM | #21 |
Rep 8,745
95 hp with just DCI is just phenomenal! Am I mistaken to say that with V3 +50 to +60hp might be the max gain with just DCI.
Curious to know what full bolt ons (on pump gas) would achieve with V4........
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
03-08-2010, 07:19 PM | #22 |
1750
Rep 17,960
Drives: A Lot
Here are the dyno results:
Actual Uncorrected numbers: STD corrected numbers: |
