New HPFP - Reprogram?
03-11-2010, 03:39 PM | #4 |
Rep 17,017
Not sure if it is different for the 335 but my 135 did require programming with the new pump. I think it has to do with priming the pump before you start the car because when I unlock the car, I hear a buzz.
03-11-2010, 03:52 PM | #6 |
Rep 1,037
I asked them to update mine, and they said they can't unless it was required. And they didn't. Had my pump replaced last month
i'm not addicted to boost, but i sure am more fun when i'm on it.
03-11-2010, 04:38 PM | #7 | |
Rep 1,754
Picked the car up this morning, pump hasn't failed yet... We'll all find out soon enough, I guess. |
03-11-2010, 05:02 PM | #9 |
442
Rep 18,331
They first do the update because it will cost them much less and time....But if your changing out to the newest fuel pump there is no need to update software to make it work right....This new pump should work the same as the supposedly old pump...The newer one has better internals which supposedly are more fail proof....we shall see
03-11-2010, 06:53 PM | #10 | |
Rep 1,179
so if you dont want you software upgraded, and you are not under warranty, then they should oblige your request, but if youre under warranty, the shop wont get reimbursed for the repair if all the conditions are not met for this repair -- there are several bulletins out on this -- the latest is 12 55 06 (march 2010 revision) |
03-12-2010, 08:35 AM | #11 | |
Rep 1,037
03-12-2010, 09:01 AM | #12 |
Rep 794
Drives: 2021 M2C, 97 M3
Maybe you got the old pump... what's the last 3 digits of the part number on your service order?
Performance Center Delivery, June 21, 2013: 2013 E92 335is | Le Mans Blue | Gray Leather with Black | 6MT | 19" Style 313's | Michelin Pilot Super Sports | BMW Carbon Fiber Rear Spoiler | |
03-12-2010, 10:57 AM | #13 |
Rep 627
I got my car back yesterday with the new pump and im pretty sure they reprogrammed it, the car feels a little different and my old software used to have the jerky downshift when leaving from a stop and since I got the car back it hasnt done it once. There is no note on the paperwork that says anything about an update.
_
03-12-2010, 11:45 AM | #14 | |
Rep 1,179
if it just a quick blurb -- like cust states -- car cranks for extended period on start up .. replace HDP pump -- doesnt mean the reprogramming didnt take place.. the real story are in the tech comments |
03-12-2010, 11:47 AM | #15 | |
Rep 2,563
The BMW tech was unsure at first whether that would be necessary, but in the end it was not (luckily). Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
03-12-2010, 11:59 AM | #16 | |
Rep 1,179
but just as the advisor said, it will be updated if the situation requires it -- and with the HDP problem that exists its one of the first things on the list of t/shooting measures. -- note: all the 881's were called back to RPDC's and no claim for a 881 will be accepted .. so the 881's are out -- unless the dealer doesnt read there dailys Last edited by shifterboy45; 03-12-2010 at 12:11 PM.. |
03-12-2010, 12:15 PM | #17 |
Rep 1,037
i dont have the slip in front of me right now, but i know for sure that i didnt get the newest pump, because i asked them for it when i brought the car in for the replacement and they said they didnt have the new part number yet. then i joked with him and said, " ok kev, see you in a couple months then."
03-12-2010, 12:31 PM | #18 | |
Rep 1,179
03-12-2010, 03:16 PM | #19 |
Rep 1,037
late january. it was literally like the week that people first started posting about the new part number, and saying that some dealers already had them. so i asked my SA about it and he said they didnt have that new part number in stock yet. i asked them if they could flash me to the most current software, and he said if it would require it then they would. but when i picked up the car, they said there was no need to reprog.
03-12-2010, 03:55 PM | #20 |
Rep 56
I got my pump replaced for the second time last week, with the new unit. This time they did reprogram the computer, and it was stated on the work order. Believe it or not, doing so immobilized my sunroof, which I discovered when I was driving away from the dealer. Returned and the service rep "recalibrated" the sunroof with the key fob.
Anyway, the car idles smoother and seems a little stronger with this 2nd replacement and reprogram. |
03-12-2010, 05:04 PM | #21 | |
Rep 1,179
new I-level
but to each his own ... sorry for the reinitialization problem on the sunroof ;( late Feb is when the push for return of the 881 and the replacement 943 along with 2.37.0 reprogramming with enhancements for long crank .. |
03-12-2010, 10:19 PM | #22 |
Rep 543
Drives: Alpine White 335i coupe
i just recently took my car in on 3/10/10 they tested the low side pressure and found it at 5.5 bars. According to their SOPs the minimum is 4.5 bars. The however proceeded to update the program according to SIB 12 55 06. This update changed the driving feel of the car. Possibly just in my head but the exhaust note seemed a little deeper. My iDrive color scheme was also different. (The traffic from RTM shows up in a different color and some commands are not listed differently. e.g. start route guidance became accept guidance or something of that nature) not sure if this was new either but in the home screen of the map near the zoom indicator i now have a I with a check under it. It def. seems different but i cant recall what was there before.
