335i 7 speeed dcct gearbox highline
03-19-2010, 07:44 AM | #1 |
Rep 498
Hopefully I'll be picking up the above by the end of the month. Please can someone tell me how this gearbox works. I am not interest in the mechanics more just how you pull away, change gear, do you have to do anything to stop it stalling or rolling forward etc.
03-19-2010, 07:48 AM | #2 |
Rep 8,972
So you've ordered one without test driving or reading about it???
Blimey, Basically it only has 2 pedals and you drive it just like a normal auto (you have driven an auto at some point?) |
03-19-2010, 07:56 AM | #3 |
Rep 498
I have driven automatics before and was looking for a 6 speed auto 335i, but this 7speeder turned up and I have read rave reviews about it, but just wondered if it differed much from the 6 spead gearbox. I have put a deposit down that has held the car.
03-19-2010, 08:00 AM | #4 |
294
Rep 2,602
Well it's a robotised manual gearbox ala M3 SMG/M DCT/Audi (VW) DSG. Two clutches, a gearbox, some hydraulics and a computer! You can pop it in auto and it changes gears for you or use it in manual and change gears yourself. Note: it's not like a "classic" auto gearbox though and not a smooth as there is no torque convertor; it's a manual gearbox with the changes and clutch operation controlled by a computer.
PS it's rather good! |
03-19-2010, 08:09 AM | #5 |
Rep 13,043
Drives: BMW M340I G20
Bigtime, you'll enjoy the DCT.As said already the basic pricaple is the same as an auto, you select drive and the car creeps forward, when you accelerate the gearbox changes up seamlessly.
You have a sport button just below the gear level, which sharpens throttle response and speeds up/down shifts slightly. Knock the level over to the left and you have sport auto mode, which holds a given gear longer in the RPM range and changes with more ferocity, the gearbox will kick down when you gun the throttle If you then move the level forward, you have full manual mode, which will only change via the steering wheel paddles and or by pushing the level forwards or backwards, in this mode the box will not kick down or change up in any gear, you can also select this mode with by pressing the paddles when in auto mode. If you select manual mode via the paddles and don't change gears for a while, it will automatically go back to auto mode. |
03-19-2010, 08:44 AM | #6 |
Rep 4,655
I trust this is/will be available for the 135i too?
I have been seriously considering it in the near future... Will all the nice TV/much nicer looking screen options be in the 1 too? Hmmm... Wrong place to ask I guess, and OT... Matt |
03-19-2010, 08:46 AM | #8 | |
Rep 13,043
http://www.e90post.com/forums/showth...=363642&page=2 |
03-19-2010, 09:12 AM | #10 | |
Rep 3,022
M2 Arrived!
Family 5er |
03-19-2010, 09:26 AM | #11 | |
Rep 13,043
I've not taken it to the rev limiter, so can't answer that, It does change down right at the last minute to prevent stall, but if you were say in 4th at 30 mph and floored it, it wouldn't change down and would take longer to build up speed, just like pulling away hard in the wrong gear with a manual car. |
03-19-2010, 09:29 AM | #12 |
Rep 188
1/ Just watch when the car is cold. When you put it into gear it waits a second or two before automatically blipping the throttle. Then it starts to creep forward or back. The trouble is that within the second or two you think its not going to move so you apply the throttle only to find it then adds to the blip and you jerk away from stand still. Wait till its done the blip.
2/ Also watch when you apply a lot of throttle at low speed but in a high gear. Its like kickdown but the gearbox take a second or two to select a lower gear mean while the revs jump straight up to approx 5500revs. Most annoying when you just want to overtake say one car. Dougie. |
03-19-2010, 10:03 AM | #13 |
Rep 2,396
How are you getting on with the M3 Dougie?
Gone but not forgotten:
325i M Sport (E92), Black Sapphire, Coral Red Dakota, 19" 225's, Seat Heating, 6FL and de-badge Replaced by 6.2 litres of AMG powered C class. |
03-19-2010, 10:06 AM | #14 | ||
Rep 13,043
03-19-2010, 10:24 AM | #16 | |
Rep 13,043
So why would it blip from Neutral to either 1st or reverse? I understand the M3 DCT software to be different to the 335 Dougie, mine doesn't blip, it just creeps off like a traditional Auto. |
03-19-2010, 11:08 AM | #18 |
Rep 13,043
Well mine desent, but I have had a gearbox software change, can't see why it would blip the throttle when going from neutral to either 1st or reverse as it would make the car surge forward/backward
03-19-2010, 11:35 AM | #19 |
Rep 1,898
03-19-2010, 11:38 AM | #20 | |
Rep 1,898
03-19-2010, 11:40 AM | #21 |
Evolve tuned...
9
Rep 291
Mine doesn't blip when going into gear either. It only blips on downshifts
03-19-2010, 11:59 AM | #22 | |
294
Rep 2,602
I am fully aware of the principal of dual clutch systems. They may be quite a novelty for BMWs (a Getrag 'box), but have been around a while for Porsche (PDK by ZF) and Audi/VAG (DSG/S Tronic by Borg Warner). Just because it has 2 clutches doesn't change the fact that it is a clutch coupled gearbox with discretely selectable gears under a computer's control with the gear change and clutch management carried out hydraulically for you. The advent of production car dual clutch gearboxes is simply the evolutionary stage we are currently at as a happy medium for economy, emissions and increased/improved driver involvement against an auto (SMG I was awful), as the single clutch 'boxes (I had 2 E46 SMG II M3s) were OK, but could be less than perfect if you didn't quite get the change right with the accelerator pedal. Having said that, I found it to be better and more involving than Audi/VAG's rather clinical (and boring) DSG/S Tronic or whatever they call it today. As an engineering exercise though, DSG is quite brilliant. I wouldn't class a dual clutch 'box as an "automatic" gearbox. I find it manual in the sense that it has clutches, which are engaged or disengaged and gears which are selected. All of which is carried out robotically for you. PS I didn't say you could drive a dual clutch gearbox yourself. Although if you have 3 legs/feet, it might be possible (an extra one for the extra clutch)...! Last edited by G82Dude; 03-19-2010 at 12:52 PM.. |
