335xi: Installing FMIC, DPs & exhaust this weekend...
03-16-2010, 05:45 PM | #1 |
Rep 106
I have a couple quick questions for you guys. I have a 2008 335xi coupe and I will be installing a Helix FMIC, AR catless DPs, and AE catless exhaust this weekend (on jackstands/ramps (read: no lift)). I'm wondering how much different the installs will be on the AWD, as opposed to the RWD. I'll be using the following three DIYs, as well as the factory service manual + some years of mechanical experience...
http://www.e90post.com/forums/showthread.php?t=104333 http://www.e90post.com/forums/showthread.php?t=91461 http://www.e90post.com/forums/showthread.php?t=79514 Please let me know if there are other DIYs that are more suited for my exact application. I'm thinking that the downpipe install will be the only one with any significant differences from the DIYs. Also, I have a set of KW V3s sitting around, ready to be installed. Would it be beneficial to install the suspension at the same time (i.e. will I have to take off front suspension components to access the DPs on my xi)? Thanks in advance for the help. P.S. Hopefully I can get onto a dyno sometime this week for a baseline run before I start going crazy with the mods. Last edited by eclipsor; 03-16-2010 at 05:53 PM.. |
03-16-2010, 05:54 PM | #2 |
442
Rep 18,331
The only difference will be the DPs...which would be more difficult...other than that it should be pretty straightforward...Good luck especially since your doing it with jack stands! If you finish everything after the weekend, your a champ!
03-16-2010, 06:58 PM | #4 |
Rep 1,211
03-16-2010, 07:01 PM | #5 |
Team Zissou
3084
Rep 10,198
not joking, there isn't room to remove the downpipes without doing one of those two things. We cut one of mine in half instead of removing the axel and such... axel removal/install is a pain in the ass.
03-16-2010, 07:05 PM | #6 |
Rep 106
Ugh... removing suspension components is one thing, but removing one of the axles is another. I guess I will just cut the damn pipe. The only time I will be removing the axles is when I change my clutch.
03-16-2010, 07:18 PM | #8 |
Rep 106
How hard is it to get the AR DPs up into their final destination without taking out the axle? I'm guessing it's the cats that make the stockers hard to remove, eh?
03-16-2010, 07:19 PM | #9 |
Rep 1,211
03-16-2010, 07:38 PM | #10 |
Team Zissou
3084
Rep 10,198
My UR ones are 2.5", they went right back in with no issues. I can't comment on the AR's. But like you said, it was the cats that were the issue getting the stock ones out
04-07-2010, 05:48 PM | #11 | |
Rep 106
Well... HO LY SHIT... my car is finally back together and I'm in love.
I installed the Helix FMIC and the AE exhaust myself, then got to work on the downpipes. I cut the stockers in half (I now regret that) before removing the axle and bearing case, which turned out to be a big mistake. Why? Because I couldn't get the axle out of the bearing case or the hub. That fucker was in there good and I had absolutely no luck extracting either end. Obviously there was no going back, at that point, because the stock dowpipes were sitting on the garage floor in pieces. I was getting pretty pissed off and I didn't want to break anything, so I ended up just putting the car up onto my trailer and taking it to a shop near my house. Quote:
The end result is definitely noticeable. The sound is quite intoxicating and my butt dyno has registered a significant increase in power (especially high in the rev range). The exhaust sounds SO much meaner and more beefy than stock. I was surprised to actually hear less of a "gurgling" sound at low speeds (part and off-throttle), which I'm (incorrectly?) attributing to the decreased back pressure. QUESTION #1: The passenger side hose that came with my Helix FMIC doesn't seem to be optimal piece for the job. It's a straight section of hose, if I remember correctly, and it actually should have a slight (5 degree, maybe) bend in it. I made it fit, but the hose is actually deforming (crinkling) because it's being forced to bend slightly. This is definitely not ideal and I'm trying to find a replacement that's better suited for the task at hand. Has anyone else experienced the same issue? QUESTION #2: The Helix FMIC feels to be about three times heavier than the stock unit, yet it's still being held in place by the same two (tiny) screws. I'm very worried about this intercooler dropping out of the car if I hit a big pothole. I think I'm going to try to reinforce the FMIC with some heavy-duty zip ties. Has anyone else had a similar concern? Thanks! |
04-07-2010, 09:09 PM | #12 | |
442
Rep 18,331
04-08-2010, 04:51 AM | #13 |
Rep 1,617
Yeah, I was really surprised that the IC is fixed place by two tiny screws (what's more, screwed into plastic... ).
But I guess it's just as much the IC pipes which hold it in place. On my Forge IC, the OEM tubing is replaced by silicone ones, which are a very tight fight, secured by T-clamps.
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
04-08-2010, 08:41 AM | #14 |
Man with No Name
22
Rep 441
OT: Autobahn335i, could you (in a different thread) post your thoughts on the Forge FMIC (power, temperature, pressure drop and install)?
E92 335i coupe March 2007 |
04-09-2010, 10:24 AM | #15 |
Rep 414
was it this much trouble to get the ar pipes in because the car is an xi? or thats what everyone goes through when they put downpipes in the n54 motor
does it matter if your coupe or 4 door as well |
04-09-2010, 10:26 AM | #16 |
Rep 106
Just XIs have to deal with this... and I don't think it has anything to do with the number of doors.
04-09-2010, 10:28 AM | #17 |
208
Rep 9,339
xi's/xdrive are definitely more trouble than the I's... coupe and 4 door are similar, it's the i and xi that differs.
04-09-2010, 11:42 AM | #18 | |
Rep 2,210
#2 - I agree however I haven't had an issue yet (or read of one) Last edited by stimpy; 04-09-2010 at 11:53 AM.. |
04-09-2010, 12:41 PM | #20 |
Burrito bowl connoisseur
124
Rep 3,501
geezus...i'll be installing the same exhaust and downpipe combo soon. i feel really fortunate at this point to not have an XI...especially since i'll be doing this in my garage on ramps/jackstands.
04-09-2010, 12:48 PM | #22 | |
Rep 106
So, if you don't remove the axle and bearing case, do you drop the subframe and lift the motor. |
