Methanol for the Track? Shiv?
03-29-2010, 01:17 AM | #1 |
Rep 2,368
Is this possible? Or would we need 4gal tanks for a 30min session? I was originally looking forward to using meth as a way to keep IAT cool on the track but only recently came to the realization that a 1 gal tank would be consumed in under 10 mins. Shiv is the only solution a larger tank? in which case how would that work with your methonal setup? Are there larger tanks available?
03-29-2010, 07:17 AM | #2 | |
SUPERMAN
121
Rep 3,171
i dont think so....and if you want a bigger tank companies make 5 gallon tanks
MODS: JB3 18ohm | AR Design Catlles Downpipes | CDV Delete | Clutch Masters FX400 | ZEX Nitrous Kit | Devils Own Methonal Kit | VMR V701 (Matte Black) | H&r Race Springs| BMW Perf Grilles|
03-29-2010, 07:56 AM | #3 |
Rep 7,377
just get the 2.5 or 5 gallon tank
03-29-2010, 11:55 AM | #4 |
1750
Rep 17,960
Drives: A Lot
You shouldn't have a problem with a 1 gallon tank lasting a whole session or more. Maybe just bring some extra meth/water mix with you so u can fill your tank up when it runs low.
03-29-2010, 12:47 PM | #6 |
Rep 2,368
how come the numbers im hearing about whether or not it will last a 30 min HPDE session are so varied? Btw, does the vishnu tank have any other size options?
03-29-2010, 03:32 PM | #7 |
Rep 7,377
wow if those were the problems.... about how big a tank i should get... just get a 2.5 gallon, you should be fine. you dont need to ask CANshiv about it.
03-29-2010, 04:18 PM | #8 | |
1750
Rep 17,960
Drives: A Lot
Shiv |
03-30-2010, 02:49 AM | #9 | |
Rep 2,563
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
03-30-2010, 07:40 AM | #11 |
442
Rep 18,331
7 gallon tank is more than enough to last anyone on a track session....If your one of those track junkies, just get two tanks...One for regular DD and when you goto the track strap on the 7 gallon tank!!!
03-30-2010, 04:43 PM | #12 |
Rep 2,368
Okay, i think i need some help here. Tried searching all over the place for info on the vishnu meth kit but i cant find anything. Can someone point me to it? Im just looking for details on the supplied pump, tank size and nozzle sizes. The vishnu site seems very limited in details.
