BIMMERPOST Universal Forums Off-Topic Discussions Board what does high beaming mean in this situation?
      03-22-2010, 11:37 PM   #1
my92
Guest
n/a
Drives:
Just curious. I was at a stoplight and across from me was a porsche. All of a sudden he turns on his high beam for like 10 seconds until the light turns green for both of us ( both making left turns ) and then he turns it off as he turns..and I'm just like "wtf?"
wtf is that suppose to mean? Just bmw hatred or some sorta signal or what?
      03-22-2010, 11:44 PM   #2
SantaPimp27
SantaPimp27's Avatar
Drives: Slow homie
dude prolly wasnt paying attention
      03-22-2010, 11:47 PM   #3
endofanera7
endofanera7's Avatar
Drives: 08 JB E92 M3
My guess is that he turned it on so that the light will turn green faster, because most of the traffic lights use some sort of sensor device to operate at night.
The same thing when you're approaching the yellow light (doing speed limit), flash your high beam if you're trying to get past it quick, you will notice the yellow light will stay on a lil longer til you passed.
      03-22-2010, 11:48 PM   #4
solefald
Nigerian Prince
solefald's Avatar
Vatican City State
400
Drives: '11 F25
'11 BMW F25  [0.00]
ever noticed how often at night lights turn green when you pull up?
during low traffic times, traffic lights are activated by lights/movement.
he was trying to set-off the green light
those lights suck ass when you are on a motorcycle.
      03-22-2010, 11:51 PM   #5
Memphis1
Memphis1's Avatar
Drives: Z4 SDrive 35i
hahah, i do that all the time, there's a couple around town that respond to the horn and a few that respond to the high beam.
      03-22-2010, 11:57 PM   #6
MadDog
Careful, I Bite.....
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Another urban legend. Snopes.com
      03-23-2010, 12:01 AM   #7
c0nstant
c0nstant's Avatar
Drives: G80 M3
i thought they were activated by some sort of sensor in the pavement or some shit
      03-23-2010, 12:02 AM   #8
Memphis1
Memphis1's Avatar
you wish...
i've proven it thousands of times at those crossings. light turns red seconds before, i beep the horn and if there's no traffic on the cross street it will change, but if i don't do anything it takes its normal time. and to finish it off, some old people sometimes stop too far away from the white line right below the light, and the traffic light will completely skip changing for that side of the street.
      03-23-2010, 12:07 AM   #9
335R1
335R1's Avatar
34
Drives: F30 335i
I know in CT they are. When I'm no my motorcycle, I'd have to put the kickstand down sometime to attemtp to activate the sensor underneath.
      03-23-2010, 12:40 AM   #10
my92
Guest
n/a
Drives:
Yea around where I live, there's little cuts and markings on the pavement just before the intersection line and I thought ours was pressure activated underneath the concrete or something lol i kept thinking I should have high beamed him back
      03-23-2010, 12:41 AM   #11
my92
Guest
n/a
Drives:
      03-23-2010, 12:45 AM   #12
kyleb350
kyleb350's Avatar
Drives: '21 X3MC
Maybe he was testing his high beams?
      03-23-2010, 12:47 AM   #13
c0nstant
c0nstant's Avatar
Drives: G80 M3
maybe when he signaled he toggled his brights on. it happens to me from time to time
      03-23-2010, 12:50 AM   #14
solefald
Nigerian Prince
solefald's Avatar
Vatican City State
400
Drives: '11 F25
'11 BMW F25  [0.00]
Maybe, but sometimes it works. It may work due to this:
http://www.wikihow.com/Trigger-Green-Traffic-Lights
      03-23-2010, 01:34 AM   #15
aut0sh0cker
meh
aut0sh0cker's Avatar
Drives: E92 335i, 997.2 C4S
From someone who has a history in the industry: traffic signal algorithms are based both on subterranean in-pavement traffic sensors (mostly inductive detector loops, that essentially function as metal detectors) and on traffic flow rate sensors above ground (low-power K-band radar, laser, or more rarely, image based). These are typically backed up by a timer-based rotation algorithm, should any of the other sensors fail.
So to debunk the myths: honking your horn wont do shit, flashing high-beams will only work if there is a non-intrusive image-based detector system that would somehow not pick up your car otherwise
      03-23-2010, 01:57 AM   #16
Dackz
Hates Speed Limits
Drives: E92 335i
Yup I do it all the time around here, works great with the xenons
      03-23-2010, 02:04 AM   #17
Choolgooz
Choolgooz's Avatar
Drives: 08 335i coupe
you wish...
+1
At night i have had luck flashing at red lights at long distances, usually by the time i coast to the intersection it turns green.
      03-23-2010, 02:36 AM   #18
pmeloche
pmeloche's Avatar
Drives: 2013 F25 X3 xDrive35i
I heard that in some area the lights trigger when they detect a slight variation in the space-time continuum when a massive object like a car approaches the intersection.
Patrice
2013 F25 X3 xDrive35i Vermillion Red
      03-23-2010, 02:55 AM   #19
radix
you know he kills little girls like you
radix's Avatar
Drives: -
Originally Posted by Choolgooz View Post
+1
no,no,no,no,no,no
If it "works" for you, it's coincidence and nothing more. Your probably setting off the motion sensor in the pavement, many of which are placed well before the intersection (see solefad's link).
      03-23-2010, 02:59 AM   #20
radix
radix's Avatar
Drives: -
you wish...
correlation != causation
      03-23-2010, 08:53 AM   #21
MadDog
MadDog's Avatar
Drives: 2006 325i
2006 325i  [7.50]
Originally Posted by radix View Post
no,no,no,no,no,no
That's what I said.
Perhaps it's time for some
      03-23-2010, 10:41 AM   #22
777ER
777ER's Avatar
Drives: 2007 328xi
For the 3M opti-com sensor to change the traffic lights for emergency vehicles, it requires a stobe which flashes @ 40Hz, some of them are encoded and need to be activated by a flash pattern.
As for motorcycles, you can get the device to mount on it and it will make the motorcycle 'seen' by the current loop underground.
-Chris
2007 Montego Blue 328xi
Sedan | Poplar trim | Steptronic | Cold Package | Power front seats w/memory | Xenon Adaptive Headlights | PDC | 2008 Plate LED's | PBX | LUX v5.2
